Global mark 2 error 53 and 55 put in new tape but still the same error
My bike is running really rich and keeps fouling out the plugs. Whats the problem with my bike??
Dirty air filter is the most likely cause. Will your bike run leaner with air filter removed? DId you recently move to a different elevation? air fuel ratio needs adjustments in that case. Have you recently installed aftermarket intake or exhaust components? if so the air / fuel ratio adjustment is also required. To check for leaner running with air filter removed, you should buy some new spark plugs so you can see condition of plug correctly on the new plugs. First run the bike at 1/4 throttle for 15 minutes and remove plug and inspect. install new plug and repeat test for 1/2 throttle, 3/4 throttle, and full throttle, replacing the plug prior to each run. The throttle positions can be marked off with white tape and black tick-marks. you will put a white piece of tape on your rotating throttle with a single black tick mark and then you will take a second piece of tape on the stationary part of oyur handle bar and put a mark for 0 and full , then half, 1/4 and 3/4. these marks will help you maintain postion during the tests. The plug conditoin will reveal which fuel circuit you should address for your fouled plugs.
Jan 12, 2011 | 2004 Suzuki VL 800 Volusia
When I am attempting to sign in to AOL I get the following messg:
1.force the global DNS. ( start - run - ncpl.cpl - right click on LAN- propertys - double click on internet protocol TCP/IP ,if its vista IPV4 - put a check mark in use the following dns, enter alternate dns as 4.2.2.1 and prefered DNS as 4.2.2.2 . )
2. perform browser reset by TOOLS- internet options - advanced - reset.
3.TOOLS- internet options - connections - lansettings - uncheck all the options.
4.uninstall norton if you have.
Jul 01, 2009 | Microsoft Internet Explorer 8
Error 1 message
Check the batteries and that there is nothing clogging up the tape area. Any little bit of tape can cause the error message to come up. Also if you put in say 4 new batteries and kept 2 older ones that show a little life still left, can cause the error message. Change all the batteries at the same time.
May 07, 2009 | Dymo LetraTAG Thermal Label Printer
TYPING II IN PLACE OF LETTERS
the mark you are seeing is the print hammer hitting the paper. remove the ribbon. corr. tape & print wheel. turn on the typewriter. close cover let it home it's self. open cover put in print wheel. close cover let it nome. put in ribbon close cover. try typing if marks are still ther. you will need a new print wheel. if working then put in corr. tape or if you are better at spelling then me you will not need it
Jan 21, 2009 | Smith Corona Wordsmith 200 Typewriter
Sylvania srd3900 error 2
Found no info in manual but cleaned tape heads and able to watch tapes. I don't know if this completely fixed problem because tape watched was not best quality.
Nov 30, 2008 | Sylvania SRD3900 DVD Player/VCR
Changed color cartridge and getting error
I had the same problem with my X8300 printer. As the printer was less than a year old Lexmark sent me a new printer. I will keep this printer until it to goes wrong and then buy another brand. Lexmark - cheap and nasty, I am afraid.
Ivanhoe.
Nov 13, 2008 | Lexmark X5495 Printer
Error on :Lexmark x6180
did you remove the tape that is on the cartridge. look at the area touch the paper path, see if there is orange or red tape on the cartidge. pull it out and insert the cartridge again. it should work
if the answer solve your porblem. please rate the answer.
thank you
Oct 14, 2008 | Lexmark X6180 Printer
Error 0F0100030C099F on hp5000
found this maybe can help i dont know
I tried the fix of :
This may be an error finding the mark encoder. The mark encoder is the
white plastic piece on the left end of the roller. Replace the lense cover
first. If the error remains, turn the printer off, and place a piece if black
tape over the hole at the left end of the drive roller, this will block the
mark encoder from the line sensor and should trigger a 010092 error during
power on. When the 010092 error comes up,
press enter to continue past the error. After the printer comes ready, remove
the tape, and run a scan axis calibration.
To run the Scan Axis Calibration:
1. Enter "Device Setup".
2. Enter "Utilities".
3. Press the UP arrow and ENTER keys simultaniously,
4. Select "Yes".
5. Enter "Service Calibrations".
6. Run the "Scan Axis Calibration".
May 30, 2008 | HP DesignJet 5500PS InkJet Printer
Tape drive does not recognize or eject tape
Yeah the Ultrium 4 tape drives only r/w to ULT3 and ULT4 tapes.
We put a Ultrium 2 tape in our 4 drive and it seems to be locked permanently.
Oct 26, 2007 | HP C7438A (Refurbished) DAT Tape Drive
SONY LIB-81 Error on LCD screen - Drive Information 51
I think this sounds like the drive is having a issue loading and moving the tape in slot 1.
AIT units are known for having this kind of problem.
Try a cleaning tape and then a new tape fresh out the wrapper for a test backup.
if it fails with a known good tape then its time to send it out for repair
www.tape-drive-repair.com
Tape-Techie
Jul 26, 2007 | Sony (LIB81A3BB) AIT-3 Tape Drive
73 people viewed this question
k24674
jasbo
jasbo
