SOURCE: Error 5800: waste ink
Clean or replace the absorber and reset the printer counter to clear the message.
SOURCE: Waste ink absorber on canon iP 1600
I tried a few times... I have done this alot to many different canon printers. This is what worked for me.
1. Unplug AC (and usb just for good measure)
2. Hold Start while plugging in...
3. While still holding Start press Resume twice.
4. This then allows for Removal of Ink Cartridges(if you are past the limit)... a very important step apparently.
5. Now repeat Step 1... Step 2
6. Now press the Resume 4 times (only blinks for 1st two presses !)
7. Should be ready...
Good luck. I was very happy when this worked for me.
B's
SOURCE: Ink absorber full Canon MP210
(11/24)
<Service mode operation procedures>
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
(11/24)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print See APPENDIX 1:
SHIPMENT INSPECTION
PATTERN 1: PRINT
SAMPLE
2 times Green EEPROM print See APPENDIX 2:
EEPROM INFORMATION
PRINT
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
(12/24)
<Destination setting procedures>
At Logic board replacement, make settings for each destination.
button pressing
LED Destination Paper for defaulte setting
0 time Green No change
1 time Orange Japan A4
2 times Green Korea A4
3 times Orange US/Canada Letter
4 times Green Europe A4
5 times Orange Australia A4
6 or more times Returns to a menu selection A4
<Waste ink counter reset procedures>
At the waste ink absorber replacement, reset the waste ink counter for the replaced waste ink absorber.
Setting operation for the waste ink counter (The counter setting value is selected by pressing the Reset button.)
The number of the Reset button
pressing
LED
0 time Green Reset the main waste ink counter to 0%.
1 time Orange Reset the platen waste ink counter to 0%.
2 times Green Reset the Main & platen waste ink counter to 0%. (Reset
collectively.)
<Button / LCD checking operation procedures>
At Operation panel unit replacement, check the button / LCD.
1. When pressing the Stop button two times, the machine will be moved into an LED confirmation mode.
2. As often as the Color button is pressed one time, each LED is lit one by one, and the machine get in the mode in which each
button is acceptable.
3. As often as each buttons on the panel is pressed from the left to the right, the displayed number is counted up.
Pressed button Display
Maintenance 1
Fit to Page 2
SCAN 3
Paper size 4
+ 5
Black 6
Color 7
Stop / Reset 8
On / Off 9
4. When all buttons are pressed, [1] will be displayed. Then, LED[8.5 x 11 Plain Paper] and LED[8.5 x 11 Photo Paper] will be lit on
the panel, and the machine will be in a service mode menu selection mode.
SOURCE: ink absorber full
This is a very common problems with canon printers. They are set for a certain number of prints and they need the ink absorber serviced. Now along with resetting the printer its best to replace the absorber. Here is link to site that has reset instructions.
http://ij-forum.blogspot.com/2008/08/reset-waste-ink-absorber-error-waste.html
Thanks,
Lee
SOURCE: canon ip 1300 ink absorber is full. how to empty
is there a program that can disable the waste pad ink full? just like ssc utility for epson c45?
There are two possible ways to remove the error from your printer. First is to actually clean the absorber pads that are full of waste ink. The second is to reset the printer to clear the error and let the printer print again.
Clean the two absorber pads. There are actually two absorber pads located on the right side of the printer, under the ink cartridges when the carrier is in the home position.
Accessing the pads and remove them for cleaning?
Turn on the printer. Lift the top cover to expose the ink cartridges. As soon as you lift up the cover the cartridge carrier will move away from its home base. Then the pads will be exposed. It will be a dirty job so be prepared with your tweezers and extra cloth for some ink spillage. Using the tweezers, lift up the pads sitting on the rubber retainer. The pads can be easily clean by placing them under running water. Use warm water to remove the ink from the pads. Dry the pads and reinstall them. Same procedure if you are installing new pads.
However, the problem will not be solve especially if you are currently facing the waste ink absorber full error or E-27.
Reset Waste Ink Counter Canon Pixma MP210 and Canon Pixma MP220
1. Start with printer off
2. Press and hold resume Button (triangle in the circle) and click "Power" button. green led should be on
3. hold the Power button, release Resume Button.
4. Without releasing the Power Button, double click "Resume" button and then release Both Buttons.
5. Click "Resume" for four times then click "Power" button, to confirm the selected action (reset counter absorber).
6. Turn off the printer and turn on again
7.
Please rate this solution. Let me know if you have any more questions. Thanks.
