Question about Motorola Mobility ic902 Cellular Phone
Direct connect does not work it comes up '' no service'' some days it will work for about 10 minutes
  • 492 Answers
Call Sprint/Nextel customer care. They may be able to get you back into the system by doing a master reset. Have the phone in hand and call on your home or business phone. If that doesn't work find the nearest service center and call. The will explain your repair options. Often the tech can either repair or exchange on the spot (given an hour or two, my shop got very busy). Please be patient with the techs, they know the phone is important but have to focus on one thing at a time. Regards, Don T.
Posted on Mar 23, 2011
Blower Motor on 2000 Saturn SL
The blower motor is connected to a termic switch, when the motor is fine and fuse is ok, is the switch that must be replaced.
Ensure the fuse is ok first.
Oct 02, 2008 | 2002 Ford Crown Victoria
Unit is shutting down after ten min
My unit never got to the point of actually shutting down due to overheating, but your problem may be related to what I experienced: A bent lamp heat shield.
My Optoma EP739 started exhibiting color-banding and strong color shift after years of great service. After trying other suggestions that didn't work, here is the FIX for my unit. I have not seen this posted anywhere else.
Problem: After 10-20 minutes of use, color-banding and then a strong shift to purple/green with almost no red. If the unit is turned off for 5-10 minutes to cool and then powered-up again the problem goes away, only to come back in another 10-20 minutes. Enabling the "High Altitude" setting in the Setup Menu helped for a while (a week or two) since it forces the main cooling fan run at high speed always, but then the problem re-appeared.
Reason: Overheating. The electronics are overheating. Like several people have suggested: First step: Open the unit up and blow-out/vacuum all of the accumulated dust. Assure BOTH fans (there is a small drum blower directly cooling the lamp and a larger regular fan that circulates air through the entire unit) are operating and clear of debris.
Once you have done that, then look for the REAL issue. With the front panel (i.e.the panel with the hole for the lens) removed and looking into the projector from the front examine the metal heat shield on the right side above the lamp. In my unit, because of years of service and heat, the aluminum lamp housing had deformed slightly, tilting this sheet metal heat shield directly INTO the air stream from the fan. This restricts the airflow enough to reduce cooling capacity. This metal shield should be high enough above the lamp to be TOUCHING the plastic case. If it is bent down and is halfway into the air stream then it restricting the exhaust airflow, causing the overheating.
Fix: Bend the heat shield back up so that it is not in the exhaust airflow. It must be ABOVE the airflow, protecting the plastic case from the heat of the lamp. This simple remedy fixed the issue for me. My projector has been running 2-3 hours a day for 10 days now with no banding issues at all. That's it. Simple fix.
Feb 01, 2013 | Optoma EP739 Multimedia Projector
TV will not come on, LED light flashes 10 times, then pauses, then repeats Sony Model KDP 57ws655
Try connecting the TV directly to a different wall outlet and check. If the issue persists, try power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue persists, then the TV requires service.
Jul 21, 2010 | Sony Grand WEGA KDP-57WS655 57" Rear...
My compressor suddenly quit cycling what went wrong?
hi there!
there are several factor on cycling failure, most common on it is the pressure switch device,checking on this,plug out or switch off main circuit breaker for compressor, disconnect pressure switch if this is a single phase connection,there are two supply wire coming in and two wire coming out on pressure switch.direct connection of compressor motor on power supply to test if it is cycling manually,after direct connection of motor compressor to power supply w/out pressure switch,switch on for 5 to 10 minutes o build a low [pressure then swict off again,then switch on again even there is a low pressure observe if there is cycling motor running if this done replace pressure switch.if still have same problem motor tripping another case not to cycle bring this to electric motor service center.have a nice day dont forget to fix my rate.
May 07, 2010 | Campbell Hausfeld 04 Gallon Twin Stack...
I replaced the oxygen sensor (post-cat) on my S-10, 2000 truck. The service light remains on. What gives?
Did you wait a few days (assuming you drive it each day?)
Still on? Disconnect the battery for a 30 minutes. If it comes back on go to Autozone and get a free code read and google the code they print out for you.
Mar 02, 2010 | 2000 Chevrolet S-10
Insignia TV model NS-LCD19. TV shuts off
Unfortunately your TV will need to be serviced. You may take the unit back to the retailer of purchase to arrange for repairs.
Sep 17, 2009 | Insignia IS-LCDTV32 32 in. Television
I can't connect to sky golf to purchase a membership. I get to direct connect, and it says retry over and over without connecting. HELP!
Don't purchase the membership...the new software is a nightmare. My unit is now frozen just before a 10 day trip to Hawaii. All my home courses are gone and I can't download or connect. Wait 30 min on hold for customer service, message says "new software release is causing unusual delays".....(how about adding some more customer service people prior to the release)?
This is a good product when it works, but frustrating when down. GPS needs reset continually.
Feb 11, 2009 | SkyGolf SkyCaddie Handheld GPS Unit
Wii console will not come on
First things first. We'll start from the beginning. Unplug the AC Adapter from the wall and from the Wii. Let it sit for 15 minutes. Then plug it back in. 9 times out of 10 your power supply needs to be reset. The only way to reset it is to unplug it from the wall and the wii and let it sit for 15 min. Try this first and report back if it worked. Even if you think you have done this already do it again.
Apr 09, 2008 | Nintendo Wii Console
Motorola Mobility ic902 Cellular Phone Logo
49 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
