Question about ASUS MS248H Monitor
Hello Sir, I've bought an ASUS MS248H screen with a new pc configuration. I use Intel i5 2500 cpu & AMD Sapphire hd6950 gpu. The monitor is connected with HDMI cable. I want to ask a few questions, 1. I could test the system just with the game Crysis. The screen resolution is 1920*1080 on the random desktop and no black borders, but after launching the game with the same resolution there occurs a black border around the game screen, so i can't use it full screen. How can I fix that? 2. While playing HD videos and also the game at 1920*1080 I realized a problem, especially on fast moving scenes. During the fast moving scene, the view on screen seems to be divided slightly through horizontal lines, what can be the reason and solution? I would appreciate to fix these issues. Best Regards Atakan
  • 2692 Answers
SOURCE: vw asus monitor
Download the correct driver for the VW193T monitor. Match your windows version.
Posted on Jan 24, 2009
  • 466 Answers
SOURCE: My Asus PG221 monitor suffers from frequent issues
I'm afraid this looks like an electronic fault. Some component, most likely a capacitor, has degraded, is overheating and going out of spec.
You just might be able to squeeze some more hours of work - but the monitor is still likely to drop dead any moment now - by rigging a computer fan on the backside to extract hot air from the inside.
Possibly, the problem might have a noise factor - try adding a ferrite shielding on the cable (unless one is already there, as it often is) and see whether the thirty minutes' grace period extend somewhat.
A probably unsatisfactory solution might be to drive it at a lower resolution, so that the more relaxed frequency constraints do not stress the component so much.
When the capacitor finally blows, you might be able to recognize it and have it replaced; it's likely a US $1 component and is probably in the LCD driver section. Perhaps, just perhaps, you could already be able to see it with the naked eye looking for a component that looks "wrong" - a small cylinder that looks bloated, with electrolyte leaking, whitish powder around the base, etc. But you would still need some solder work to get it replaced - and, if it's a SMD component, chances are it can't be done at home.
Sorry for the bad news...
Posted on Oct 22, 2009
  • 11361 Answers
SOURCE: i have an asus lcd
What happen if you use the VGA or the DVI ports? Do you get the pictures OK on the other two ports. Only one port at a time can be used.
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Posted on Jan 13, 2011
SOURCE: Hi, I have AsusVW222U 22 inch
Takeout the powercord at the back of the monitor and wait 5m.
Put it back.
This fixed it for me.
Posted on Feb 17, 2011
  • 16 Answers
SOURCE: i have asus vw192t 19"
Resolution capabilities are a complicated blend of the abilities of your graphics card and the abilities of your screen. You will not always get a 1:1 match. You can improve your chances by installing the "monitor information" file that is usually supplied on a CD that comes with the monitor. Also, updating the drivers for your graphics card (see the manufacturer's web site) might help.
Posted on Mar 23, 2011
Is 23.6" ATIV One 7 1TB HDD Full HD Touchscreen PC good for minecraft?
Minimum Requirements:
  • CPU: Intel Pentium D or AMD Athlon 64 (K8) 2.6 GHz
  • RAM: 2GB
  • GPU (Integrated): Intel HD Graphics or AMD (formerly ATI) Radeon HD Graphics with OpenGL 2.1
  • GPU (Discrete): Nvidia GeForce 9600 GT or AMD Radeon HD 2400 with OpenGL 3.1
  • HDD: At least 200MB for Game Core and Other Files
  • Java 6 Release 45
Recommended Requirements:
  • CPU: Intel Core i3 or AMD Athlon II (K10) 2.8 GHz
  • RAM: 4GB
  • GPU: GeForce 2xx Series or AMD Radeon HD 5xxx Series (Excluding Integrated Chipsets) with OpenGL 3.3
  • HDD: 1GB
  • Latest release of Java 7 from
Software Requirements:
  • Minecraft Release 1.6 or newer. Older versions will need to be updated to current versions
  • Please note that some users experience issues playing Minecraft while using a mismatched version of Java for their operating system (32 or 64 bit), while using certain versions of Java 7, or while multiple versions of Java are installed
Apr 23, 2014 | Samsung ATIV One 7 23.6" Touch-Screen...
Green horizontal lines on display
First thing to try is another HDMI cable and see if this fixes the problem. Seen a bad cables way too many times...
Second: update your videocard to the latest drivers:
You can find the correct drivers @ AMD support. Click the link and choose the correct settings. Then click display results. Download & install.
Third thing you could try is another monitor. Even a new monitor can be broken. Not uncommon. If another monitor has a good image then return your new one and let them give you a good one
Oct 17, 2013 | Dell Computers & Internet
Hello here is the homepage:
To enable crossfire, you must have 2 identical graphic cards.
The onboard graphic can`t be used with the hd6670.
This means that you must buy another hd6670 to add on the mainboard.
The graphic cards homepage:
AMD CrossFire technology is the ultimate multi-GPU performance gaming platform. Unlocking game-dominating power, AMD CrossFire harnesses the power of two or more discrete graphics cards working in parallel to dramatically improve gaming performance.
You also need a large power supply min. 500 watt to have enough power.
Please disable the onboard graphic in the device manager.
Good luck
Jan 06, 2013 | Computers & Internet
ASUS M2N VM DVI trouble
You must replace the processor cooler, the fan on it has aged and it's no longer doing its job properly. And use a good thermal paste.
BTW that software was designed to notify you of the temperatures and nothing more, reinstall it immediately.
Jul 09, 2010 | ASUS M2N-VM DVI - Motherboard - micro ATX...
What computer parts will be bought?
Following are the things you have to keep in Mind.
1. Processor
2. Motherboard
3. RAM
4. DVD drive (Writer will be good)
5. Suitable Casing
6. Hard drive.
7. Speakers/Headphones
8. Power Supply
9. Monitor/LCD panel
10. Keyboard
11. Mouse
Buy all these things and you can make up a basic Desktop system.
May 28, 2010 | Computers & Internet
Hello guys i want to know which mobo is better 1) asus P5W dh Deluxe or 2)Intel D975XBX2 plz tell me fast bcuz i want to buy a pc
Well they're both considered obsolete but I'll give you my take. I'm an avid gamer & have been building my own rigs since '96, now I have my own business doing the same & more. While I'm an AMD guy,mainly due to price,Intel has come along way & has since out-performed AMD as of late,but bang for the buck,AMD is still top dog. Asus is a brand I've always used,unless cost was a problem. I still have a socket 939 A8n32sli deluxe, & only had to replace it once with it's lifetime warranty. They have & probably will continue to have some issues when trying to overclock, alot of that has to do with too many settings in the bios. Alot of the settings don't need to be used in overclocking & even experienced overclockers can mess up on an Asus & thier bios reset thing...hope you never have to try it( that's why mine got rma'ed). A look at the design & reviews on the Asus board in question, I'd say it's a great mobo for gaming,etc. Very expensive,even now selling at over $200,used. The Intel,it's ok, but I guaruntee it will overheat easily with the cooling solutions they used on the north bridge & the capacitors by the cpu. It also is very expensive. I wouldn't buy either in today's market. You can get a far better board,half the size, & quarter of the price. Also the new boards can run the newest cpu's & memory,both which have come down dramatically in price. I'd really consider taking your $200+ & invest it in something much newer. I don't normally give up my secrets but this site is out of the closet now, . Check out what they have there in the "barebones" section,you'll be surprised at the system you can builld for the money you want to spend, that will run circles around either one of those boards.
May 12, 2010 | Computers & Internet
Expand graphic card
First of all i want to sugest you to make sure that you have maximum of memory, you gona need it if you want to edit videos.
If you want to do video editing the most inportant component is the CPU, then comes the memory, after the memory come the HDD, and after that the GPU
Now the GPU, you have a pci-e 16x port on that MB, so i will give you 3 diffirent sugestions, from a not that expensive to a more expensive to the third that is expensive but not the most expensive GPU there is, all of the very goos for vidoe editing.
There u have 3 very good GPU:s, but as i told you the most important is the CPU and the memory!
Good luck
Apr 02, 2009 | ASUS P5RD2-VM Motherboard
I got an AMD turion x2 64 processor in my new notebook n after reading reviews comparison to core 2 duo i m really tensed!
You made a good choice. In the CPU arena right now, the difference between the two CPUs is a toss up. The slight advantages of one vs. the other in benchmark tests is nominal and actually artificial..
What happens with an AMD CPU is with the associated GPU onboard. And with a 64bit processor, the number of apps and games that take advantage of 64bit CPUs has always been limited but they are growing. This will only become more and more numerous.
The main architectural difference in the two was in how the two cpus communicated and the AMD was first to use a bus between the two cores and the Intel had to go to the onboard memory controller and back. That was in the first inception. Still, AMD has been far in advance of Intel and Intel has played catch up in tricks inside the cores and how the north and southbridge took advantage of the cores' architecture.
Needless to say, I'm an AMD power user and my gaming rig has an AMD dual core on an Asus/Nvidia board and an Nvidia PCIe 9800 GPU.
In the long run, all modern notebooks require you to own a pad cooler to use these in your lap or not, they all produce heat. So, just get a good one designed for your laptop so it snaps into place and will keep your rig nice and cool.
At a LAN Party you won't suffer from having a dual core AMD cpu, you'll hold your own and it will be an even playing field and the wins will go to the person with the fastest fingers... as it should be.
Sleep easy friend,
Oct 26, 2008 | HP Pavilion DV5234US Notebook Laptop
ASUS MS248H Monitor Logo
80 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
