Question about Techko SH4105PF Shredder
I have a techko SH4105PH shredder only runs in reverse wont work in forward what solution do you request or can it be fix and where can i take it to be repair thank you
5 Suggested Answers
fellowesrep
  • 102 Answers
SOURCE: Techko SH2106PA
your blades have either become dull or have spread due to a jam or a broken mount on cutter if your in warranty contact manufacturer if not time to buy a new machine.
Posted on Mar 02, 2008
fellowesrep
  • 102 Answers
SOURCE: Shredder not working
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
t_vinson57
  • 58 Answers
SOURCE: new gear drive cog needed for c505pz shredder please
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
badfrankie
  • 92 Answers
SOURCE: Shredder will run in reverse
Unplug the shredder. CAREFULLY clean out the shredding teeth and paper pathway. On some models you can loosen one end and open the paper path for better access. Ther is an acuator arm for a switch at one edge of the paper path and that will get clogged with paper and the arm cannot move to tell shrdder paper paper is in, ready to go. A blaast or two of canned air in the direction of the arm will help too.
The reverse action is ususlly initiated manually and is not affected by switch operation.
Let me know
Posted on Jan 16, 2011
When bin was full, I emptied it only to find that my shredded no longer worked on auto, forward or reverse
Dear Sir,
Maybe, just maybe, I have an answer for you.
Somewhere on the part of your shredder that touches the bin, there is a tiny switch that touches the bin, and it is a safety switch that causes the shredder to stop working if the bin is removed.
In the shredder I have, and have had, the switch is usually plastic, and is the same color as the plastic body of the shredder.
Proper positioning of the bin to the "bottom" of the shredder is critical to it's working, as the bin presses on the switch to "close" it.
God bless your efforts.
May 09, 2016 | Techko SH1524CP Shredder
How do I unjam it?
Sometimes the only effective way to unjam a shredder is to turn it upside down (with power disconnected) and pick out the jamming material bit by bit. It is a tedious, messy job.
Aug 12, 2015 | Techko SH1524CP Shredder
Only goes in reverse
Lube might not be necessary. Unplug the shredder from the outlet. Lift it off the shredded paper bin and turn it over. It is very possible that you have a jam. If this is the case, remove as much paper as you can making sure that you don't use anything that could do damage to the cutter'shredder blades. Once you have removed as much paper as possible, place the shredder back on the bin making sure that it is aligned properly. One way of making sure is to check for any space between the shredder and bin. If you do have space make sure that you replaced the shredder correctly on the bin; you may have to turn it around 180 degrees. When you get the shredder properly aligned, use the switch (DO NOT USE PAPER AT THIS TIME) to switch the shredder from Forward (shredding) to Reverse. You may have to do this a couple of times so be patient. At this point the shredder should be working in both directions. If so, move the switch to Auto or the center position and try a SINGLE sheet of paper. If it shreds that piece of paper, then you have fixed it. Be sure not to insert more paper than the shredder is rated for. Also, unless it specifically states that it can handle staples, credit cards, etc. do NOT let any of these items run through your shredder.
If none of the above works, buy a new one - :)
Jan 10, 2014 | Techko SH1524CP Shredder
Wont shut off I have to move switch to reverse then back to auto /on
in a lot of the models there is a switch in the middle of the slot where you put in the paper, right where the credit card shredder part is at. sometimes it's gets stuck. lean the shredder back and try tapping on the top. NOT BEATING on it just tapping it. in auto mode it should shut off once the switch jars loose. you may have to lean it forward also if the switch is in the front, just try both directions. you may need to unplug and turn the head over and check and make sure paper or plastic isn't stuck in the switch if it won't shut off at all. remember... UN PLUG IT BEFORE POKING AROUND IN IT!!!!
Nov 30, 2013 | Techko Office Equipment & Supplies
Shredder will run in reverse mode but not in forward/auto. Has not been jammed or overheated.
Let me know
Jan 15, 2011 | Techko SH2106PA Shredder
Our shredder motor is working but it will not go forward to shred. It will reverse. I've unjammed every visible paper jam but still nothing. HELP!
If it wont run forward but does run in reverse you may have lost the PCB inside.... contact Royal at 1-800-524-0799 for parts assistance and pricing.
Nov 29, 2010 | Royal CIA 12X Shredder
I jammed the paper got it out but it will not shred now , it is a SH2106PV Shredder i think it is jammed
Hi, Unplug it and flip it upside-down. Use a small screwdriver and tweezers or small needle nose pliers to get as much paper out of the machine rollers as possible. Remount it on the bin and restart it. Run it in forward and reverse. You'll probably have to flip it over and clean it out a few times before it frees up completely, but it will.
Best regards, --W/D--
Aug 06, 2009 | Techko Office Equipment & Supplies
Power light on
The motor could be fryed , these are hard to get for replacement depending on the model and price.
Jun 21, 2008 | Techko SH1524CP Shredder
Feb 07, 2008 | Techko SH1524CP Shredder
Techko SH4105PF Shredder Logo
48 people viewed this question
Top Techko Office Equipment & Supplies Experts
Adorjani Laszlo
casper muchato
Level 1 Expert
Tom Chichester
Are you a Techko Office Equipment and Supply Expert? Answer questions, earn points and help others
