Question about Sony Ericsson VH-310 Bluetooth Headset
VH310 is paired with my blackberry 8520. turned off the headset yesterday; cannot re-start the headset with the phone today.
2 Suggested Answers
  • 82 Answers
SOURCE: I've lost the numeric passkey
The default password, as with most Bluetooth headsets, is 0000.
Posted on Jun 20, 2011
I dont know how to able the bluetooth of blackberry curve 8520??
Here are the pairing instructions for the Discovery 610 to your mobile device.
Bluetooth Pairing Instructions:
Look in your mobile phones manual for the section that describes how to set up a Bluetooth wireless connection.
1. Move through the menu selections on your phone until the phone display shows "Look for Devices," or equivalent, as a selection.
2. With your headset turned off, hold down the call control button until the headset status indicator briefly glows blue, then flashes red and blue. The headset is now in discovery mode and will stay that way for 30 seconds.
3. On your phone, highlight and select "Look for Devices", or equivalent, to activate the scan for the headset.
4. When the phone display shows the scan results, select "6xx Plantronics". The phone will continue to search for the headset.
5. When the phone display asks for a passkey, type "0000" and press Enter.
Your headset is now linked to your phone.
I hope this helps.
Good luck from Headsets Direct - 800-914-7996.
Aug 03, 2011 | Plantronics Bluetooth Headset 610 Wireless...
Plantronics voyager pro plus is connected and paired with blackberry tour. when a call is coming in, I cannot answer or hang up the phone from the bluetooth headset.
Make sure that your Blackberry's headset mode is activated. If the headset mode is turned on in the Blackberry menu and settings, you may also need to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Good luck from Headsets Direct!
Mar 09, 2011 | Plantronics Voyager PRO Bluetooth Headset
Cannot pair blackberry 8520 with parrot ck3100
I could not pair the Blackberry Curve 8520 with the Parrot CK3100. After looking at the Parrot website, I saw that the Blackberry was actually supported, so it SHOULD work.
Then I found the solution: the Parrot had already too many other phones paired (4 or so), so it could not pair an additional one. After removing the other phones from the Parrot pairing list, the Blackberry paired without a problem. SOLVED!
Davy
Feb 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
I can not pair my headset HS820 with my BB 8520. My BB does not recognize it...what can i do?
First Ensure that your Blackberry 8520 is in discoverable mode (Settings>Options>Bluetooth) once in Bluetooth hit Menu (the button to the left of trackpad, Select options to turn Discoverable on, once you have done that ensure your bluetooth is in Pairing mode (solid blue light, except Plantronics brand which will alternate Red and blue lights) then have the device search and it should find it, select connect, then enter the headset (typically 0000 unless Bluetooth owners manual says otherwise) and it should pair just fine from there
Hope This Helps!
William
Sep 20, 2010 | Cell Phones
How to pair up nokia bluetooth headset BH-213 with blackberry curve 8520 ?
Hi
1.Ensure that your phone is on and the headset is off. 2. Press and hold the multifunction key (for about 5 seconds) until the green indicator light starts to flash quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. When the headset is connected to your phone and is ready for use, the green indicator light flashes slowly.
thank You
Aug 31, 2010 | Nokia Bluetooth-Headset BH-213 2600...
Im trying to connect my Jabra BT350 to my blackberry 8520 but my blackberry bluetooth wont even find the device even the Jabra headset is turned on.....i also lost my Jabra BT350 user manual cd and i dont...
The headset has to be in learning mode first for any phone to find it, press and hold the power on button for 8 seconds until the power light comes on and stays on then search for it with your phone, pairing code can be 0000
Aug 29, 2010 | Jabra BT350 Bluetooth Headset Headset
How to get Jabra BT2050 in pairing mode? Problem - Rogers Tech Support asked me to ''wip'' my BlackBerry 8520, after that the bluetooth device stopped working and won't go into paring mdoe. Thanks.
Press and hold the center round on/off button for 10 seconds to put Jabra BT2050 into pairing mode. Type in pin "0000" when the BlackBerry 8520 detected the bluetooth headset, then the two should be paired. Hope this help.
Joseph
Jan 09, 2010 | Jabra BT2050 Bluetooth Headset
How to connect jabra BT150 to blackberry 8520 curve
You need to pair your Blackberry with your headset.
  1. Turn on your Blackberry's bluetooth and search for bluetooth devices.
  2. While the Blackberry is searching and the headset is off, press and hold the call/end button on the headset until it's light glows steadily. Do not let go until the Blackberry finds it.
  3. Pair the devices and allow the headset to connect automatically.
  4. Default passkey is 0000.
  5. To connect, press and hold call/end button on headset like the one in step 2.
Oct 29, 2009 | Jabra BT150 Wireless Headset
I can't pair my Motorola H700 to my Blackberry curve.
http://khaoohs.wordpress.com/2007/11/16/motorola-h700-bluetooth-blackberry-pairing/
this actually works.
Aug 09, 2008 | Motorola Mobility H700 Wireless Headset
Sony Ericsson VH-310 Bluetooth Headset Logo
54 people viewed this question
Top Sony Ericsson Radio Communications Experts
JonSnell Electronic
JonSnell Electronic
sandrasteven
Are you a Sony Ericsson Radio Communication Expert? Answer questions, earn points and help others
