My hp laserjet 2015n is printing a black line down the paper, what is this and can i fix it?
  • 125 Answers
Hi:
One way to determine what is causing this is to do what is called a "panic stop" while printing a document. As the paper is starting to be fed into the printer shut it off and remove the toner cartridge.
You ideally want the paper to be under the print cartridge. Examine the image on the paper. Is the line visible on the paper at this point? If so, then the problem is with the print cartridge and it will have to be replaced. If the line is not showing up on the paper then the most likely culprit is the fuser section. This is were the toner on the paper is fused to the paper by heat and pressure. The heat roller or heat sleeve could have a line on it which would correspond to the line you are seeing on the paper.
Andrew
Posted on Mar 23, 2011
How to get rid of the vertical black line on the paper?
Usually replacing the toner cartridge fixes that problem. Sometimes it's the fuser.
Jan 20, 2014 | HP LaserJet 1018 Printer
Black line on left side of paper
I forget the terminology but I believe there's either dirt or a sheet of paper on an internal roller.
You might try here for HP help.
Aug 12, 2012 | HP LaserJet 1300 Printer
Duplex printing availeble in HP laserjet 2015n?
HP 2015n is not able to print duplex (both sides). HP printers, which have duplex print have "d" after the product name/number - like HP2015dn, 2055dn.
Aug 20, 2010 | HP LaserJet P2015n Printer
Lines in printing
...maybe its time to replace fuser fixing film!?
Nov 10, 2009 | HP LaserJet 1020 Printer
HP Laserjet 2015n printer
Sir, the Hp LaserJet 2015n printer CANNOT automatically do duplex printing since the printer does not include mechanism and paper storage areas to cycle the paper through the printer a second time and print on the reverse side. Manual duplex printing can be done as follows: Choose duplex printing and remove all sheets after the printing is complete. Turn the sheets over while preserving the orientation and insert them in the paper feed path. I have an HP 1020 laserjet printer which is similar to the 2015.
Aug 22, 2009 | HP LaserJet P2015n Printer
A black line is printing on the left side of the
Pull out the toner cartidge, lift the flap and look at the drum, it should be clean. you will have to buy a new cart to fix
Jun 03, 2009 | HP LaserJet 1300 Printer
HP 2015n only prints after power cycle
try to connect the printer to a computer independently from the network just to make sure if the problem lies with the network or printer.
May 19, 2009 | Office Equipment & Supplies
HP Laserjet 3390 Prints a Black Line on papers
make sure you check and make certain there are no scratches clean both the top of the scanner and the scanner bed itself and wipe down with a lint free cloth
Feb 12, 2009 | HP LaserJet 3390 All-in-One Multifunction...
HP LaserJet 4000tn Printing a Black Line
Change the toner cartridge, refilling will not solve the problem.
May 29, 2008 | HP LaserJet 4000tn Printer
Black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Oct 15, 2007 | HP LaserJet 3055 All-In-One Printer
125 people viewed this question
k24674
jasbo
jasbo
