Question about Weather King 10AJA3001AH Air Conditioner
When you turn air on the outside unit buzzes but doen't run
    Genius:
  • Weather King Master
  • 1,033 Answers
Hello, sounds like you have a bad contactor coil, replace the contactor and also the capacitor while you are at it.
Posted on Mar 23, 2011
  • 18 Answers
SOURCE: Carrier Air Conditioner, cool air then runs luke warm air
Have you checked the freon level in this unit? If you are low or there is a leak it could be the problem. Hope this helps.
Posted on Dec 11, 2008
  • 306 Answers
SOURCE: Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
Posted on May 02, 2009
  • 166 Answers
SOURCE: No cool air coming into house.
Yes, so as not to be repetitive (as others have had the same problem), here's a simple article that percisely explains the possible causes of your AC not cooling:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Also, if need be, take advantage of the link towards the end for four free quotes from technicians if you find yourself need to get one. (You don't want to needlessly be charged for just someone's coming over only--it could cost a lot for no substantive action.)
Brad
Posted on May 25, 2009
  • 340 Answers
SOURCE: Air handler is running but outside unit fan is not
The buzzing if it is real loud is a very wore out contactor and could be the cause of your unit not running. Check your circuit breaker. you'll likely need service and have the unit cleaned for best performance. Good luck Tom
Posted on Jun 28, 2009
  • 38 Answers
SOURCE: The outside unit buzzes and will not turn on
you have a bad capacitor in the unit, they have dual capacitors. If you can open the service panel outside and look at the silver can, it will probably be swollen up, if that is the case it needs to be replaced
Posted on Jul 01, 2009
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
I need help with a buzzing sound in my air conditioner.
It is probably the compressor humming. They can make some funny noises especially on start for a while. If the unit is not cooling it may be the start capacitor or the comressor may be locked up.
Jul 19, 2010 | Goodman CLQ36AR49 Air Conditioner
Fan not working on outside AC unit
The buzzing noise is probably the fan motor. Is the compressor running? First make sure that there are no tripped breakers. After that kill the power and check the capacitor with a multimeter. If that checks good then check the fan motor windings with the multimeter. Let me know if you have any questions.
May 26, 2010 | Intertherm P3RA-060K Air Conditioner
A/C outside unit will not run. Inside works, breakers are on and did not trip. No noise coming from outside unit, except for low buz when 1st turned on. After 10 seconds, nothing. Goodman # CPLJ36 - 1B. No...
sounds like your contactor/relay on compressor defective, by the way it sounds the buzz is from the magnetic coil on the contactor but its not pulling the contacts in to start the compressor
Aug 30, 2009 | Heating & Cooling
A/c outside not working
The buzzing noise is your contactor drawing in from your thermostat. The fan part of your unit is on a different circuit from your outside A\C unit. Your thermostat is the conductor of the orchestra tying ths units together. It may well be that your A\C circuit breaker has tripped, if it has there is a reason for it's tripping. Resetting the breaker by turning it off then on may get your unit running, but a technician needs to ascertain why it tripped. Or it could be a bad contact switch inside the outside unit not letting enough electricity through the switch. More than likely the first issue. Good Luck
Jul 15, 2009 | Goodman CKL36AR36 Air Conditioner
You have an electrical problem I'd call for service and if has not been cleaned in a while has it cleaned for best performance. Tom
Jun 28, 2009 | Carrier 38CKC036 Air Conditioner
Air handler is running but outside unit fan is not running. Just a buzzing noise.
Jun 28, 2009 | Goodman CPLE24-1 Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
My air conditioner stopped working.
lets check do you have plug something els in the outlet to check for ac curent? the cable of this unit have an overload braker? need more info but better call a tech...good luck
Aug 11, 2006 | Kenmore 6000 BTU Single Room Air...
Weather King 10AJA3001AH Air Conditioner Logo
99 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
acrman404a
Level 1 Expert
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
