Question about Exercise & Fitness
Hi i have just bought a proform air stride crosswalk csi model petl21460 treadmill ...it worked for a day but now it had stopped working ...the digital display comes on and the incline didn't work when i bought but you can hear it when u press the button however the belt just doesn't work at all...any solutions??
SOURCE: Proform 550xp Treadmill in continuous incline/decline mode!!!
i just called the manufacturer on this and found out i have a faulty control panel, but these are the steps they told me to go through to reset. If it works, then you are good, if not, you may also have a control panel issue.
1. plug in and turn on treadmill, keep red key out
2. press and hold the stop button and speed up button at the same time and hold them while you insert the red key
3. after red key is inserted, let go of both buttons
**CAUTION - be sure to stand on side bars of treadmill, clear of the belt for this next part bc it will go VERY FAST***
4. press stop button once
5. press speed up button until it reads 85 (see what i mean?!)
6. press stop button once
7. press incline down or up one time and it should get back into normal mode. mine just started a series of flashing lights and "8"s in all the "windows" so my panel needs to be replaced. here is the number i called - 1-877-993-7999. Good Luck!
Posted on Jan 06, 2010
SOURCE: proform 360p stuck on incline
I had the exact same problem.
This usually happens if you switch it off at the mains while the incline is adjusting or is somewhere other than lowest. You should always make sure before finishing off, to lower everything.
Now for the solution: If you open up the case it has 5 or 6 black philips (cross head) screws (use your user manual if you don't have your original go to proform and find the support link and download the .PDF if your model is not available get the one before or after in the same model product line (model number is below the power input)).
Make sure you remove the power before opening the cover, obviously.
Anyway, once opened, you should find a sheet of paper wrapped around in some plastic wallet. On that paper it should explain everything. Try not to mess with too much things in the settings, otherwise you might mess it up badly.
Mine is something like: Hold the speed up (+) button and then while holding the button insert the key - that will get you to the service menu (obviously the power has to be connected).
Once in the menu pressing the incline up does a self-calibration (maximum up and maximum down) after that it should be perfect.
Remove the key any time to come out of that mode and resume normal operation.
I may not find this place for any more replies 'cos i only found this site by accident. While looking for info. on my burnt out motor model: PETL 3013.6 .... But i have come across someone selling a faulty one on ebay for like 5 quids... it's picking it up the trouble!
Posted on May 31, 2009
  • 10865 Answers
SOURCE: Need to replace 15 amp fuse on ProForm Crosswalk
Remove the fuse and take it to any auto parts store where they will match it up for you. Regards, Joe
ps - kindly rate my answer. thank you.
Posted on Feb 04, 2010
SOURCE: I have a proform j8li treadmill, all 4 led lights
I have the exact same problem with the very same treadmill that i bouth 10 years ago and it has been sitting for 5 years unused. The last time it was turned on it worked but now that I plug it in and try to start it, everything works but the belt drive motor. Any ideas?
Posted on Feb 09, 2010
How do you get the fuse out
1) see the block diagram attached. and proceed according with the logic sense.
God bless you
Jun 28, 2012 | Proform Crosswalk 2.0 XT Treadmill
When i try to run, it stops and then goes. Its like its trying to hard to go, you cant even run. its a proform crosswalk caliber.
hi it seems like the belt on the motor has either slipprd or needs to be tightened, i had the same problem. i just tightened the belt on the motor and its working fine!
Nov 20, 2010 | Proform Crosswalk 500 Treadmill
My proform crosswalk model no H 29730 TREADMILL RATING 1.5HP 12A \r\n120V AC ELECRONIC BOARD (MOTOR CONTROL) NOT WORK. CAN\r\nYOU REPIR/REPLACE THE SAME
if the motor controller card is the model MC_60 you should change D4015L diodes and SCR's S4015L but if MC_2100 you should change the MOSFET IRFP250N
Sep 14, 2010 | Proform Crosswalk 500 Treadmill
I have a pro form cross walk advanced 525x when i jog on the treadmill the track will stop rotating mid stride
the treadmill should have tension adjusting screws. they'd be on the back of the treadmill where the belt wraps around the rear roller, they're inset and you'll need an allen wrench to adjust them. the screws adjust this rear roller. you'll want to tighten them to increase the tension. they also straighten the belt. if your belt is too fat to the right, you'll want to turn the adjustment screw on the right clockwise to tighten and this will bring the belt over to the left. and vica versa for the belt being too far to the left.
Feb 18, 2010 | Proform Crosswalk 500 Treadmill
I have a 1992 Proform CrossWalk Dual Motion Cross Trainer. Motor still works great. There is rubber covering the roller under the moving piece. It has come off on the right side. Can this be replaced?
Really, I have had my crosswalk for over 20 years. I can't complain. I am passing it on to my son and getting a NEW Proform treadmill. Their longevity has sold me.....
Oct 24, 2009 | Proform Crosswalk 500 Treadmill
Treadmill speed control does not work - only max.
visit www.iconfitness.com and enter your full model number to print out a speed calibration procedure. Sounds like it needs it. We are a service dealer for them.
Aug 10, 2009 | Proform Crosswalk 3.0 XT Treadmill
Exercise & Fitness Logo
145 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
