Question about Iomega 500GB Prestige USB 2.0 Portable Compact Edition Hard Drive
My hard disk makes a beeping sound when connecting to my mac and it's no recognizable. I already changed cables and ports.
  • Iomega Master
  • 19,396 Answers
Hi.
Beeping sound means physical damage. Often there is no way to recover data.
Please let me know if you would need some more advice on this.
Regards.
Ginko.
Posted on Mar 23, 2011
2 3Tb Hitachi External Hard Drives for Mac OS X 10.6.8. Not recognized by my Mac
Hi, I presume that in the box where they came packed it says "Mac compatible" since every HD nowadays is. They are not recognized probably because you did not format them.
Warning: The following instructions will ERASE ALL of the Disk's contents.
Do the following:
  1. Plug the Disk into the computer.
  2. Open "Disk Utility" app in your Mac (it is a built-in app, already on your Mac).
  3. Big disks like that may take several seconds to initiate, be sure to wait for it to pop up in "Disk Utility's" left device list.
  4. Select the disk in the left panel (device list) and then, on the right, select "Partition" tab.
  5. In "Volume Scheme" select 1 Partition (or the number of partitions you wish if you understand the concept of a partition).
  6. In "Volume Information" give the name to your disk/partition and select it's format (If you're going to be switching the disk between Mac and Windows select MS-DOS (FAT), if only Mac choose Mac OS extended). Warning: MS-DOS is an old primitive filing system so you will not be able to have single files with more than 4 GB on the disk, like an HD Blue-Ray movie.
  7. Select Apply, done.
If you couldn't see the disk in "Disk Utility" then your USB ports may not be fast enough, in this case you may have a cable with 2 USB ports that go in the computer and both connect simultaneously the disk to provide more speed. If you don't I can't help you more with the information i've got.
Good luck.
Sep 23, 2013 | Hitachi Computers & Internet
When connected External HDD by USB Cable with PC then not detected
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Sep 09, 2011 | Computers & Internet
Hello, my seagate external drive is not registering on my mac but is making a beeping noise. What does this mean?
Try changing your USB cable you are using to connect the External drive.. It may be that the usb cable is not good and thus the Drive is making beeping sound..
If it helped you please say thanks and like/rate the comment please
Jun 06, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
The hard drive was set up for my Mac and was working well. Now there is a beeping sound! How do I get it to stop?
The beeping sound is generated when the disk has suffered a mechanical failure - the only way to fix it is to buy a new one since this one is near or already dead.
Jun 04, 2011 | Computers & Internet
I have a 1 TB SimpleDrive external USB drive. The drive is now making a repeating, beeping noise, slow and methodical, and it is not recognized by either my MAC or my pc. WHat does the beep-beep-beep mean...
the beeps are post during post the very first work is done by the ram all the memory in the ram is first transferred to the hard disk and remains active until turned off.
make sure that your RAM is securely seated,
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
when you plugged the external disk drive you got that windows could recognize the USB device change the cable just replace the cable of the hard disk everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 30, 2011 | SimpleTech SimpleDrive Portable USB 2.0...
HM500JI not recognized by computer (mac), a red flashes and it beeps.
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
Nov 10, 2010 | Samsung HM500JI 500 GB SATA Hard Drive
My iomega external hard drive beeps when connected computer
I just bought an Iomega external Hard Drive model number SPDHDU and I couldn't get it to stop beeping when I connected it to my Mac... Then I changed the usb connection from one I had laying around for other devices, to the one it came with and now it works fine!
Jan 11, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
My hard drive doesn't show up
If the external hard drive is not detected by yur computer, try first connecting the drive on a different USB port so we can test the USB port and then after that if still not yet detected try a different USB cable to test the cable and after that still not detected connect the drive on different computer so we can see if this is already a hardware problem.....
Jan 05, 2010 | Sabrent eSATA External Drive Case
My hard disk do not detects by the machine.
Thanks for using fixya.
If your computer doesn't detect the hard drive, its possible that:
1. There is a problem with the data cable for the hard drive. Change the SATA cable or IDE cable.
2. Power connection to the Hard drive might be loose. Make sure its connected properly.
3. The hard drive may be bad already. The best way to find out is to try and connect it to a different computer.
4. Its also possible that the port on the motherboard is already bad but this seldom happens.
Jul 16, 2009 | Samsung (SP0822N) 80 GB Hard Drive
Bought a new LaCie drive; isn't recognized by mac or pc
Lacie Porsche drives in my experience or infamous for not having the most durable bridge boards. The bridge board is a chip that has a chipset on it which take the SATA or PATA connection and send it to the USB and or Firewire ports on the enclosure. If the drive is powered up, you should get a small red or orange light on the front. When connected to either mac or pc ( porsches are MS_DOS formatted out the box ), if it does not mount or does not appear in DISK UTILTY, then it is a high probability that the enclosure/bridge board has failed and the drive ( if not making grinding, buzzing, clicking or beeping sounds) will have to be extracted and placed into a more stable enclosure. Hope this helps.
Oct 02, 2007 | LaCie 301103U 500 GB USB 2.0 Hard Drive
Iomega 500GB Prestige USB 2.0 Portable Compact Edition Hard Drive Logo
233 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
