Question about Dell A940 All-In-One InkJet Printer
Will not print
The printer message says to unlock the scanner and then the power button. I have no idea how to unlock the scanner.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Is this a new printer?
Posted on Aug 19, 2008
I am trying to print and I am getting the message saying unlock the scanner? How do I unlock the scanner?
where you get the fax print out there is a blue botton, you have to swich that to unlock.
Feb 24, 2011 | Dell 1815dn All-In-One Laser Printer
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
HP Photosmart C4180 message "Scanner
Try resetting the printer:
Reset the printer
-Disconnect the Universal Serial Bus (USB) cable from the back of the printer, but leave the printer turned on.
-Open the cover of the printer and remove the print cartridges.
-Close the cover and wait for the Insert Ink Cartridges message.
-Disconnect the power cord from the back of the printer and wait for one minute.
-Reconnect the power cord. If the printer does not automatically turn on, press the Power button.
-Open the cover and reinsert the print cartridges.
-Close the cover. If prompted, print a calibration page.
-Reconnect the USB cable, and try to print a print job from the computer.
Hope that helps!
Feb 07, 2011 | HP Photosmart C4180 All-In-One InkJet...
MFP 1815 D Unlock Scanner message
Inside the print tray (where the paper comes out) on the upper right there is a blue lever. Pull it toward you and that will unlock the scanner. I just did this and restarted my printer and it worked! Hope this helps!
Jul 13, 2009 | Dell 1815dn All-In-One Laser Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
CANON PIXMA MP830 Error Msg: Scanner not working correctly.
the error message: "Scanner is not operating correctly." The scanner is definitely unlocked.
Nov 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Lexmark x5150 scanner locked
The scanner is locked. to unlock it
1. Press Power to turn the All-in-one off.
2. lift the scanner unit until the scanner support holds it. To the left and beside the scanner support is the scanner lock
3.pull the scanner lock toward you to unlock the scanner.
4. close the scanner lid.
5. power on.
Feb 19, 2008 | Lexmark X5150 All-In-One InkJet Printer
Dell A940 - Unlock Scanner then press power
See
http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Dec 08, 2007 | Dell A940 All-In-One InkJet Printer
Dell A940 All-In-One InkJet Printer Logo
52 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
