My Philips remote control doesn't speak to the TV. I have tested the remote control on my other Philips TV and it works fine. The TV works fine with the buttons on the unit, it's just I can't use the remote!
  • rugbygm11 Mar 23, 2011
    Hi that didn't work so I'm thinking I need a new IR receiver like you said. Model number is 22HFL3330D/10. Would it be easy to fit myself?
  • 19,396 Answers
Hi.
The TV uses an internal IR receiver to communicate with the remote. If the TV is not working when you use The TV's own remote, and if the remote has been tested and its working, then the problem is the IR board or circuit located inside the TV.
Before calling support try disconnecting TV power cord for fifteen-twenty minutes, flip out remote batteries for one minute, then reassemble remote and restart the TV. The power down will reset internal circuits.
If that doesn't work, the IR receiver inside the TV must be replaced. The part is not expensive. Call the service number listed on the owners manual to call support. Verify warranty status and ask a quote on repair.
If you want directly locate the part, let me know model of the TV in question.
Regards.
Ginko.
Posted on Mar 23, 2011
  • Ginko
    Ginko Mar 23, 2011
    Hi.
    The IR board is not difficult to replace, but you will still need to disassemble the TV. The manuals say that service must be carried by a trained person.
    Here is a service manual.
    The IR board is pictured at page 11 in service manual, see pic.4.3.6.
    The board is not expensive, but parts for this model are not listed on web. The part must be ordered from Philips.
    Regards.
    Ginko.
What is the tv code for sylvania model #SST4324
1. Your TV has a high failure rate with the IR module. When this goes bad no remote will work with your TV. If you still have your OEM remote try testing it to see if it is transmitting a signal. Instructions below.
2. Many universal will not work your model TV. I suggest getting an OEM remote. You ca purchase from link below. SYLVANIA NE139UD TV Remote Control How To Test My Remote Control ReplacementRemotes com
Jul 09, 2014 | Philips Magnavox Learning Universal Remote
Phillips tv wont change channel
tried with pressing the channel button at the panel tv or using with the remote controller doesn't work?.
Oct 26, 2012 | Philips Phillips 2422-549-01929 Tv Remote
I don't have the user instructions for my Philips remote. Need to set up my TV - purchased the remote in 2010, it doesn't show a model/name on it anywhere. How do I find the instructions or apply...
If the TV is a Panasonic, I'm sure the Phillips remote wont work unless it is a "universal" remote. You will need to code it in to work on your TV if its a universal one. See if it has an auto scan button on the remote.
Dec 27, 2017 | Philips SRU3004 Remote Control
My remote won't program the tv
As you probably know, finding the correct code to make a universal remote speak to your model of tv can be a real challenge. here is a great website that may be of help to you. http://www.remotecodelist.com/remotes/
Nov 03, 2009 | Philips Universal PH301S Remote Control
Remote control will not let me cycle thru input
1-888-744-5477 Monday - Saturday 8:00 AM - 11:00 PM EST Sunday 9:00 AM - 6:00 PM EST Excluding Major Holidays
They really are not much help, they will likely direct you to a Philips Authorized Repair Shop. Hope you have warranty or some kind of insurance. Damage from a storm does not fall under warranty. Good Luck!
Sep 12, 2009 | Philips Televison & Video
Philips Magnavox Universal remote and mute control on Toshiba TV
Ha.....flippped a reset-type button on back of TV set...all is now fine....
May 07, 2009 | Philips Universal PH301S Remote Control
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Remote control stopped working
Hey. I paid the $20 for the expert advice and (I feel such a fool) I just had to unplug the tv and plug it in again for everything to work!
Martin000
May 11, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Needed: Code finding procedure for universal TV Controller by Philips
I found the instructions that came with the remote control when I bought it. It was easy to fix, and now it works again.
Thanks for offering ur help; if anything else comes up, where I will ned expertise, I shall certainly ask for ur help.
Thanks. P.
May 09, 2008 | Philips Magnavox Learning Universal Remote
Remote codes
http://www.remote-codes.com/
Apr 07, 2008 | Televison & Video
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
