Lamona Integrated Washing Machine 1200rpm manual needed
blueextc3221
  • 15935 Answers
SOURCE: I am looking for a user manual for a Servis wahicg
CLICK HERE
http://www.miaudioaddiction.com/fixya/manual.pdf
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Posted on Sep 16, 2010
  • 89 Answers
SOURCE: Whirlpool AWOE 9559B 1200rpm 6th
Morning, Your model number does not come up. It is located on a front loader behind the door, top loader under the lid. GE right side at front bottom of case. Will await your answer. Thanks
Posted on Jan 23, 2011
  • 6277 Answers
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
(this is my standard reply but I've just followed my own advice and found this!
http://www.inter-spares.co.uk/howden/howden-washing-machine/hja8703/instruction-manual-1-2-3-4-5-6-7-8-9-10-11-12&usg=AFQjCNHicY59t2EHXq15qkInEBscfeGeZw)
Posted on Jun 19, 2011
  • 6277 Answers
SOURCE: Lamona Washing Machine HJA 8514 Half way through a
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
Posted on Jul 27, 2011
SOURCE: My Lamona integrated washing machine
Hi Guys,
My Lamona washing machine is also stuck on rapid wash? Dis you get it resolved?
Kind Regards
Posted on Sep 02, 2011
I have a Lamona HJA8514 intergrated washing machine and I cannot find the filter to clean it. Can't see it on manual either
the only filter some washing machines have is at the water supply where hoses hook up.if front load some were right inside door at bottom hope this helps
Feb 12, 2015 | Washing Machines
How do we check the filter for Lamona washing machine
https://www.howdens.com/appliance-collection/laundry/integrated-washing-machines/1400rpm-integrated-washing-machine/
i found this one as your model detail is missing
i think you need to remove the kick board if its a built type kitchen inset washer to gain access
on the above site is the manuals for the other models they make
in this range
what is the error you have
or do you just want too know???
Dec 19, 2014 | Washing Machines
Lamona hja 8514
You have an internal pump which is not accessible without uninstalling the appliance, however instead of using drain block have you tried a proper appliance cleaner and cleaning the connection under the sink as this is where most smells come from and not the machine themselves
Apr 07, 2014 | Washing Machines
Lamona hja 8553
Unfortunately Lamonoa doesnt make washing machines. Its a wood fitting company that uses various machines. They reccomend this manual
http://pdfsb.net/readonline/5a6c4244656739355758422b436e6c6a55554d3d
for the 8553.
You have to read online..through the pdf
Mar 20, 2014 | Washing Machines
My Bosch machine is not spinning properly leaving my washing still really wet. Tried cleaning pump once before and it worked but it's not worked this time round. At 1200rpm the cycle is really s
Bosch machine is not spinning properly leaving my washing still really wet This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jun 21, 2012 | Washing Machines
Lamona HJA8553 Washing Machine door release has suddenly stopped working!! Is there an emergency door release to get my wet washing out??? tried turning off at the wall in hope of resetting the machine...
My Lamona integrated washing machine HJA 8553 has a nasty smell coming from it like an old damp mop its making the whole of the house smell any ideas why
Jun 30, 2011 | Washing Machines
I am looking for a copy of the user manual for the Lamona Integrated Washer Dryer model number HJA8704 but am struggling to find it online. Would you be able to help please?
John C.
Jun 19, 2011 | Washing Machines
Washing Machines Logo
717 people viewed this question
Top Washing Machines Experts
