Question about Cycling
How do you remove the pedals from the bike? - Cycling
  • 70 Answers
The pedal on the right hand side, when looking from the back of the bike will be left hand thread, meaning righty loosey. The pedal on the left will have normal thread. You will probably need a deep well socket of the right size and an extension to reach the nut inside the pedal, then just hold the pedal arm still in a vise, or with a wrench, and loosen in the correct direction for whichever pedal you are removing.
Posted on Mar 23, 2011
  • 57 Answers
You should be able to use a box end wrench on the spindle.
This is a video link of a website I use and reference for all my bicycle maintenance.
http://bicycletutor.com/replace-pedals/
I have installed and removed clipless pedals but not these-need to change from one bike to the next. How do I remove my ultra 6700 carbon SPD clipless pedals from my bicycle's crank arm
Go and buy a Pedal Wrench (at your Local Bike Shop, or online).
If you buy it from your LBS, then they'll happily demonstrate how to use it, otherwise do a search for Bike Wrench on You Tube.
Hope this helps.
Rgds,
Scott
May 24, 2014 | Pedals Cycling
How to get pedals off
the pedals are reverse threaded. So instead of "righty tighty" it's just the opposite.
Apr 19, 2014 | Toys R Us 1001325 Avigo 20 inch Little...
Raleigh tora bike pedal removal, i got the pedal off how do i remove the inner bar
You have to either buy a crank arm removal tool, or take it to a bike shop. There is no other way. I recommend using your local bike shop since they charge very little for this, and you can easily ruin the bike without some experience with the tool.
May 12, 2012 | Raleigh Cycling
Trying to replace the pedal, cannot get the existing pedal off of the bike. It is the left pedal shaft that will not come off. The bike is a Schwinn 220 excersise bike
Are you sure that you're turning it correctly? The left pedal on almost all properly designed bike pedals turns counter-clockwise to remove, the opposite direction to normal.it's to ensure that normal forward pedalling action cannot unscrew the pedal.
Jul 18, 2011 | Cycling
I would like to remove the pedals to teach my child to ride on 2 wheels but cannot find the manual
In my tips and tricks section is a link to the manual. You can also take the bike into any bike shop and generally they are happy to pop the pedals off for you. You need a pedal wrench to remove the pedals, so if you don't own one then this is the simplest and cheapest solution.
Mar 20, 2011 | Huffy 12 in. Girls Disney Princess Single...
You usually need a pedal wrench. They are thin and easily slid on the pedal nut. 17mm or 19mm typically, depending on bike/pedal size.
Jan 24, 2011 | Bike Extreme Lite Youth Shoulder Pad
I need to remove the pedals of a Mongoose downhill mountain bike
Hi Miranda
You need to purchase a pedal removal spanner(wrench). They are very thin so they can slot in between the pedal and the crank.
If this is not an option, find a 15mm spanner(wrench) and tap it onto the bit where the pedal meets the crank. Ive always found that you need a friend to sit on the bike, hold the opposite pedal at the low stroke while you undo the pedal.
**REMEMBER** pedals have the opposite to normal threads. To undo them, you need to turn them clockwise. Spray penetrating fluid onto the threads a day before you attempt to remove them. They are very difficult to remove.
Hope this helps.
Aug 23, 2010 | Cycling
Remove the pedals from a boys huffy bike
Bike pedals can be a little tricky, but most likely for that bike you will need a 9/16's wrench. There should be some flat surfaces inboard of the pedals between the crank arm (the long arm that you screw the pedals into). Now, here's the hard part - the R pedal is normally threaded, but the L pedal is reversed. The easiest way to remember which way to turn the wrench is to stand behind the rear wheel and you will always pull the wrench towards you to loosen. Depending on how long the pedals have been on, they might be pretty tough to get off. You could use some penetrating spray (like Liquid Wrench) and let that sit for awhile. Also, once you get the pedals off, remember to put a little grease on the threads so that next time they won't be so tough!.
May 11, 2010 | Huffy 16 in. Boys Diego Single Speed Bike....
I can't remove the pedals - I want to remove these
Be advised the left pedal is left-threaded. Get yourself a nice Park brand pedal wrench.
What fixing nut?
How to:
http://www.parktool.com/repair/readhowto.asp?id=83
Apr 01, 2010 | Shimano America PD-M540 MTB SPD Mountain...
Cycling Logo
245 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
