Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
When I turn the Dryer on there is the letters AF start flashing it is running and drys the close but it takes a lot longer than it did when I got it.
I've seen the AF code twice now on my Whirlpool Cabriolet Dryer (wed6400sw1). The first time, we thought it stood for "Auto Fluff", a cycle to keep the clothes wrinkle free...We soon realized the dryer was getting a lot hotter than it ever did before and until I checked the vent stack from the roof, I had no idea that the pipe was blocked with a build-up of lint. I cleaned the pipe from top to bottom by taking it apart wherever I could using a vacuum and every hose extension I could get my hands on. I duct taped these together so I didn't drop it somewhere that I couldn't reach!
The second time we saw the AF code was this weekend. First, I verified the vent pipe was not clogged again. (a good quick test for this is to disconnect it from the back of the dryer and run it unconnected to see if the AF code fires) After some online research, I started taking it apart the back to maybe replace the thermistor or the thermal fuse shown above.
I noticed an odd little piece of ceramic tubing had fallen down to the base of the dryer pan. So I decided to take the heater core apart to have a look. Sure enough, I found my problem. My dryer has two separate groups of springy looking heater wire. You can see that part here as well as the little tube I found. http://www.appliancepartspros.com/Appliance-Parts/whirlpool-element-item-number-ap3953732.aspx It turns out that ceramic tube is an insulator allowing for the two heating elements to exist without touching since they are both powered from the same starting wire point.
Well, my AF code (which is really just telling you the dryer is getting too hot) was being created due to a broken wire which caused the two units to fuse together. It must have been getting really hot. It also had welded itself to the metal backing structure.
I carefully removed the broken wires from the heater element and reassembled to test. Sure enough, it works good again and no AF code, but I bet it doesn't heat as much since I removed one half of the element. I'm going to pick up a replacement heater element tomorrow from the local parts store to restore it like new.
Hope this helps someone!
Posted on Aug 27, 2012
    President:
  • 1,554 Answers
The airflow is restricted as what AF flashing on the display means. Check and ensure that the lint filter, lint duct, and the vent are clear. Lint built up in these areas causes airflow restriction and AF to flash. Another source of this problem if those areas are clear is a faulty outlet/exhaust thermistor or cycling thermostat located on the blower housing. Replace the outlet/exhaust thermistor or cycling thermostat whichever is applicable to your dryer.
Remove the rear access and locate outlet/exhaust thermistor or cycling thermostat on the blower housing.
Posted on Mar 24, 2011
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
My kenmore elite mod. # 110.67062600 keeps flashing af
It is due to low air flow (AF),clean the vent tube out. The easiest thing to do is disconnect the vent and run the dryer, the AF will not be displayed, you can take the back top panel off an on the inside is a sheet with codes and how to take apart your dryer, as you have lint inside the dryer as well and should be cleaned out at least twice a year, varies on usage. Hope this helps Tim
Apr 07, 2011 | Kenmore 67032 Dryer
The dryer takes three hours to dry a large load. It is almost one year old and it seems to take longer than it used to and the clothes don't actually get that hot anymore
is your dryer getting hot if so disconnect your dryer vent and run a normal load and if it drys that load in a normal ammount of time it is your vent pipe in the wall clogged
Mar 16, 2010 | Maytag Dryers
Clothes dryer drys but no heat(electric dryer)
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 16, 2009 | Whirlpool ET8CHEXSQ Dryer
AF flashing on our Whirpool Cabrio Dryer.
Hi Terry,
AF flashes if a restricted airflow condition exists. Check to make sure the lint screen is clean, the door seal is in place and the vent is not
obstructed.
I suspect it's the vent connecting the dryer to the wall or the vent pipe in the wall to the outside. Without moving your dryer, look behind it to see if the flex duct is crushed or pinched. If it is, it's pinching off your air flow, too. Pull the dryer out straighten or replace the hose (you can get vent hose at Home Depot, Lowes or Ace Hardware) then slide the dryer back being careful to keep it about 8" from the wall (8" is the recommended distance from the back of the dryer to the wall, btw).
If the flex vent is NOT pinched off, then you should call a chimney sweep to come out and clean the vent pipe that's in the wall.
*Note---> If you want to test this diagnosis to verify it, just disconnect the flex hose from the wall and run a load of clothes. The error code should not reappear.
SG
Mar 27, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
AF keeps showing up
AF is an AIR FLOW issue, youll need to check your venting for an obstruction.
Dec 07, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Dryer displaying erroneous letters
AF is restricted airflow clean lint filter and check your vent hose for kinks or obstuctions
Dec 02, 2008 | Kenmore 67082 Electric Dryer
Kenmore 70 series dryer control/timer knob doesn't turn when running
THE TIMER HAS A SMALL DRIVE MOTOR THAT TURNS THE TIMER AT DIFFERENT SPEEDS FOR DIFFERENT CYCLES AND VARIES FROM BRAND TO BRAND BUT EITHER WAY YOU MUST REPLACE THE TIMER , EXPENSIVE FIX IF THE DRYER IS WORTH IT THAT SHOULD TAKE CARE OF THE PROBLEM
Aug 29, 2008 | Kenmore 60172 Electric Commercial Dryer
Drying cycle
Is the drying fan rotating(you should hear this)? Or the watertap closed. It uses cold water to make the steam into condense. If tap is closed, the machine has no water to cool the steam with. Check lint filter.
Jan 22, 2008 | Candy CNW156 Front Load Washer / Dryer
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
954 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
