Question about Ricoh Aficio 2015 Copier
Hello, I have a problem with RICOH Aficio 2015.
Hello, I have a problem with RICOH Aficio 2015. After I power up the machine, I get a READY message, but the problem is that it doesn't load toner in drum. I opened up the drum and cleaned it, but I still have the same issue. Any assistance, please ? Thanks in advance!
  • 3 more comments
  • santosj27
    santosj27 Mar 24, 2011
    What di you mean about "doesnt load toner"???
    How can you be so shore???
    I whant to help you but i dont understand what realy is your problem.
    Try to give more info
  • danielstirbu Mar 24, 2011
    Hi Santos and thank you for your interest,
    The problem with the copier started after I got an error meesage on the display, that there is no toner loaded.
    I disassembled the drum unit and cleaned it (there was no toner left in the drum after this process).
    After I assembled the drum unit back and tried to print, I got no errors messages on the display (only ready message).
    I reassembled the whole copier back togheter and tried to copy a page, but the copier printed a blank page. I want to mention that the toner cartridge is half full.
    After I downloaded the service manual and learned how to enter SP mode (yellow button, 1 0 7, hold the cancel buton 5 sec), I tried to do some tests:
    1. Devlpr Initialize => SC:392 error meesage: TD sensor initial setting error
    - TD sensor initial setting is not performed correctly.
    - ID sensor defective
    - No developer
    - Drum does not turn
    - Development roller does not turn
    - Poor connection of the PCU
    - The voltage is not applied to charge
    2. Force DevlprChurn => SC:390 error message: TD sensor error
    - The TD sensor outputs less than 0.2 V or more than 4.0 V 10 time consecutively during copying.
    - TD sensor abnormal
    In my opinion there is a problem with the drum unit sensor (TD sensor) that detects if there is any toner in it.
    I reached this conclusion because of the above errors and when the drum unit had toner I got the "no toner" error message, also after I cleaned the drum unit the copier acted like he had toner in the drum unit.
    I just need another opinion on this problem.
    Thanks alot for your time invested in this matter, hopefully I can repay your kindness someday.
    PS: Sorry for my poor english.
    Cheers!
    To bad all my page setup is lost, I hope you understand what I meanabove.
    Cheers!
    Ok, I found another way to comment with page setup working.
    Hi
    tests:
    setting error
    - No developer
    Cheers!
    I disassembled the drum unit and cleaned it (there was no toner left in the drum after this process). After I assembled the drum unit back and tried to print, I got no errors messages on the display (only ready message).
    - No developer
    - Development roller does not turn -
    In my opinion there is a problem with the drum unit sensor (TD sensor) that detects if there is any toner in it. I reached this conclusion because of the above errors and when the drum unit had toner I got the "no toner" error message, also after I cleaned the drum unit the copier acted like he had toner in the drum unit.
    Cheers!
  • danielstirbu Sep 13, 2011
    One more thing, when I enter the menu and try to Force Develprchurn I get an error message: 802.011 Force Develprchurn error!
    Guru:
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 183 Answers
Look check that motor bottle is rolling and toner home place is sending toner to drum
Posted on Mar 25, 2011
  • 1 more comment
  • danielstirbu Mar 28, 2011
    Hi, before I cleaned the drum, the motor bottle was running just fine (as he thought he didn`t had any toner in, he tried to load toner in drum). So I dont think there is any problem there, and also I think that I got an error message if the motor was dead, instead I get ready message, like everything is OK.
  • plagio omar Apr 11, 2011
    beware that if bottle didn't belong to machine she didn't rolling correctly all the way look to bottle home position and clean home toner and talk to me
    Hi plagio000, sorry for answering this late as I had some other problems to solve. The bottle is genuine so I dont think is a problem with it, tho when I try to make a copy, the motor doesnt roll the bottle all the way, it rolls just 1 centimeter then it stops, also after a while i`m getting SC:390 error again. In my opinion there is a problem with the motor, but I want to be sure is only this and not some other hardware.
    Thanks in advance!
After replacing the main motor of my richo afico 2018 the copy result reduces is the cause of mismatch main motor?
Yes, If you have installed a main motor from Aficio 1015 the machine will work and there will be no SC Code displayed, but the machine will print a reduced image.
The part number for the main motor for Aficio 2015 is :
" AX06 0270 Brushless Motor 24V/20W "
Oct 05, 2013 | Ricoh Aficio 2015 Copier
Error code ricoh aficio 2035
hello what type of error code do you receive?
SC XXX
Nov 30, 2010 | Ricoh Aficio 2015 Copier
Hello we have one printer Ricoh 2015 we want to connect to network printing . It is possible
In order to connect it to a network, you need to have the print/scan option installed. If your copier has the print/scan option, you can hook it up with an Ethernet cable and download the print driver from the Ricoh website:
http://ricoh-usa.com/downloads/software.asp?tsn=Ricoh-USA
May 29, 2010 | Ricoh Aficio 2015 Copier
We want our ricoh aficio 2015 as a network printer what type of interface we required?.
first u have to purchase feature expantion or GW board from ricoh if it has been already installed in d machine just download the rpcs driver from www.ricoh.com
and install to ur pc
Apr 21, 2010 | Ricoh Aficio 2015 Copier
Installing Printer/scanner kit to Ricoh Aficio 2015
the main part of the kit is a dimm card. the dimm has the fax/scan/print stored on it. the problem adding this to your machine is drivers, only twain scanning, no scan to folerd, no internet faxing, no winodws 7 drivers. if you get a whole kit you need to add the fax pcb and also get the nic for it to scan properly. good luck
Dec 23, 2009 | Ricoh Aficio 2015 Copier
Aficio 2015 ADF not working
if you plug the ADF connector while the machine is on the code will appear when you connect the ADF shut down the machine and then connect the ADF plug
Jun 22, 2009 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015
Pressure roller warm up error. Usually means that the fuser roller isn't at the right temperature when you turn the copier on.
Try turning the copier completely off. Wait 30 seconds. Turn it back on again and see if it goes away.
If not a technician should look at the fuser section to see what the problem is.
Jul 15, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015
Does your machine have a document feeder on it? If so, turn off and unplug the machine from the wall, and check in back of the machine to see if the feeder is plugged into the unit properly. Try reseating the document feeder plug to ensure good contact. Plug the machine back into the wall and turn it on. If it detects the document feeder, fax and scan functions should be restored.
Jun 16, 2008 | Ricoh Aficio 2015 Copier
Ricoh Aficio 2015 Copier Logo
429 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
