Question about Vacuums
KitchenAird KSM 500 stopped because of heavy flour. Wife restarted it and it makes a metallic noise and then stops. My search indicates it might be worm gear. Any suggestions. I live in No. VA--any sugestions for small appliance repair places..
  • ibyke Mar 23, 2011
    The mixer does work once my wife cleared the up the mixing bowl. I ran it for about 10 seconds but turned it off for fear of further damage. Isn't it likely to be the sorm gear since it's designed to fail to save the metal gears?
  • ibyke Mar 29, 2011
    Your solution was incorrect. Using a video on you tube for guidance, I replaced the worm gear and the mixer works perfectly. I used parts readily available to retail customers for a job that wasn't complex. It took me almost 2 hours because of a couple of solvable obstacles and because I keep reviewing the video.
  • Vacuums Master
  • 11,800 Answers
Yes, most likely the gears have been stripped, they will have to be replaced. This is a complex job and the parts aren't available to retail customers - they will have to be specially ordered. It's better to take the unit to a repair shop.
The only certified service shop in Virginia is
Hobart Sales-John L. Nelson Jr. Inc.
1739 Kelly Road
Richmond, VA 23230
Phone: 804-353-1275
Fax: 804-358-6926
You might find that the one from Maryland is closer
Waters Appliance Service
216 E. Diamond Ave
Gaithersburg, MD 20877
Phone: 301-258-7500
Toll Free: 800-225-5009
Fax: 301-869-3118
Posted on Mar 23, 2011
  • Azrael SRL Mar 23, 2011
    No, there are no sacrificial parts inside it. Actually there are just 5 rotating parts: the rotor of the electrical motor with the worm screw machined in it, the worm gear with the planetary shaft attached to it, the planetary gear and the tool shaft attached to it. So either one of the gears was stripped or one of the bearings got deformed. Either way it must be replaced.
Where does a cylindrical metalsilver bearing go?
usually the pin roller you have found is one of many found inside a bearing race called a roller bearing.as it was hot and alone, it shows that the shell has collapsed.all the other pins have tangled up inside the shell,stopping the brush from rotating.it is unusual for these parts to be repaired , depending on the make and value of the appliance. cost effectiveness is the primary issue.
Apr 17, 2016 | Dyson Vacuums
My Dyson D17 Animal vac makes a buzzing noise when the belt turns. I took the belt off and turned the small metal gear that turns the belt. That is what is making the slight noise. My wife vacuumed the...
Try not to **** up any more water. Don't use until you can dry it out well. Hopefully you live in a warm climate so that will happen sooner than later.
Sep 23, 2013 | Vacuums
Stopped working
This is a problem with your carbon brushes, remove old brushes, and check they have not become jammed in there brass sleaves, they are spring loaded.
If they are not jammed but less than 20mm new brushes are required, available from most good vacuum stores.
Before purchasing spin the motor, and feel that the copper commutator, where the brushes contact with, is not buckled (not even slightly)
NB Buy genuine Numatic they go back in better.
Independent Experts
Jul 15, 2013 | Numatics Numatic Harry Canister Vacuum
Rumba making Clicking noises - stops It has been cleaned.
even if the 2 brush rollers are clean you need to pull the small yellow ends of the roller off [the funny lookin ones].hair ect. get jamed in there .use a knife or small screw driver to pull the build up out.hope this helps
Jul 13, 2010 | iRobot 53501 Roomba 500 Series Vacuum...
When in carpet mode, brushes seem to be hitting something. Brushes cleaned - how to stop making the awful noise
LOL do you mean when you move the vacuum forward (say into a baseboard)? it makes the loud shocking noise.. i hate that too.. but that's the crazy Warning sound indicating something is stuck (like you sucked up an area rug) or you have run into something and it set off a sensor.
Mar 26, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Sometimes while I'm vacuuming, the front of the vacuum makes a horrible noise. If I lift up the front end, it stops. Any ideas?
I just cleaned the small metal drive gear inside the brush housing. That solved my problem. It seems that some junk can build up in the drive gear which makes the belt slip on the gear. That is horrible noise you are hearing.
Mar 21, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
Floormate noise
The motor sounds bad. Use the Hoover web site to locate a shop near you for warranty repair. hoover.com
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_b96ba3f038cf317c
Oct 09, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Electrolux Canister - Stops working after 1-2 minutes.
Electrolux Canister - Stops working after 1-2...
Our vac works for a short time, then shuts off and makes clicking noise as if trying to restart again. Works after cooling for a while but for another very short time. Your suggestion on fix would be greatly appreciated.
Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure
I would advise that it could be a thermal switch or a regular switch that the thermal switch is over heating and needs replacement – there are small hoses in the door section that could have been pinched or kinked and it stopping the air flow from the vacuum – also check for a clogged or plugged vacuum hose, a full vacuum bag or a dirty vacuum filter. Check the thermal switch or reg switch or the hoses in the door. Or feel free to contact your local vacuum dealer in your area or in the yellow pages, or call the factory @ the phone number listed below:
http://electrolux.com Customer Service
Electrolux Home Care Products – North America
PO Box 3900 Peoria, IL 61612
1-800-896-9756
Don – The Vac Man
Apr 21, 2008 | Electrolux Guardian Bagged Canister Vacuum
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
