Question about Kodak EasyShare C140 Digital Camera
My camera was left in my purse and got lotion on it on accident then it said lens error 112 then i somehow got it working then it stated lens error 118 what should i do
  • 6,831 Answers
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Apr 13, 2011
On my daughter's coolpix s220, we get the "lens error" message, and then the lens closes.
Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 16, 2011 | Cameras
Tip
Sanyo digital camera showing lens error 1114 or 112
Hi.
If your Sanyo digital camera is not starting and you get lens error 112 or lens error 1114 prompted on display, that means that the lens is getting stuck, and cannot extend or retract fully. The controller board detects the error on startup, and shuts down after displaying the error message.
This errors usually happen because of dirt, or because the lens mechanis mis damaged in consequence of a shock.
If lens does not retract, try helping the lens back, without putting too much strenght, while you turn off the camera at he same time.
If the lens does not extend, try tapping softly the back of the camera to help lens out, while you turn off the camera at he same time.
If the camera had been exposed to sand or dust, try blowing canned air on the lens.
If this does not work, the lens assembly must be taken apart completely and re-assembed, and for that you need a camera repair shop.
Also call the number listed on the owners manual to get support from the manufacturer.
Check also the links below for more troubleshooting in case of lens error:
Lens not retracting on digital camera.
Lens Error.
on Apr 09, 2010 | Cameras
I bought my camera 6-7 months ago. Now when I try to take pictures the lens comes out but I can't take a picture. and then a Lens Error message shows up on my screen and the lens closes. I can view...
Leaving the camera on and putting it where pressure is applied on the extended lens will damage the gears driving the lens mechanism in and out.There fore the problem was due to a broken gear mechanism.You need to bring it to a service/repair shop, because there are no owner serviceable parts inside and which the service guy has.If you camera is under warranty(usually 1 year) return it under the warranty and get a replacement.
Feb 02, 2011 | Casio Exilim EX-Z750 Digital Camera
Describe hi, i have a canon powershot a520 that was left in someone's purse when she gave it back to me the lens is now sticking half way out and when i push the power button it blinks on for a split...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 22, 2009 | Canon PowerShot A520 Digital Camera
My camera worked fine one day, then it was in my purse. When I went to use it the light was on and the screen said there was a lens error. Everytime I try to turn it on now it makes a grinding noise and...
Hope you purchased an extended warranty. I've had two Cannon's with the dreaded lens error. Probably what happened was that while it was in your purse, somehow the power button got pressed. The camera powered up, tried to extend the lens, then stripped the gears or broke whatever mechanism extends the lens. The sad part is that if it's not under warranty, it probably not worth dumping $100.00 + into fixing it. Too bad, it's a nice 8mp camera with some pretty good reviews. I feel your pain.
Feb 22, 2009 | Nikon COOLPIX S200 Digital Camera
My Sanyo VPC S670 - digital camera lence is stuck
My camera had the same problem it would turn off after i tried to take a picture and it would say lens error 112 all i did was put duracell batteries in it as soon as i did it worked it seems wierd but try it its cheaper than getting a new camera
Jul 19, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Problem*cybershot DSC-S40
You have a jammed lens error the lens has to be repaired or replaced. You dont have to drop the camera for this to occur it can happen when ever the camera is in your pocket or purse. it accidently gets turned on and when the lens is coming out it is obstructed and strips the little plactic gears in the lens.
Feb 19, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Lens Error 25
Guess what I tried banging the bottom of my CW330 camera, as suggested by Timewarped, and the lens retracted and the "Lens Error 25" cleared. I can't believe it, you saved me about $80 in repairs. Thanks
Mar 25, 2007 | Kodak EasyShare C330 Digital Camera
Kodak EasyShare C140 Digital Camera Logo
60 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
