Question about Jandy Laars Lt 400,000 Btu Heater
Jandy LAARS LT pool heater blows out the fusible link. What could be the cause?
    President:
  • 2,468 Answers
Check for a heater that is leaking current to the water jacket and this would be a ground and if enough current leaks to ground it will open this link you can check this by undoing the heater,then if its ok then you know its the heater or by checking with an ohmmeter
Posted on Mar 23, 2011
I have a laars jandy 250 lt gas pool heater that only heats luke warm. The heater cycles normally then heats up but stops before reaching operating temp. No service lights and thermal switches are g
I do not have a handy but mine has a temperature setting at the heater and one on the remote. it is possible that one of the settings is low. the pool or spa temp is sensed at the heater and with the water temp located in the pool lines. so both the control board and the heater are sensing the water temperature.
Oct 09, 2014 | Jandy Laars Lt 250,000 Btu Heater
Jandy Lars LT fans doe not turn on and error flashes hi limit
check safety circuit and see if high limits are corroded also see if fusible links are tripped
Nov 27, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
How do u remove hi limit switch from a Jandy LX 400N-L heater model#LX400N-L
high limits are located at header where pipes go in underneath
if those are ok check fusible link maybe 2 one at bottom one at top under top cover
Aug 15, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
High limit switch
check gas pressure if ok fusible link in top has red stripe replace then should be ok
Jun 08, 2013 | Jandy Laars Lt 250,000 Btu Heater
Hi exhaust temp reset for laars LX heater
check gas pressure then replace hi temp fusible link down at bottom
Apr 20, 2012 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Laars LT - "red" light
means calling for heat if heater doesn't come on check safety circuits
Feb 12, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Is it possible to replace the jandy air flow switch
yes you can buy all the parts for the heater here:
http://www.parts4heating.com/Pool-Heaters-Teledyne-Laars-LX-LT-s/435.htm
Specifically this is the part for a heater built after 2003
http://www.parts4heating.com/SearchResults.asp?Extensive_Search=Y&Search=R0302000
Feb 23, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Jandy Laars Lt 400,000 Btu Heater Logo
224 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
