Question about HP LaserJet 3800 Printer
Printer keeps running configuration and won't stop. We got an error 54.16 something with the sensor. How can we fix it?
    Genius:
  • 1,089 Answers
54.16 error is caused by the magenta toner-level sensors.
The fix is to get the DC Controller replaced.
If you are not a technician, you will have to take the printer in to a repair center.
Posted on Mar 24, 2011
Testimonial: "thank you we will try that"
How to solve transport error on wincor nxdorf 4915xe
usually transport errors mean that something inside the printer is not allowing or not feeding the paper through properly , either a motor isn't kicking on, paper is not being picked up from the supply tray properly or there may be something caught in one of the stop sensors inside the printer that will not allow the paper to pass through properly. unfortunately the only way to fix that usually is to look at every sensor in the paper path and ensure nothing is blocking or holding any of the sensors open if none of those are blocked off then you may have a bad motor on one of the drives that pull the paper from one location to another inside the printer.
Jun 25, 2014 | Brother Dcp-7055 Laser Print Copy Scan...
Tip
Error 5100 fix
This issue could or could not be with the printer itself. Try these steps below.
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Run a test page, your printer should respond as normal.
If the steps above does not work for you, then you need to check printer for obstructions by checking the inside of your printer through the gears that you can see under the lid. There should be something obstructing the gears such as dirt. Also,
1. Clean the strip film.
2. Clean the strip film sensor (back of head carriage)(use contact cleaner).
3. Fix purge unit.
Thank you for visiting FixYa! We answer your concerns promptly for FREE. Please spare a few seconds to click on YES button in return. Have a good one!
on Jun 06, 2011 | Office Equipment & Supplies
My printer keeps giving a false paper jam error message. How do I fix it?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Dec 06, 2010 | Canon Office Equipment & Supplies
When i print any photo it can't print error show E3
hi, look at this post maybe can solved your problem not all Error E3 means your printer part damage but maybe somethings inside it that makes the printer look likes paper jam,
Canon MP198 Printer Error E3 is because something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things.
Look at the paper sensor there is must be somethings in it. I found this when my printer Canon MP198 got error E3. I found small part of paper in the sensor that makes sensor not function properly. I just remove the paper and the printer working again.
see also
http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html
Nov 18, 2010 | Canon Office Equipment & Supplies
Error code 3 on canon mp 198
Hi
Canon MP198 Printer Error E3 is becaused something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things.
Pls vote us to keep us alive
Nov 16, 2010 | Canon PIXMA MP160 All-In-One InkJet...
I had to bring a computer home from our office where it was connected to a network. I am trying to install the printer CD for the HP LaserJet 3055 printer and at some point in the process, I get the...
Go to START >>> RUN then type msconfig..(click on OK). It should bring up System Configuration window. Go to STARTUP tab then un-tick the entry you think is the DOS Command String. This should disable it from running during startup. Restart the computer.
Nov 10, 2010 | Office Equipment & Supplies
Epson Stylus PHOTO RX500 - PRINTER ERROR message
keep pressing the button, until it stops where you want.
good luck
Mar 21, 2010 | Epson Stylus Photo RX500 Printer
Paper jam 2 on Samsug ML-3051N
There is a door around the very back of the printer, if your printer is slightly encased in as mine is you can't see it. That is where the Paper jam 2 is
Jan 04, 2010 | Samsung ML-3051N Laser Printer
Error on tally genicom 6312
found this on Tally Genicom's Website about your device.
Technical Services Note
MT6xx/T6xxx (All) Paper Motion Faults 11 May 1995
T645.039
If you are having problems with recurring Paper Motion Faults that don’t seem to stay
fixed by doing the paper motion sensor calibration, try the following:
· Check the back of the form along the left side to ensure there are no black (dark) areas
in the area of the tractor drive holes. (If there are, this is probably the problem. If not,
proceed on down this list.)
Clean the sensor on the upper left tractor then run the calibration routine again. If it’s
not better yet, continue.
With Tech Access ON, do the following:
Go into DIAG - Meters - Paper Motion and monitor the sensor reading with paper
installed and removed. If the reading with paper installed is in the 300 to 350 mVolt
range, change the sensor (even if it seems to run the calibration alright). A more
normal reading would be something greater than 600 mVolts for the MT691/6092 and
1000mVolts or greater in the 645/661. Don’t forget to recalibrate the sensor. If it’s
not fixed yet, try this next step.
Run a configuration printout and then do the following:
1. Clear the NV Ram (Tech Access feature ON)
2. Calibrate the Paper Motion and Paper Out sensors
3. Restore the configuration based on the print-out you just ran
http://www.tallygenicom.com/support/technotes/tnote/d5639.pdf
my site: www.techvisitor.com
Jul 01, 2008 | TallyGenicom 6312 Matrix Printer
Printer keeps getting jammed no matter what
clean all sensors and make sure you have good dry stock to run through it like a heavy 28 lb paper. also check the path of the paper and see where it stops it might be at the paper tray pickup or even the fuser. try running the machin with the covers open by jamming something into the cover sensor and see where the paper stops at.
Aug 27, 2007 | Sharp AR-407 Copier
HP LaserJet 3800 Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
