When heater is switch on, it glows at one side and continually glows on and off, is it broken?
  • Anonymous Mar 24, 2011
    Hi Gas, it is a dimplex 2kw convector heater, not sure of the name, but it's the metal bar inside the heater that is only lighting up when switched on. It then continually goes off and on.
    Brigadier General:
  • 4,736 Answers
Is it the ignitor glowing or the heater's ceramic plaques? Also knowing who the manufacturer is and the model number, will be a big help in answering your question.
Posted on Mar 23, 2011
  • Rich Landrum Mar 25, 2011
    It's the heating element, hosco. But, I don't believe it should constantly be cycling ON & OFF, when the thermostat is not calling for heat, but the unit is ON. I tried to locate the Owners Manual, but without a Model Number, I'd be scrolling through mu computer all night. I suggest you contact Dimplex USA, Technical Service at 888-346-7539 to see what they have to say. You'll need have your Model Number, handy when you call. Trust me, it's on the heater somewhere.
    Hope this helps get an answer to your question. Please be kind enough to rate my response to you. Thanks!
Electric furnace fan works heater does not
coil could be broken. open the cover hold the door switch and look to see if the coil glows when the heater is turned on if not turn off the power then remove the coil then turn on the power and check the voltage you should get 210V A/C on a meeter if you do or yo can do this firs, check for continuity on the coil if you get continuity then check for voltage. if no voltage check the breakers or check the breakers first the electric heater needs two breaker if one is tripped you could have a blower and no heat.
Oct 08, 2014 | Coleman Home Electric Furnace Eb15b/Eb15d
Heater wont ignite
make sure you have 24 volts ac on both sides of pressure switch if not see if fusible link is ok 24 on both sides ok see if ignitor glows when heater is turned on if it doesn't glow need new ignitor
Jan 10, 2014 | Jandy Pool & Spa
Dryer blowing cold air . No heat!
Check the "Bias thermostat" for continuity with a multimeter. IF it is bad, replace with this part.
Nov 29, 2010 | GE DBXR463EDWW Electric Dryer
Automatic gas shutdown light comes on. replaced ignitor that was not glowing. worked friday. today troubleshooted new ignitor is fine. replaced ignition control box. still no power (voltage) going to...
This sounds like your fan prover (air switch)
check switch continuity, and air switch tubing.
Replace if neccessary.
Sometimes these vinyl air tubes just melt
Nov 01, 2010 | Jandy Laars Lt 250,000 Btu Heater
Some times the heater works and some times it doesn't.
You most likely have a bad heater. Sometimes the broken heating element will make contact until the machine vibrations disturb it. A faulty thermostat could also cause this symptom.
Try to check for the problem when the heater is not working.
Unplug the machine! Check the heater for continuity with a multimeter. If it does not have continuity, replace it. If it does have continuity, I recommend that you also remove the heater and carefully look to see if the heater coil is broken, but touching at the break.
If the heater is good, the operating thermostat may be turning the heater off too soon.
Other failures can also keep the heater from working: temperature switch, timer, centrifugal switch, etc.
Apr 29, 2010 | Whirlpool LER4634J Electric Dryer
No blinks normal running igniter glows gas comes on wont run
Check for 24 volts across the gas valve when Ignitor is glowing. If no, bad board. If yes, bad gas valve or blockage.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Mar 05, 2010 | Goodman GMS90703BXA Heater
I have a Trane xe 70. The Heat is not turning on. The ignitor will glow but NO gas or blower. I turn on the fan and the blower does work but not when HEAT is selected on the t-stat. Also the LED light...
Check to see if you get 24 volts AC at the gas valve from the circuit board when the igniter is glowing. If yes, bad gas valve or blockage in gas train. If no, bad circuit board or broken wire
Feb 07, 2010 | Heating & Cooling
Heater will not kick on....buzzing sound. Took
You will find an error code chart on the wiring diagram pasted to the reverse side of one of the panels. It will help you to know where to start looking for the issue. I am also sending you the sequence of operation to give you a few more pointers, read on.
Dec 03, 2009 | Goodman GMS90703BXA Heater
Dryer will not get hot.
There is a glow bar that ignites the burner. The glow bar probably needs replacing, check it with an ohm meter, usually you can see if the glow bar is broken because it is ceramic and is usually broken. Be carefull when replacing the new one not to touch the part that glows
Jan 09, 2009 | Roper REX4634KQ Electric Dryer
Heater will not light off
Be sure filter not dirty or too old lack of flo can cause tripping of high heat switch check flo switch also always check simple things 1st traceace
Dec 20, 2008 | Jandy Laars Lite2 Ld 400,000 Btu Heater
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
