Question about Mongoose Mischief Mag BMX Bike
My new moongoose mischief keeps getting loose chain and pedals, ive tightend it up sevral times but keeps doing it, and the pedals keep loosening from the body??? anyone know how to solve this/
    Problem Solver:
  • 7 Answers
My first thought about the chain continuuin to become loose, is that you need to loosen the nuts on the back wheel, and pull the wheel (while the chain is still attached to bot hsprockets) in order to remove any slack. If it's a continuous issue, chances are that back tire keeps migrating forward because those nuts aren't tight enough.
To the pedal issue-If the pedals are wobbling or vibrating because the aren't snug while on the pedal bar (the bar that the pedals revolve around) it is probably because the peddals are too large. Try buying a new set of pedals. If they are loose and trying to slip off of the pedal bar and if you have tightened the nuts that keep the pedal on the pedal bar and they are continuing to become loose, it could be that you need to use locking nuts.
A quick fix to solving loose pedals is to add washers to the end of the bar until the washers are flush up against the pedal and the nut.
Happy pedaling!
Posted on Mar 23, 2011
How do I loosen the chain in a hot wheels bike to loosen the pedals for my kid model 8006-84
you can loosen the chain by loosing both nuts on the back wheel and sliding it ahead a little bit but I do not belive this will fix your problem your son might just be a little to small yet
Feb 24, 2015 | Pedals Cycling
Can you adjust the tension on the wheel?
What sort of tension?
Rim loose on spokes: evenly tighten the spokes to add tension ( very high skill required to keep the rim true. Pro help should be sought)
Too much wheel side play: tighten the wheel to frame axle bolt (unless the bearing is gone, then you'll need new hub bearings).
Chain tension too loose: Move the rear wheel away from the pedals by loosening the axle bolt, pulling back to remove most (but not all) or the slack from the chain. Pay attention to the alignment of the wheel in the frame. Tighten the nuts back down
Feb 17, 2015 | Cycling
I have a new 455 rancher chainsaw husky 20inch bar chain keeps coming off new chain
You may have a bent bar, or you could be putting the chain on a little too loose. Perhaps the chain is not getting lube ?
Possible that the chain tentssioner and or adjustment is loosening up as you are using the unit. Other than that maybe a defective new blade ?
Oct 21, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
We changed the pads, rotors, drums and shoes on our 2001 montana, after we were done the break pedal goes to the floor, we were told to change the master cylinder and did,, but it didnt fix the problem,...
After you change brakes you need to bleed air from the brake lines what you need to do is find the bleeder valve its usually rite beside where the brake line goes in the calipers and looks like a grease fitting get someone to pump the brake pedal 3 or 4 times and hold it while someone else loosens the bleeder valve to drain the air out keep the pedal mashed until you get the bleeder valve tightend back up . Do each wheel until fluid comes out check brake fluid while doing this so it doesnt run out. Hope this helps
Jun 03, 2011 | 2001 Pontiac Montana
The chain on the 16 in chain saw keep slipping. Seems the thumb screw will not stay tight? Who can check this and fix?
First thing I would do would be to loosen the thumb screw fully so the chain is as loose as you can get it Next, loosen the chain bar and pull it out as far as possible which will take up the slack in the chain itself. Re tighten the chain bar. Afterward, you can perform detailed adjustment on the chain by playing with the thumb screw.
This solution has always worked for me and my various chainsaws.
Apr 12, 2011 | Remington 16" Electric Chain Saw
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
Chain damage
The chain could be stretching. Are you using a good quality bar and chain lube? Never use old motor oil. Once the chain has jumped several times it may be bent.
Properly adjust the chain and keep an eye on it while using. start with a new bar and chain and watch the tension. You can also replace the tool less cover with a standard cover for about $25
Jul 01, 2017 | Poulan Pro Chain Saw 46cc 20"
Chain keeps coming off Poulan 2150 woodsman gas chainsaw> Common causes?
The most likely cause is a loose chain.
Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system.
HTH
Lou
Dec 16, 2009 | Garden
Can not keep chain on bar. Tried 2 different
The inside part of the chain are called drive links. I think when the chains came off the first time (loose chain?) some of these links were slightly deformed (burred). Take a flat file to the burrs on the sides of the drive links. Once repaired keep your chain properly tensioned.
Chain adjustment
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They don't need these really loose - finger tight will do.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
If no burrs please repost. This has piqued my interest. I think a brand new chain will operate correctly.
Oct 31, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Mongoose Mischief Mag BMX Bike Logo
210 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
