Question about VinoTemp VT-60 Wine Cooler
The temperature was set in the mid 50 range, but dropped suddenly to below freezing. I heard a loud "clunk" type noise just prior to that. I assume it is a faulty thermostat. How can it be fixed?
    Guru:
  • 1,524 Answers
This uses a temperature sensor and control board.
Vino temp @ 1-800-777-8466
The "clunk" noise sounds like the internal compressor motor mounts have broken.
Posted on Mar 23, 2011
Is it normal for my 2012 subaru outback to have a loud popping/clunking sound after I am done driving it (shut the car off)? I Have heard it from my previous car as a cooling thing but this seems loud
run the fault codes as it may be an indication that the cat converter is running at an excessive temperature due to incorrect air/fuel mixture settings from the ECM
Sep 12, 2014 | 2012 Subaru Outback 2.5i Wagon 2.5L 4-cyl....
I am not able to adjust the temperature on the freeze protection.
Unknown which freeze control you have.
http://waterheatertimer.org/pdf/PF1102M-freeze-control-manual.pdf
Usually the adjustment range is small for pool timer controls since pipes are made of plastic.
You can buy thermostat controls and convert them to freeze controls and give yourself wider range of temperatures.
Cadet 72801 has range from 80 to 40 degrees, and turns ON when temperature rises above set point.
You can reverse operation so it turns on when temperature drops below set point by installing DPDT relay.
10 amp use Omron LY2-AC or 30 amp use 5X847 relay.
http://waterheatertimer.org/H230A.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 27, 2012 | Pool & Spa
I have the one with frezzer on bottom and french doors fan makes loud noise louder some days then others open doors it stops close them back and it starts again my modle does not have an ice or water...
refrigerator (commonly called a "fridge") is a cooling apparatus. The common household appliance comprises a thermally insulated compartment and a heat pump-chemical or mechanical means-to transfer heat from it to the external environment (i.e., the room in which it is located), cooling the contents to a temperature below ambient. Cooling is a popular food storage technique in developed countries and works by decreasing the reproduction rate of bacteria. The device is thus used to reduce the rate of spoilage of foodstuffs. A refrigerator maintains a temperature a few degrees above the freezing point of water. Optimum temperature range for perishable food storage is 3 to 5 °C (37 to 41 °F).[1] A similar device which maintains a temperature below the freezing point of water is called a "freezer".
The refrigerator is a relatively modern invention among kitchen appliances. It replaced the icebox, which had been a common household appliance for almost a century and a half prior. For this reason, a refrigerator is sometimes referred to as an "icebox
Jan 16, 2011 | Samsung Refrigerators
Frigidaire Model ES200 White Electric Range f1
F-1 USUALLY MEENS THE MAIN PCB OR CLOCK ***. I WOULD RECOMEND REMOVING THE POWER AND PULLING IT AWAY FROM THE WALL .TAKE THE BACK PANNEL OFF AND LOOK FOR A BURN MARK. THAT SHOULD SHOW WHAT BLEW.
GOOD LUCK!
ERIC
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Mar 05, 2010 | Electrolux Kitchen Ranges
My westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Nov 08, 2009 | Westinghouse Refrigerators
Temperature not low enough
check fan at the back of refrigerator or you have defrost problem
Apr 05, 2009 | Kenmore Refrigerators
Whistle noise? POP? Black out
sounds like the lamp has shattered. check the lamp
May 18, 2008 | Samsung HLN5065W 50" Rear Projection...
VinoTemp VT-60 Wine Cooler Logo
322 people viewed this question
Top VinoTemp Refrigerators Experts
Vernon Taylor
Ilia Bichin
Are you a VinoTemp Refrigerator Expert? Answer questions, earn points and help others
