Question about Rotary Watches
Ref G3002-Batt:UC-364 PO:01092. Rotary quartz watch. I require to alter the date and day feature which has english and european days. I can alter the time by pulling the handle out which is shielded in its design but only has one pull out position. thank you.
    President:
  • 2,501 Answers
Your watch should have a position in between home and fully out but it sounds as if your watch is like mine, where I cannot detect the position (i.e no click or feeling any detent).
Try to pull the crown wheel out a little and turn it. (the day and date change feature is in this middle position).
The english days can be achieved by turning the wheel until the desired day shows (it alternates between english and another language).
Have patience and keep trying until you get the feel for the correct position!
Posted on Mar 23, 2011
Tip
HOW TO SET DAY / DATE ON AN ANALOG (STEM) WATCH
mcdevito75 here, Over Forty (40) years ago, watch manufactures added, to some of their ANALOG (wind up) and almost all of their DIGITAL (button display) watches the FEATURE of the, MONTH or DAY of the WEEK and the DATE, not only was the time of day available but also the DATE which you no longer had to go searching for, it was readily available on your wrist. The PROBLEM came with SETTING the CORRECT MONTH or DAY of the week and the DATE as some MONTHS HAD 31 DAYS rather than 30 DAYS, this meant you had to CYCLE your watch at least 62 times to get to the CORRECT DATE and mant times, when you finally did reach the CORRECT DATE, the day of the week was off, meaning more CYCLES thru the 24 hours.-------- HERE is the EASY way to SET the MONTH or DAY / DATE on your QUARTZ / MECHANICAL (STEM) watch without haveing to go thru the 24 hour cycle so many, many times. Not only is this, WEAR on your fingers, you can also damage your watch with some many cycles of the 24 hours to SET the correct MONTH or DAY / DATE. ------ HERE ARE THE BASICS,---------- Your ANALOG or STEM watch either QUARTZ or MECHANICAL should have a TWO (2) position STEM we are only familiar with the ONE (1) position we use to set the TIME, there should be TWO (2) positions to the STEM. First pull out the STEM to adjust the MONTH or DAY depending on your watches display, if your watch DISPLAYs the DAY of the week, set the DAY to one (1) DAY before the DAY you want, don"t worry about the DATE (number) yet. Once you have the MONTH or DAY set, push the STEM back into the watch, NOW with a finger nail just under the STEM (usually from the back of the stem as there is more room) gently lift the STEM to it"s first position, It may take some practice so be patient, once the STEM is in it"s first position you should be able to turn the STEM to adjust the DATE (number), if so Adust the DATE (number) to ONE (1) DATE before the DATE you want, This way your watch will be adjusted to change the DAY / DATE at the correct time. Once you have the DATE (number) adjusted to ONE (1) DATE before the DATE you want, push the STEM back into the watch, NOW pull the STEM out to adjust the time, go thru the 24 hour cycle to adjust to the correct DAY DATE (number) and time of day.------------ Your QUARTZ or MECHANICAL (stem) watch is now adjusted to the correct DAY / DATE and will change at the correct hour which is generally 12--1 AM.
on Jul 20, 2010 | Watches
Tip
on Jul 09, 2010 | Watches
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
Jan 16, 2016 | Invicta Reserve Mens Arsenal Swiss Quartz...
Rolex President Day-Date Men's Watch
Rolex, at one time, had a quartz (battery operated) watch. It was only manufactured in solid gold and was distinctive in style from other models. It is no longer being made. For all practical purposes, it you see a battery operated Rolex it is not genuine.
May 23, 2010 | Rolex Day-Date President 118239 Wristwatch
I have agents rotary quartz with the number 3081 stamped on the back. the watch is oblong with a black black face and gold lettering and a date box. and gold intergrated strap. Would you please be able to...
Your watch is battery operated hence the term "quartz" All quartz watches are battery powered. As for value I'm not sure. The manufacturer of the module (mechanism inside) is a reasonable indicator of value. If its ETA then its in the upper range. You could try seeing if Rotary have a site if so they may allow you to identify details on age etc from the stamp numbers.
Jul 24, 2009 | Rotary Automatic Limited Edition Dark...
Day in both english and french alternately.
retailer contacted rotary.
apparently there is quite a delay (hours) before the day eventually chages back to English. In other words it doesn't change immediately after 12pm but sometime early in the morning?
The moral of the story is that you should be in bed before 12pm and not to take any notice of the day on your watch since it will still be yesterday and in French?
Jun 11, 2008 | Watches
Pulsar Men's analog wrist watch - how to set day and date
Pull crown out to 1st position....Turning one way will alter the date and turning the other way will alter the day.
Apr 23, 2008 | Pulsar PXF106 Wrist Watch
Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
Dec 01, 2007 | Watches
Watches Logo
1,630 people viewed this question
Top Rotary Watches Experts
richie46
Are you a Rotary Watch Expert? Answer questions, earn points and help others
