Question about Maytag MDE9700AYW Neptune 174 Electric Dryer
Dryer want heat up. i got fuse tester but where are they at
  • Maytag Master
  • 43,501 Answers
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101[
Posted on Aug 13, 2011
White knight 427 not heating
Heating element is probably burned out. Or the thermal fuse / cutoff. I would check the fuse first as the heating element has 2 independent heating coils and usually both won't burn out at the same time. It would be best to have a meter tester. I am in Lake Worth, Fla. I travel within a 40 mile radius How to Replace White Knight Tumble Dryer Heating Element Heater...
Sep 12, 2014 | Dryers
Amana dryerned7200tw not heating. no error codes
Its either your 220 or heating element or thermal fuse use a continuity tester to see which one it is heres a link that might help.
Dec 04, 2013 | Amana NDE2330AY Electric Dryer
Stopped in mid cycle
Check your thermal fuse. The fuse will burn out if the dryer gets too hot. Take it out and test the fuse with a continuity tester. If it has no continuity the fuse if bad. If it is the fuse replace it and make sure the vent isnt clogged. That would keep the heat in and make the fuse burn up
Sep 24, 2013 | Whirlpool GEW9250 Electric Dryer
Model 66944 Electric Kenmore Dryer has no heat. Runs but doesn't get warm. Check basement fuses and they are fine. What else can I do does this model have fuses on board?
your heating element is out,or one of your hi and low thermostat, or possiby a burned wire leading to these items,best option is to hire a professional,this can all be tested with a tester
Jan 23, 2011 | Kenmore 66942 Dryer
Our Whirlpool dryer model #LER7646AQ0 will not start. Door switch checks for power with a power tester. Put new start switch in and still doesn't work. Do I need to use Ohm tester or will power tester...
This problem is commonly caused by a blown thermal fuse located on the blower housing. The thermal fuse is wired in series with the motor and the motor activates a centrifugal switch for the heating element when it runs. These setup makes the dryer fail to start and the heating element not to turn on if the thermal fuse is blown. The dryer seems to no work at all. Verify the condition of the thermal fuse by bypassing it and starting the dryer.
Disconnect power then access and bypass the thermal fuse on the blower housing. The blower housing is located on the rear left bottom of the dryer cabinet. Remove the rear panel to access the blower housing and so the thermal fuse.
Bypass the thermal fuse by disconnecting the wires and connecting them together. Insulate them properly and plug the dryer back in. The thermal fuse is indeed blown and needs to be replaced along with the cycling thermostat if the dryer starts. Do not use the dryer with the thermal fuse bypassed due to fire hazards.
The thermal fuse and cycling thermostat are part numbers 3392519 and 3387134, respectively.
Jan 11, 2011 | Dryers
Nothing is happening. do have power all the way to terminal inback if control nobs.
Check the door switch with a continuity tester and make sure it's still allowing power thru.
Also check the thermal fuse:
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Dec 02, 2009 | Whirlpool LER4634J Electric Dryer
Heat element
if your dryer isn't heating, it's possible that your heating element needs to be replaced.
are either of these pictures of your dryer?
Whirlpool dryer 1
whirlpool dryer 2
May 15, 2009 | Whirlpool WED5521SQ Electric Dryer
Whirlpool dryer is not drying
the heater could be bad but you need a volt tester to check there are thermastats and thermal fuses that can stop the heat as well as the breaker the unit may run but not heat if one side of the breaker is triped or bad
Nov 29, 2008 | Whirlpool Dryers
DRYER WON'T HEAT
make sure you have 220v going to dryer , get a tester lamp @ home store plug in from center hole on receptacle to right should read 120v ,then from center to left should read 120volt , from far left to right should read 240 volt , make this test before you blame dryer , If you don't get these reading check breakers or fuses ,dryers will run and not heat on 120 volts with one line fuse blown or one side of breaker out
Nov 16, 2008 | Frigidaire FER231A Electric Dryer
Dryer has no heat on any setting after house fuse blew.
We got the problem with our dryer figured out. After checking possible solutions on-line, we checked the power going into the dryer with a ohm tester and discovered we weren't getting full power that we expected. Just after changing the fuses in the house the first time we heard a snap sound but the fuses appeared to be fine, but no heat to the dryer. When we discovered we weren't getting full power we used the ohm tester to test the fuses indiviually and discovered one of the fuses were bad. Put in a new fuse and wala! the dryer is putting out heat. Thank you so much for the service you provide to "do-it-yourselfers" like us!
Nov 10, 2008 | Dryers
Maytag MDE9700AYW Neptune 174 Electric Dryer Logo
20 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
