Question about Nikon D50 Digital Camera with 18-55mm Lens
Flash Hello I am using the Nikon D50 The flash is not working. Is there a way to toggle the flash? Or to turn on the flash? Thank you
    Problem Solver:
  • 9 Answers
It may be broken/blown, but there is a way to toggle the flash. There is a button located on the left-front of the camera , just left of the flash and above the lens. Hold it while scrolling the wheel on the right.
Best way to find out if it's broke or not: put your camera on Auto, go into a dark room, and take a photo. If the flash pops up and takes a shot w/o firing, you know it's broke. If it doesn't pop up at ALL, you've probably got a bigger problem
Posted on Nov 20, 2008
I have a Nikon D50 black image on bottom of screen what is causing this problesm
If you are using the built-in flash and a telephoto lens, the end of the lens can block some of the light from the flash and that appears as a slightly rounded black "hump" at the bottom of your picture.
Jan 21, 2010 | Nikon D50 Digital Camera
Nikon D50 -flash won't fire
Try pushing the flash forward just a tiny bit. this model of Nikon has a built in problem with the flash popping up too hard. You can also try to "soften" the pop-up action with your finger instead of just letting it snap up into position.
Sep 12, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 : how do I ensure the flash will fire on day shots?
Auto mode only allows for "Auto Flash", "Auto Flash with red eye" or "Forced Flash Off". Forced, flash "ON" does not exist in Auto.
Put it into "P" for programmable mode. Then press the flash button on the left-face. The flash will pop-up. While holding the button, turn the selector dial to select what you want the flash to do - the little flash icons will display on the top panel as you do this.
Cheers.
Jun 08, 2009 | Nikon D50 Digital Camera
Flash on Nikon D50 will not latch down
If you have a fine screwdriver, remove the two screws underneath the pop up flash housing and remove the upper housing. BE VERY CAREFUL OF THE 300V at wires under the cover. You can see where the latch catches on a disk with steps - rotate the disk to a lower step and it will catch. Otherwise, an independent repair shop can probably do it while you wait for less than $40 USD.
Nov 25, 2008 | Nikon D50 Digital Camera
Nikon D50, digital SLR, I was using my camera at a wedding and the flash just stopped working. The camera thinks the flash is going off - it pops up and takes them quickly but no light goes off.... do...
good day,
it seems that your built-in flash is busted. you can go to your nearest nikon service center and have it replaced. or you can purchase an external flash that you can attach to your unit. when looking an external flash better use a nikon flash, however if you are looking for other brands/manufacturers, just check if it is compatible with your unit.
i hope this will help
Sep 27, 2008 | Nikon D50 Digital Camera
Nikon D50 flash not synchronizing
Ok this is a crappy fix but it works for me.
If your flash isn't syncing correctly make sure your on auto flash. when your flash flips up and you get the beep push the piece that holds the flash just a little forward. and walla your flash syncs up.
Sep 25, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Flash out of sync
I just had mine fixed by nikon and it seems as though the problem would come back every now and then. my current solution is to switch over to Manual mode and turn AF assist, AF illumination, and ISO control to "ON" and then then shoot a few shots. Then switch metering to centerweight. take a few shots, it should work correctly, then switch back to AUTO. after that, the flash should fire as normal. I just received my body back about 2 weeks ago, so i hope my "bad batch" flash unit was replaced with a known good one. if not, i don't know what to do.
Sep 18, 2006 | Nikon D50 Digital Camera
Nikon D50 Digital Camera with 18-55mm Lens Logo
142 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
