Question about Brookstone Slim Profile CD System V4.0 Shelf System
I own a Brookstone model Slimline CD V4.0 radio / cd player. i have hooked a ipod dock to the audio imput port on the back of the unit. how do i get the audio from the ipod to play thru the Slimline?
Cd plays sound the radio dose not
Posted on Apr 04, 2011
Can i hook this up directly to an ipod,or do i have to use one of those radio frequency things?
From what little research I did it does not look like you can connect and Ipod without extra gear. Here is a link to some of the accessories that you can hook up to it:
http://www.crutchfield.com/p_113MP228/Kenwood-KDC-MP228.html?tp=5684&tab=other_items
If It was me, I would just spend the money on a stereo with a usb port. Then you can connect your Ipod directly to the cd player and operate your Ipod playlist with the cd player itself. Plug it in throw your Ipod in a cubby hole and use the cd player.
Aug 03, 2009 | Kenwood KDC-MP228 CD Player
How do you play your ipod with DEH-P49001B system.
Two options.
1. To play AND control your iPod from this system, you need to purchase a separate cable. Model is CD-I200 and it plugs into the back of the unit and the other end plugs into the dock connector of your iPod. (Assuming your iPod has a dock connector)
2. To play your iPod only through the system use the AUX1 mini stereo connector. Unfourtunately the AUX1 input is located on the rear of the unit. You need a separate cable with a mini plug on both ends. (Will look like a headphone plug on both ends). You will probably have to pull out the system to be able to plug in the cable unless you are lucky and you have tons of room under your dash to be able to reach the rear of the unit. Make sure you get a cable that is long enough to reach from under your dash to where you want to keep your iPod in reach.
Jul 23, 2009 | Pioneer DEH-P5200 CD Player
Speaker cuts out when ipod is hooked up to audio in port
try isolating the problem by inserting other sources such as tape deck, portable cd players, game consoles, if they work fine, test you ipod cable. next test you ipod on other audio in ports such as karaoke or other component stereos, ask a friend if he or she has one. test both, you may now have the idea where the trouble is.
Jul 10, 2009 | Teac AG-V2050
Help with ipod connection to cd player
You must use 1 of 3 methods to connect your iPod
1. FM modulator to wirelessly broadcast on a low FM band
2. iPod 3.5mm male/male direct connect cable.
3. iPod USB connection - with Pioneer iPod adapter module.
The direct connect 3.5mm port is on the back of the unit. One plugs into the radio - one plugs into the iPod headphone port.
Click HERE for your owners manual in PDF format.
CLICK HERE for the installation manual
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 13, 2009 | Pioneer DEH-400UB Car CD/ MP3 Player
Connectiong ipod to panasoninc df200u
the df200u is a old unit it can not be done , you can hook up a cd changer to it thats all .. cd changer model cx-dp880
Feb 26, 2009 | Panasonic CQ-DF200U CD Player
Ipod
On the Kenwood models that are within about 6 or 7 years old or newer, there is an iPod adapter for the head units that plugs into the CD Changer port on the back of the radio. Kenwood makes an adapter (KCA-IP500) that gives direct control and charging through the radio and several companies make aux input adapters for Kenwood radios that will connect to the iPod's headphone jack.
Sep 21, 2008 | Kenwood KDC-3024 CD Player
Ipod?
There is no IP-BUS plug on the back of this model radio, nor is there a 3.5mm heaphone jack for auxillary input. The only way possible is through a wired FM Modulator.
My suggestion would be to replace the head unit. This model is a very inexpensive unit ($100retail) and can be replaced with a unit that is similar in features but with the addition of ipod input. You can get a radio with direct ipod control and charging for less than $150! Hope this was helpful.
Jun 07, 2008 | Pioneer DEH-1800 CD Player
Ipod connection
As far as iPod connections - they will work with a regular iPod and an iPod Nano. You have two options depending on how much you want to spend and how much convenience you want.
Option 1 - Use a Pioneer CD-IB100 adapter. This will plug into the docking port on the bottom of the IPod, charge it, offer control and song information on the head unit. You need to use this one and not the newer CD-I200 cable because your head unit is not compatible with the newer piece.
Option 2 - Use a Pioneer CD-RB10 adapter and a 3.5mm to RCA cable that will plug into the headphone jack of the iPod. You will only get audio input to the head unit but this option is somewhat cheaper.
As far as the clock settings - hold the 'source' button to shut the unit off(key still has to be on). Push the 'function' button until options appear - you can switch between options by repeatedly pushing the 'function' button and adjust settings by using the up/down/left/right arrows.
Dec 29, 2007 | Pioneer DEH-P6800MP CD Player
Help
Hi, Normally, your JVC Car Stereo will not allow direct connection to an Apple iPod. However, there are several aftermarket interface adaptor that will allow you to do so: 1. Connect the iPod to a JVC KS-PD100 which in turn is connected to the CD changer jack of the KD-G720 (rear of the unit). Set the stereo to CD changer external input setting and you're ready to go; 2. Connect the iPod to an FM Transmitter such as the Griffin iTrip (w/ Dock connector) which in turn will broadcast the IPod music as an FM signal. Operating the KD-G720 on FM radio setting will receive the IPod's broadcast music. Hope this be of some help to you. Pls post again how things turn up. Good luck and kind regards.
Aug 01, 2007 | JVC KD-G720 CD Player
Brookstone Slim Profile CD System V4.0 Shelf System Logo
497 people viewed this question
Top Brookstone Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
