I own a Lexmark X4580 all-in-one. When I press the scan mode button, it shows an on screen message "Cannot retrieve Application List". I have restarted, unplugged, shut down for hours & cycled through other functions. Still the problem continues. This is keeping me from scanning some important docs. Please advise.
  • Dan Hanes Mar 24, 2011
    Very helpful. Thank you.
    Guru:
  • 1,833 Answers
According to your problem It is not possible to retrieve the scan application list during the Downloading Application List step. You should determine if the resolution below should be used. It may possible also for USB connection. Check the USB cable. If you don't have connect with PC through USB or Wireless then change setting of resolution and document format. If this does'nt solve the problem then you can download 3500-4500/3500-4500.exe patch. Install it. then turn off the system and reboot it after 30 second. this may help you.
Posted on Mar 23, 2011
My Printer Lexmark X4580 will not scan. I get the following message-Cannot retrieve Application List. Printing and copying works fine.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. If your printer is connected via the USB cable, disconnect your printer from your computer. Reboot your computer. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Try to scan again.
If that doesn't help, try to reinstall the printer software on your computer. This will help repair any corrupted files necessary for scanning or printing.
Jun 27, 2011 | Lexmark X4580 InkJet Printer
"Cannot retrieve Application List" Error message
plz install drivers of your printer first to your pc.
Mar 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark x5470
is this scanner plugged into a power strip by chance.plug it directly into the wall power
Oct 05, 2008 | Office Equipment & Supplies
Device monitor application problem
Make sure that the Lexmark Imaging Studio program is running. This was installed when you set up your printer.
If you see the multi-colored icon in your task bar for Lexmark Imaging Studio then try pressing the scan mode button twice. You should be able to scan then.
Sep 28, 2008 | Lexmark X3550 All-In-One Printer
Lexmark X4580 cannot scan, as although it recognises my PC and when I press the tick it states "downloading application list it thinks for ages and then states "unable to retrieve application...
This appears to be a known error on this model of Lexmark including all the 3500-4500 ranges... there are a couple of download patches on the Lexmark customer support site at lexmark.co.uk, I simply followed the instructions and the first patch worked fine......
Jul 15, 2008 | Lexmark Office Equipment & Supplies
you know some of the operating system if there is a corrupted file or dll some of the printers, USB and other devices in-counter this kind of problem you need to fix first your operating system then after that remove your printer driver and re-install again then then try to scan again..... hope this solution help you...
rate this solution please...
Mar 29, 2008 | Office Equipment & Supplies
Lexmark 5400 series
Problem: Lexmark cannot retrieve applications list
I have the Lexmark X3550 with the WiFi option board installed (makes it same as the model X4550) and get the “cannot retrieve applications list” message on one of the five computers connected to my router (Linlsys WRT54G V8) and using wireless printing and scanning. Just like everyone else with a similar Lexmark WiFi printer/scanner, I can print wireless, but cannot get the wireless scanner to work on one of my PCs.
The fix, in my case, was to change the Lexmark network name as follows.
1. Launch Lexmark Imaging Studio.
2. Right-Click on “View or change network settings”.
3. Enter a new network name in the first box shown. (This box contained the correct network name for my PC, but another name was needed to make the scanner work. I simply added “-lex” at the end of the current network name.)
4. Right-Click OK. You should return to the Imaging Studio screen.
5. Close the Lexmark Imaging Studio window. (The tray icon should remain at the screen lower right.)
6. On the printer, press the Scan Mode button.
7. On the printer’s display screen, select the Computer Name that you entered for the new network name. Just use the arrow buttons until the exact name is shown.
8. Press the Check button. The display screen should show “Downloading Applications List”. Within about 10 seconds the message should change to “ *Scan to Computer ”. Wireless scanning should now work.
9.. Press the Start Color or Start Black button. “Requesting Scan” will be shown. After a few seconds scanning will start. The process is a bit slow.
10. After a while you may see an empty small Lexmark window onscreen. Later, the Lexmark Imaging Studio will appear onscreen, then change to show many options and features. An image of the scanned item will appear in a Lexmark window. Save and/or edit the image. Another scan can be done by pressing the printer’s Check button again. Be sure the correct computer name is shown on the printer’s display.
That’s it. A new computer name was the solution. Your PC and printer may require a restart (power off) after changing the “computer name”.
Regards, Fbyrd
Mar 12, 2008 | HP PSC 2210 All-In-One InkJet Printer
Lexmark X4580 (all in one wireless)
resintall your driver or scanner/printer management suite. Drivers for these sort of all in ones, get corrupted by little things, like power glitches, all the time.
Feb 06, 2008 | Office Equipment & Supplies
"Scan Request Failed"
I have the Lexmark X3550 with the WiFi option board installed (makes it same as the model X4550) and get the “cannot retrieve applications list” message on one of the five computers connected to my router (Linksys WRT54G V8) and using wireless printing and scanning. Just like everyone else with a similar Lexmark WiFi printer/scanner, I can print wireless, but cannot get the wireless scanner to work on one of my PCs.
The fix, in my case, was to change the Lexmark network name in their Imaging Studio application. This worked for several weeks, but now I get the “cannot retrieve applications list” message again. I have not fixed the new error yet, but changing the network name may work for you. Here are the steps to change the Imaging Studio network name.
1. Launch Lexmark Imaging Studio. (Double left-click on its icon)
2. Left-Click on “View or change network settings”.
4. Left-Click OK. You should return to the Imaging Studio screen.
Regards,
Fbyrd99
Oct 23, 2007 | Lexmark X3550 All-In-One Printer
76 people viewed this question
k24674
jasbo
jasbo
