A code was entered on my panasonic tv. i want to get the channel lock off can't remember the code.
    Top Expert:
  • Televison & ... Master
  • 75,417 Answers
Hello
There is one way to unlock your Panasonic TV. There is a procedure. Follow it and see whether your set can be unlocked or not. In most Pansonic sets this will work.
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip.
You must have its original remote control to do this effective.
OK
Posted on Mar 23, 2011
Zenith Z42PT320. I set parental lock code for my son and forgot password. How do I reset or retrieve?
Zenith TV unlock [Child lock]
Tune the television to a channel blocked by a child lock. The words "Enter Lock Code" will appear on the screen with four dashes underneath
Press the numbers on the remote control to enter the child lock pass code to unlock your Zenith television. When the code is entered correctly, the blocked channel becomes visible. The words "Enter Lock Code" remain on the screen if the password is not correct
Enter "0000" if you did not change the password on the television prior to enabling the child lock feature. This number is the default pass code for the child lock.
Push "7777" if you changed the pass code for the television but no longer remember the code. This number allows you to bypass the child lock and watch the programming.
Key lock
Press the "Menu" button on the remote control to access the "Main Menu" screen on the television.
Scroll to "Special" using the up or down arrow buttons and press the right arrow button to access the "Special" sub-menu.
Push the up or down arrow button to highlight "Key Lock" and then press the right arrow button.
Press the up or down arrow button to change "Key Lock" to "No" and then press the "Menu" button to save the setting.
Wish to get more? http://electrohelponline.blogspot.com/
Jun 07, 2013 | Televison & Video
When I cut it on it says channel locked enter passcode how do you get it to unlock
Press the "Menu" button to set the lock code for your JVC TV. A padlock icon will appear on the menu display.
Press "Zero" to access the lock code function then use the left and right arrows to select the four-digit number for your code. Use the up and down arrows to move to the next area of the display.
Select the up or down arrow to finish your lock code then use the left or right arrow to save your lock code settings and exit the menu. You can return to this display if you forget your four-digit lock code and set another code.
Write your four-digit lock code down and keep it in a safe, private area.
Select the locked TV channel you desire to watch or want to unlock. A message will appear on the display requesting you to enter your lock code to unlock the channel.
Unlock your JVC TV by entering your lock code on the 10-key pad. The message "Invalid Lock Code!" will appear on the screen if you enter the wrong lock code.
Oct 12, 2012 | JVC AV32F476 32" TV
I have a Panasonic pv-c1320 without the remote. trying to get the code through comcast digital transport adapter need a 5 digit code
Here are some Panasonic codes that Comcast lists on their website: 21062, 20035, 20162, 20225,
20614, 20616, 21035
(but the code depends on which remote you have, check Comcast's website for more info)
http://www.comcast.com/corporate/customers/customer_support/remotes.html
You can also try to manually search for the code:
Turn the TV on
Press TV or AUX
Press and hold "Setup" until TV/AUX blinks twice
Enter 9911 and press "Power" using the Comcast remote
Press "Channel Up" until device powers off
Press "Setup" to lock in that code
Please let me know if you found this helpful.
Have a great day!
Mar 16, 2011 | Panasonic PV-C1320 13 in. TV/VCR Combo
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
0711
0711.
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
lock.
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
regards
shaun
Parental Control Menu
Lock Enable
Change Code
Reset
Back
Main Menu
Sound
Size
PIP/PBP
Parental Control
Channel Setup
Setup
Exit
Press Right to Enter
Press New Code
Off On
TV Rating
Movie
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
I was given a mitsubishi tv but the previous owner had a password lock on it. Is there any way to access the tv by rebooting or something in order to use the tv?
1. Press the Mode button until the LOCK CODE display appears.
2. Enter the 4-digit code using the CHANNEL SELECTOR buttons.
3. Press the CANCEL button to cancel the previously locked channel. The LOCK CODE number display flashes.
4. To exit the CHANNEL LOCK mode, press the MODE button until only the Time and Channel display appear.
Secret text if the code is forgotten!
2. Press Channel Number "9" and "QV" simultaneously. Knowledge of this procedure defeats the channel lock system.
Nov 12, 2009 | Televison & Video
Volume not working for different tele
Hold down TV button at top of remote until other buttons on top row light up. Press red power (big one) then press channel up repeatedly until tv turns off. Press # button on bottom right to set the new code.
It might only take a few channel ups before you find the right code but it may take a hundred. If you go thru all of the codes in the remote the tv button will start flashing quickly to indicate you have done so.
When you are all finished just remember to press and release the sat button up top to control the Dish receiver once again.
Here are some common brand name tv codes also. If yours is here its easier to enter the code. Hold down the tv button until all others light up then enter the three digit code and press #.
Sony 500 Zenith 501 RCA/GE 503 Mitsubishi 504 Panasonic 512
Aug 21, 2009 | Televison & Video
My cable channels are not coming through. The tv
try all 0000 see what happens sometimes that is factory code hope it works
Feb 20, 2009 | Panasonic CT-27E13 27" TV
Panasonic TV TC-19LX50 that is Locked
Ask your part time workers what the code was, then enter it into the television.
Mar 24, 2008 | Panasonic CT-24SX12 24" TV
Channel Locked
someone have entered a code in the tv ask any member of your family who had tampered with the tv and if they had, do they remember the code they put in.if no one can give account of what had happen you will have to call a tech and have them reset your tv.good luck.
Apr 26, 2007 | Sony Grand WEGA KDP-65WS550 65" Rear...
Televison & Video Logo
165 people viewed this question
Top Televison & Video Experts
