Question about Zanussi ZBF360X Electric Single Oven
How do you access and Replace Mains Indicator light / bulb for Oven
    President:
  • 1,140 Answers
Hello Ivor,
I assume you're referring to the small neon mains indicator on the fascia panel rather than the internal light in the oven. To replace this, you have to pull the oven forward to gain access to the rear of the control panel from above.
The wiring at the rear of the control panel is live even when the oven is switched off. Please switch off the oven at the wall and/or the 30amp fuse in your consumer unit before attempting any service or repair on your oven.
1. Remove the four retaining screws ringed in red in the diagram below. These are only visible with the door open. Pull the oven forward about 8-10 inches. The oven is front-heavy due to the weight of the glass door and has a tendency to topple forwards, so either remove the door (lock the hinges and lift it out) or place something under the front of the oven to support it.
2. Unscrew the coloured lens for the mains indicator light on the fascia panel. This is difficult to grip and a bit tricky to remove, but unscrews anti-clockwise. You can now pull the main body of the indicator light through to the rear. You may need to wiggle it around a little to get it through the hole in the oven panel.
3. Disconnect the 2 wires from the terminals on the indicator light. Attach the wires to the new light, feed it back through the hole and hold it steady at the back while you screw the lens on at the front.
4. Push the oven back in, insert the four retaining screws and tighten them fully.
If you can't see the switches and wiring immediately when pulling the oven forward, there will be a removable access panel covering the front portion of the top of the oven. This either unclips or has a couple of retaining screws - I can't remember which on this model, but it will be obvious once you pull the oven forward.
Hope this helps. If you get stuck or need further assistance, please let me know by clicking on "Add a Comment" below your question.
Regards,
BElectric
Posted on Mar 23, 2011
  • DILLIGAF
    DILLIGAF Mar 23, 2011
    Sorry, I remembered after posting that you may need to remove the fascia/control panel as well to remove the indicator light. I recall there is a flange on the body of the indicator light which is trapped between the fascia and the front panel of the oven body.
    All of the other instructions still apply except the indicator light pulls out forward after removing the fascia panel.
    To remove the fascia panel:
    1. Remove the 2 control knobs and the timer/clock buttons ringed in blue. These simply pull off.
    2. Unscrew the lenses from both indicator lights ringed in green (see previous message).
    3. Remove the 3 screws securing the fascia panel to the oven. These are accessed from behind the panel so this needs to be done with the oven already pulled forward. There should be one at each side and one top-centre.
    When re-attaching the fascia panel, you will need to make some minor adjustments to the position of the panel so it lines up correctly. To do this, insert the three screws, but leave them loose. Align the fascia correctly with the left and right sides of the oven door and semi-tighten the top screw. Next, lift the left or right side of the fascia until the gap between the fascia and oven door is equal all the way along, tighten the screw on that side, while holding the panel in position, then tighten the other 2 screws.
    I should also mention that replacing the indicator light/s is not done by replacing the "bulb". You have to buy the whole neon indicator assembly. These cost about £15 and you should have this ready starting the repair. If required, I can provide the part number and supplier details, but it would help if you could let me know your location.
    Hopefully, I've covered everything. Please let me know if you have any questions or need further assistance before or during the repair.
    Regards,
    BElectric
Bottom oven lights keep burning out.
The oven bulb is different from an appliance bulb. The glass and base are specific for the high temperature application that is seen in a oven
The link from sears shows a sample of an oven bulb and the price represents the special characteristics.
I have seen where some bulbs are rated at 130 volts?
Range Oven Light Bulb Part Number 316538901 SAME DAY SHIP GUARANTEE from...
This link from Amazon relays some of the one star reviews of the appliance light used in the oven application. All ovens are maybe not equal where the heat may be more significant in one make over another.
Amazon com Customer Reviews GE Appliance 21188 40 Watt 415 Lumen A15 Light...
Another set of reviews that again show problems in some applications for bulb life.
40 Watt Incandescent A15 Clear Appliance Light Bulb 416768 The Home Depot
Not many reviews on this bulb. The 130 volt rating is an indicator of longer life? Of the choices I wood choose the following.
Sorry I couldn't help you more. Disappointing that no bulb stands out as the very best.
Bulbrite B40A15C 130V 40 Watt Incandescent A15 Appliance Bulb Clear Amazon...
Jan 09, 2016 | Ovens
Where is the light bulb in the main oven as I need to replace it
On my older Jenair, it is on the upper surface of the oven. It has a glass cover that would need to be removed to access the bulb.
Could be the switch or connections at the switch that is preventing the bulb from operating. Depending on age of oven and frequency of use of the light, oven bulbs last a long time. Mine is still good after 26 years!
May 07, 2015 | Ovens
How do I locate the fuse for Smeg oven sa9066xng?
The fuse is in the mains plug......but if you have the clock it won't be the fuse! The bulb has blown......replace bulb!
Nov 09, 2014 | Ovens
Built-in oven-- clock unresponsive
you have to push 2 of the buttons at the same time. usually - and + for 3 seconds. you will see the display change. good luck.
Jun 01, 2017 | Zanussi ZBF360 Electric Single Oven
Replace light in KEMC378KSS microwave
The oven lights are 12-volt, 5-watt maximum halogen bulbs. They
will come on when the oven door is opened. On double oven
models, both upper and lower lights will come on when either
door is opened. The oven lights will not work during the Self-
Cleaning cycle. When the oven door is closed, press OVEN
LIGHT to turn them on or off.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
Feb 04, 2013 | KitchenAid KEMC378KSS Electric Double Oven
It "popped" a circuit breaker
NORMALLY THERE ARE SCREWS TO REMOVE TO ACCESS A PANEL TO REMOVE THE LIGHT BULB. IF THERE ARE NOT, THEN THE EXTERIOR COVER MAY NEED TO BE REMOVED TO ACCESS THE LIGHT BULB. THIS EXTERIOR COVER HAS SCREWS.
MAKE SURE YOUR CIRCUIT BREAKER IS OFF BEFORE YOU TRY TO REPLACE THE BULB.
Feb 20, 2011 | Ovens
Main oven bulb changed now new one will not go out.
There is probably a problem with the oven switch. If you are careful, you can, after switching off the mains, remove the oven light switch, pull off the live terminal and insulate it. The turn on the oven mains again and see if the light still comes on. If it does, there is wiring problem. If it does not, the switch is faulty and needs to be replaced.
Feb 05, 2011 | AEG D5701-4 Electric Double Oven
How to replace oven light bulb for beko DC543 electric cooker
hi
You may need to remove the glass cover by turning it anti-clockwise.
On some models access to the bulb is from outside so the oven has to be slid out of it's housing and an access plate removed.
chek this following steps..
Step 1 Make sure the bulb is actually burned out. Confirm the oven is plugged in and that a circuit breaker is not tripped.
  • Step 2 Look for the manual to determine what size bulb is required. Most use a 40 watt appliance bulb. If you can not find the manual, then buy a bulb to replace it after you take out the old one.
  • Step 3 Confirm that the oven is not on. Allow it to cool to room temperature if it has recently been used.
  • Step 4 Open the door and use a flashlight to light the area where the bulb is located. Do not put weight on the door itself, but go in at an angle or sideways.
  • Step 5 Find the shield or cover over the bulb, gently pull or twist it off. Some glass covers are surrounded by a wire clip or a ring that is screwed in to the back.
  • Step 6 Gently remove either the wire clip or ring. Since the cover is most likely glass, be cautious. Unscrew the entire glass cover similar to a jar lid in older versions of ovens. Then repeat process if there is more than one bulb.
  • chek this usefull link
    http://www.espares.co.uk/advice/cookers-and-hobs/a/1/112/changing-your-oven-light-bulb.html
    hope u will b helpfull
    tnx for contactin fixya
    regards
    Jul 12, 2009 | Ovens
    Bottom oven not working
    If its brand new, most possibly the electrician did not bridge the mains connection. It sounds like an installation fault. There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection. Oshie
    Nov 27, 2006 | Gaggenau EB294/295 Electric Double Oven
    Zanussi ZBF360X Electric Single Oven Logo
    250 people viewed this question
    Top Zanussi Ovens Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Are you a Zanussi Oven Expert? Answer questions, earn points and help others
