Question about Stoves Ovens
Hi, got a stoves newhome df500 dit-t2 oven, about 3 years old and the grill flame goes out on release of the control knob, when lighting the grill, any ideas as to what is wrong and how to fix it....thanks in anticipation....Bob
  • mark sawyer Feb 22, 2013
    how do you light the burners
Stoves df50 gas hob lights,but only gives a flame,help
Posted on Jun 27, 2011
I need an oven control knob for Stoves Newhome s1550D0m
try the manufacturer's website perhaps they can assist you
Aug 13, 2016 | Stoves Ovens
Push knob in on oven sparks & lights release knob flames go out
Often on ovens you have to hold the knob down for a period of time before the flame will stay alight.
Try getting the oven lit then holding the knob down for 30 seconds. That should be more than enough time if that is indeed the problem.
Is it a new oven or has the problem just arisen? It
Jul 23, 2015 | Ovens
H I have a stoves newhome 600si the rings,lite but when the grill or oven is on the flames nearly go out as if its lost full pressurean ideas please
I would have your regulator checked going to your stove to make sure you have enough flow rate or a obstruction
Jan 04, 2015 | Stoves Ovens
Grill gas comes on but on release of grill knob, the gas goes off.
I would arrange a service call from a registered gas safe engineer.
Apr 13, 2017 | Electrolux Ovens
I have a Frigidaire model FCG30B6Q0JWI-5A gas stove (Made in Costa Rica) and can't get the oven to stay lit. There is no electronic ignition, no pilot, it's just a regular run-of-the-mill light a...
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Jul 28, 2011 | Ovens
Stoves 720 EF Electric Double Oven Model No 059040415 -when you turn the grill knob there is no light and it doesn't do anything at all - the grill is not working. However, the element must be working as...
First things first. The oven element is totally separate to the grill element. The clock has to have a time set for either the top or bottom oven to work, whereas the grill will work without the clock being set.
The control knob for the top oven is the ONLY control that will turn the top oven lights on, the grill does not turn the lights on. ( If you want to watch your toast, you have to turn the top oven switch on to the first setting as well as operating the grill control).
To prevent the grill being operated with the door shut, there is a micro-switch on the door hinge that allows the grill to operate ONLY when the door is down. The grill control also does not illuminate unless the door is down. There are two options on the grill control - right or left. One way is the inner element only and the other is both inner and outer ones.
So if you have done all that and it still doesn't work, then the micro-switch could be faulty.
Best of luck
Nov 23, 2010 | Stoves 720EF Electric Double Oven
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
Hi i cant seem to get my grill or oven on can any one help
thanx for the site guys i got the no for the co and they going to get back to me thanks again
Dec 28, 2008 | Stoves Premier 720GRa Gas Double Oven
Oven will not stay alight
You have aproblem with you ffd ( flamme faliure device which is located in the oven.. Or if your oven has a thermocouple that has gone. Yo need to replace either one of them depending which one you have in your oven
Nov 18, 2007 | Ovens
Ovens Logo
591 people viewed this question
Top Stoves Ovens Experts
ashburton
John Tripp
John Tripp
Are you a Stoves Oven Expert? Answer questions, earn points and help others
