Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
I NEED TO REPLACE A SUPPLY HOSE AND A DRAIN HOSE... ONLY PROBLEM IS I'VE LOST MY ORIGINAL INSTALLATION INSTRUCTIONS. I NEED A DIAGRAM OR PICTURE TELLING WHAT, HOW, AND WHERE TO PUT THEM. CAN SOMEONE PLEASE HELP ME! THANKS
  • tnbush2010 Mar 23, 2011
    THANK YOU SO MUCH!!!!!!! VERY HELPFUL
  • Frigidaire Master
  • 19,396 Answers
Posted on Mar 23, 2011
  • Ginko
    Ginko Mar 23, 2011
    Hi.
    You are welcome.
    All the best.
    Ginko.
Tip
How to repair or fix a Dishwasher if it doesn't drain
Dishwasher Doesn’t Drain Following a cycle, a small pool of clean water inside the tub is normal. An excessive amount of water means the pump isn’t pumping water out properly, the drain hose isn’t carrying it to the drain pipe, or the house’s drain lines are backed up.
If dirty water spews from the air gap, the drain line is kinked or clogged. (If you’ve recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made; see your disposer instructions.)
1) Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink), and, using a stiff wire, clean it out. Also check the entire length of the drain hose for kinks or blockages, especially at the drain connection to the disposer or drain line.
2) Once the dishwasher is cool, shut off the power to it, and—if your dishwasher is made to allow this—remove the strainer, located under the bottom spray arm at the base of the cabinet (see illustration). Unscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it.
3) Determine whether the sink trap or house drain line is clogged.
4) If the dishwasher still doesn’t drain properly, the drain hose may be clogged or the drain valve may need replacement. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose or replacing it with a new hose.
on Sep 03, 2010 | Dishwashers
I have a DW60CKX1 dishwasher when I select normal wash after about 10 min it flasher E10 what is wrong
Water tap not turned on. Ensure the water is connected
and turned on.
Insufficient water supply
pressure.
Check household water
pressure.
Water inlet hose is crimped
or bent, so no or not enough
water gets to the dishwasher.
Check the water inlet hose and
straighten if needed.
Drain hose is not connected
correctly.
Ensure that the drain hose is
connected in accordance with
the installation instructions.
Aug 02, 2016 | Dishwashers
Dishwasher is not working, FP DW60CSW1, three of five lights blinking
It is possible you have this error
First 3
programme
indicators
flashing
E5 Water tap not turned on.
Insufficient water supply pressure.
Water supply hose is crimped or
bent.
Drain hose is too low.
and turned on.
Check household water pressure.
Check hose and straighten if
needed.
Ensure that drain hose is
connected in accordance with the
'Installation instructions'.
For details refer user guide.
Apr 08, 2013 | Fisher and Paykel Dishwashers
Where does the grey hose connect? I'm not sure if
First we need to know what diameter said Grey Hose is? I assume you are speaking of a Washing Machine?? If so, typically they are equipped with 3 hoses as follows: One for Hot Water Supply and a Matching hose for Cold Water Supply. Both of these hoses are equipped with 3/4 Inch Female Housse Thread connectors identical to a Garden Hose. So that delegates the Third Hose to DRAIN. It is LARGER and usually is attached inside the Washing Machine to the Water Pump and passes through the rear cover and ultimately must be formed into a "U" bend and inserted into the Drain. It is necessary to secure this hose to the Drain and Supply device so that it cannot blow out of the Drain while the Washing Machine is Pumping Out. All Washing Machines come with User Manuals and Installation Instruction Sheets. Like Automobile Owners Manuals, they should be read cover to cover and stored for future reference. You can find most Washer and Dryer Manuals online. Use Google Search to find them.
Nov 18, 2011 | Health & Beauty
Water wont drain
You use your dishwasher so often with no problems that any issue can seem like a major disaster. But you can fix a drainage problem with a trip to the hardware or plumbing supply store and a few minutes of effort. If your dishwasher doesn't drain properly, the drain hose is probably kinked or damaged, interfering with the flow of water out of the dishwasher. You can fix the problem by replacing the drain hose yourself.
Difficulty: Moderately Easy Instructions And 4 Tools (Material) Needed To Solve The Drain Problem.
  • Shallow dish,Pliers or screwdriver,Replacement drain hose,Replacement hose clamps
  1. Turn off the water supply to the dishwasher. Turn off the dishwasher's power supply by unplugging it (under the sink) or turning off the appropriate circuit breaker.
  2. Pull the dishwasher all the way out from the cabinet so you can access the drain hose and pump near the back.
  3. Locate the drain pump and hose. The drain hose is the larger of the two hoses attached to the dishwasher and is generally located close to the bottom back of the dishwasher.
  4. Place a shallow dish under the drain pump. Loosen the clamp on the drain hose close to the drain pump, using pliers or a screwdriver. Pull the drain hose off of the pump, allowing any water to drip into the dish below.
  5. Remove the other end of the drain hose from the garbage disposal or drain by loosening the hose clamp and pulling the hose off of the connection.
  6. Attach the replacement hose to the drain pump and the drain or garbage disposal. Attach new hose clamps, and tighten them to hold them in place.
  7. Turn the power and water back on, and run the dishwasher through a cycle to make sure that the dishwasher drains properly and the hose doesn't leak. Tighten the hose clamps if you find any leaks.
Good luck and thanks for using fixya.
Jan 30, 2011 | Kenmore Dishwashers
How do I install a new drain hose in my LG dishwasher the original cracked and flooded my floor
You will have to completely uninstall the dishwasher to replace the drain hose assembly.
Part# AEM69493803.
Once the unit is out of the cabinet drain hose replacement is fairly easy.
Jan 14, 2010 | LG Dishwashers
Lost installation manual. specificaly wiring diagram
i damn sure didnt throw away 25 bucks; i guessed and got it.
Mar 23, 2009 | Sony Home Security
SPRAY ARM ASSEMBLEY NOT TURNING ON MY BOSCH DISHWASHER, ALSO WATER JUST DRIPPING THROUGH SPRAY ARM
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
  1. A common leaking trouble maker
  2. Another common leaking trouble maker - especially for leaking out of the door area
  3. Can I use a rubber or plastic hose for the hot water on my built in dishwasher ??
  4. Some common pump assembly pictures...
  5. Dishwasher Basics
  7. Dishwasher soap notice
  8. Draining and washing help
  9. Help for storing an appliance
  10. How to remove the access panels
  11. I just installed my food waste disposal, now my dishwasher will not drain, what could be wrong??
  12. I moved and lost the tap adaptor for my portable d/w, help!!
  13. Important disclaimer
  14. I would like to try to install my own dishwasher
  15. Loading your dishwasher help
  16. Motor and pump assembly screw and impellor help
  17. My dishes are not as clean as they used to be, what might be wrong?
  18. My dishwasher racks have rusted.
  19. My dishwasher will not fill with water
  20. My dishwasher will not start
  21. My soap dispenser will not open
  22. Sand like deposits inside the glasses and d/w
  23. Some common soap door dispensers breakdowns
Mar 09, 2009 | Whirlpool 24 in. ADG7540 Built-in...
One drawer drains into the other and vice versa
hope someone has a solution as we also have this problem...
May 25, 2008 | Dishwashers
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
328 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
