Question about LG Computers & Internet
Blue "on" light only on
  • 34 Answers
Vaue questions like these should be avoided!. Please specify what lights of which unit and the problem..
Posted on Mar 23, 2011
Power failure
Make, model and OS please.
Feb 25, 2014 | Computers & Internet
KitchenAid KC0111 Countertop Oven - only "Toast" setting works showing the blue active light, while the "Broil" and "Bake" settings no longer work or turn blue light on.
Faults like this can be anything from faulty switches to failed electronic parts. If spillage of liquids or runny consistency foods has occurred, it can find its way into circuits by air migration due to temperature changes and gradually cause corrosion which can lead to chemical changes in board and component materials which render them conductive or inoperative.
The only real solution lies in a complete dismantle to detect the real cause.
That is not something other than a qualified person should undertake as otherwise even more damage may be caused by clumsy handling of the situation.
Feb 01, 2013 | Kitchen Ranges
"NO SIGNAL "is displayed on a blue screen
You have selected an input on the display that is not getting any signal that the display can recognize. Press the source button either on the set or on the remote until you get a signal.
Aug 09, 2012 | Element Electronics FLX-1910 19 in. LCD...
I have a Intermatic ST01C installed with a 3-way connection. The other day it started "clicking" on-off..on-off..on-off etc. and would not stop till I operated the non-timer switch leg in my...
Wiring could be suspect.
I have tested this timer.
ST01C works like this in 3-way circuit.
Timer program turns lights on-off.
When blue wire and red wire are connected together, then timer reverses on-off program.
So the only function of second 3-way switch is to connect and disconnect blue and red wires on the timer.
The second 3-way switch is wired differently than ordinary 3-way.
See illustration below.
http://waterheatertimer.org/ST01C-program.html#3way
Either the switch or timer have malfunctioned.
My bet is the timer.
1) Replace 3-way switch and see if problem clears up
2) Manual says: reset timer when encountering problems.
Hold down on-off button and push-and-release reset button.
Keep holding on-off until INIT displays.
3) You have to completely reprogram timer after reset.
Link above has ez steps.
ST01C manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
Feb 22, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Please advise if there is any step/key that could release the use of key with blue note function. i.e. on "M" key, the blue note is "0", if I could not release its blue note...
There is function key in your laptop which is blue in print and written Fn which means there are some keys like u say 0 written on M it is zero in numbers which work only when u have switched on your numlock.To get back to M switch-off numlock.
Jan 05, 2011 | Samsung Computers & Internet
I have replace the inserted cartiage with a new one and inserted more paper and still the display screen says "drum error" or "no tray". I have also taken out some paper and moved the...
Switched off the Printer and reinsert the cartiadge, and switched it on and the reset button for 7 seconds. And then give a print from your pc. If you facing the same problems, then without doing any thing just again press the reset bottom of your printer for 10seconds. I think this will solved your problems.
Thanks You
Dec 29, 2010 | Office Equipment & Supplies
I hooked up the hot wire to the black and the other wire to the red, the green to ground, the white to the neutral in the box. The timer lights up and shows a display, but the light doesn't come on. I...
Here it is directly from the instructions.
Connect one of the two wires from the wall to the black wire on the timer.
Connect the other wire from the wall to the blue wire on the timer.
Red is not used in a single switch configuration, cap the red wire with a wirenut.
Good Luck.
Gary
Dec 22, 2010 | Intermatic Inc. ST01C Digital In-Wall...
HI, I HAVE A SYLVANIA MODEL SA 170 , I CAN´T SEE THE NUMBERS WHEN I´M IN FROM THE SCREEN, IT´S APPEARS VERY DARKS
If I understand correctly, you have Sylvania 170 timer and the display doesn't light up.
If you have different problem, add a comment.
A) If this is existing installation and timer display worked correctly before, then it sounds like timer malfunctioned or power to timer is interrupted. Check breaker, and then pull out timer and test for power.
B) If this is new installation, then 2 possible things:
1) Timer defective: exchange for new one.
2) Timer not wired correctly.
Review wiring:
Timer replaces single pole switch.
Single pole switch has two wires
Timer has 3 wires: Blue Black White
Timer has additional wire to run internal clock and to light up display.
If timer not wired correctly, then display will not light up.
Here is correct wiring:
a) Two wires from switch.
b) Connect timer-blue wire to one of the switch wires. Choose either one for now. You will have to choose other wire if display doesn't light up.
c) Connect timer-black wire to other switch wire.
d) Timer-white wire does NOT connect to either switch wire. Look in back of electric box. There are white wires twisted together and covered with wire nut. These are neutral wires. Connect timer-white wire to neutral wires. This will power the clock and display.
e) If your box does not have the white wires described in d), then connect timer-white wire to bare ground wire.
f) Turn power ON. Does display light up?
g) If display lights up, switch is wired correctly.
h) If display does not light up, then reverse timer-blue wire and timer-black wire shown in step b) and c).
Dec 02, 2010 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
Blue strips on sony DSC-h20 while looking on lights
its only visible on display. Once you take the snap it will not be visible in the shot. Switch to Inteligent mode, it will remove the blue strips on display.
Oct 06, 2009 | Sony Cyber-shot® DSC-H20 Digital Camera
Computers & Internet Logo
18 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
