Question about Frigidaire Gallery GLWS1339EC Top Load Washer
Shirt caught under agitator how do I get agitator out to unwind shirt
    President:
  • 2,468 Answers
You need to pry the softener dispenser cup off the top of the agitator,then you need a 7/16"socket with an extension to remove the nut located down inside there,then lift the agitator straight upward
Posted on Mar 23, 2011
Shirt stuck in washer
Is it under the agitator or between the basket and the tub?
Oct 22, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
How to remove the agitator to remove a shirt that is caught
according to GE if you have a model made after 1999 you need to have a GE technician remove the agitator as it requires a special tool. :(
Dec 17, 2010 | GE Washing Machines
A shirt got stuck and there was smoke accompanied by a burning smell
Possible that the motor was loaded when the shirt got caught into the drive. Allow the machine to cool offf , open the rear/back panel and check to see the heated component. Can be the motor, the capacitor or the belt slipping by. After cooling off and removing of the struck shirt if the set done not works then checck if the motor has failed .
Sep 16, 2010 | Maytag HAV2557 Top Load Washer
Clothing stuck under the agitator
Hold the agitator steady and the very top end will screw off. If very old it will be stuck pretty tight, but do not break it. Then the agitator will lift straight up.
Aug 08, 2009 | Kenmore Washing Machines
Can't get the fabric softner cap off
Don't feel foolish as im sure your not the only one this has happened to. to remove the agitator cap you must lift it off, apply slight twisting to it while your doing this. soap can gum it up so you may have to use a straight screwdriver to assist you. once you have done this, there should be EITHER a set screw for an allen key on the SIDE of the agitator OR a 3/8 hex screw in the center or the agitator. there is a spring under this screw so remove both and the agitator should lift staight up. use an old belt underneath the base of the agitator for better results. i hope this has answered your question.
Thanks
Aug 08, 2009 | GE WJRR4170E Top Load Washer
Sing a Futura Sewing Emboidery Machine, how do I
This I do quit often, just pull the shirt away from under the foot as you go, pause the machine every now and then and readjust the position of the shirt, it is time consumming but it really works and using the correct stabilizer with spray on glue as well as the plastic stabilizer on tob, (pin this very tight on top of the shirt) you get a beautiful result.
Apr 17, 2009 | Singer CE-200 Quantum Futura Computerized...
Shirt caught in the agitator
The top of the agitator should unscrew then pull off.
Feb 21, 2009 | GE Spacemaker Washer and Dryer Electric...
A t-shirt is stuck under agitator/spinner thing. How do I lift off the spin assembly?
yes, remove the softener dispenser at the top of the agitator and there is a bolt there that is holding the agitator assembly. if you remove that bolt, the whole piece can be pull out and you can remove the clothe that was stuck in there.
tnx 4 using fixya,
drcool
Sep 06, 2008 | Kenmore 24032\24036 Top Load Washer
Pockets
Dear sewer:
The only way I have found is to take the pocket off the shirt and re-sew it after you have finished embroidering it. Notrub
Mar 05, 2008 | Baby Lock Esante
Removing the Agitator on a G157 Hotpoint washing machine
Some models have a bolt towards the bottom of the outside of the agitator, depending on model. If it has one, take out out and you'll have to yank on it VERY hard to get of off (you'll most likely lift the machine off of the ground a few times in the process!)
If the bolt isn't there, its under the top cap of the agitator "somewhere". You'll still have to yank up on the silly thing to get it off after taking the bolt out.
Jan 08, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire Gallery GLWS1339EC Top Load Washer Logo
180 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
