Question about HP 32sII Calculator
Calculator does not switch on i have usad all of the remedies in the users manual supplied with the calculator including changing the batteries. do you either :- 1) repair the calculator. or 2) replace with another.
We hit a button on Casio HR-170RC and now it keeps rounding up. How do we stop this?
It is the slide switch for decimal places. You needs to be set to 2 places.
Slide Switch ' Printing Calculators ' Calculators ' CASIO
support.casio.com > Support > FAQs > Calculators > Printing Calculators
Q1: What is the [F CUT 5/4] switch or [DEC] F, 0, 2 button for? (HR-8 series); A1: The HR-8 series have a [DEC] key with F, 0, 2, and 5/4 over it, while many other calculators models have a switch labeled [F CUT 5/4]. The button or switch can control rounding off to a certain number of decimal places. F is floating point (no F ... Missing: 170rc
HR-170RC ' Calculators ' Manuals ' CASIO
support.casio.com > Support > Manuals > Calculators ·This page might be unreadable or wrongly displayed depending on your browser, OS version, and settings. In this case, please try with different browser (Chrome, Firefox, etc.) ·We recommend you to download the large PDF files from this site and view them off-line. [ To download a file ] 1.Align your mouse pointer with the ... Missing: rounding
[PDF]HR-170RC HR-200RC - Support - Casio
support.casio.com/en/manual/004/HR-170RC_200RC_WA_EN.pdf - Translate this page
Mar 15, 2017 - Back-up Battery. Your calculator comes with a single built-in CR2032 lithium battery that provides power to retain values stored in memory when you leave the calculator without power (AC ... Weight: HR-170RC: 570 g (20.1 oz) including batteries ..... performed with values as input, and the result is rounded.
Slide Switch ' General Calculator ' Calculators ' CASIO
support.casio.com > Support > FAQs > Calculators > General Calculator Q1: What is the use of the Slide Switch? A1: F: Floating Decimal CUT: Values are cut off to the number of decimal places specified by the current Decimal Place Selector setting. UP: Values are rounded up to the number of decimal places specified by the current Decimal Place Selector setting 5/4: Values are rounded off (0,1 ...Missing: 170rc
Mar 01, 2018 | Casio Office Equipment & Supplies
User manuels
The manual does not disclose how to change battery. This is what it says about changing it.
Jan 20, 2014 | Canon LS-100TS Calculator
The HP 10 S cannot handle the fraction 1200 17/32 !! Type in this fraction and press enter. The HP 10 S changes the fraction to its negative value. Appearently, the 10 digits of the fraction 1200_17/32...
Here is what the user manual says about the limitations of the calculator (and who or what does not have limitations?)
2d01c681-7192-49b8-85a3-3ed05bfa6077.pngThese limitations concern the display of results. As to the number of steps in a string of calculations, the maximum is 79, and you are warned by a change of shape of the cursor at the 73 rd step. The calculator can handle values between -1*10^(-99) and 1*10^(99).
If the calculator gives a negative result it may be due to change sign key being pressed inadvertently. Or maybe close to its limits the software shows some singular behavior.
Oct 07, 2013 | HP 10s Scientific Calculator
Printed manual for Hewlett Packard 35s scientific calculator
CalcPro sells the original HP35S User's manual for about 10 dollars. Here is the link.
Dec 31, 2011 | Office Equipment & Supplies
How do you change the battery in a Canon LS-100TS calculator
Here is the owner manual for your calculator as a free download. http://www.devicemanuals.com/guide/Calculator/Canon/Canon-Portable-Display-LS-100TS-User-Guide-TkRFeE5UQT.html
just download it and save it to solve your current issue and for future reference. J.
Aug 17, 2010 | Canon LS-100TS Calculator
I was given an XL-1267 calculator, with no user manual. The ink is very faint, How do I fix this?
Unisonic Calculator Ribbon XL 1267 We supply Calculator Ribbon supplies for various calculators, as well as supplies for typewriters, cash registers, printers and dictation equipment. Can't find the calculator supplies you are looking for here? Then call us at 1-800-816-6855 or email us at pos@execuline.com We carry many of the hard to find calculator ribbons for various model printers.
Aug 16, 2010 | Unisonic Office Equipment & Supplies
Voyage 200 won't turn on
I've fixed my Voyage 200!! I fixed it using the 3rd solution listed below. I've placed them all in there in case the one I used din't work. The funny thing is the solutions listed weren't even for the Voyage 200. I mistakenly tried the wrong one, but it worked!! I've also posted some soultions listed for the Voyage 200 just incase the others don't work and the website I found these solutions can be found here. Good Luck!!
Website:
http://epsstore.ti.com/OA_HTML/csksxvm.jsp?nSetId=85103&nUsePub=NO&jttst0=6_23871,23871,-1,0,&jtfm0=&etfm1=&jfn=ZG1C0B48595DC76138EFAD7BAC9C1E63B698A69C9FCFEA6C84DEE9934631AC138649F2CD10EBEEF5C5E390C0B8C5F215C2F3
List of solutions that worked for me:
  1. Try a new set of batteries (including the backup battery).
  2. Adjust the contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the CLEAR key. While holding CLEAR, reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the CLEAR key and then press it one more time to remove the message. (worked for me!! Never actually said "Ram Cleared" just had a long box across the screen that filled up and POOF it was back!!)
  4. Remove one of the AAA batteries. Press and hold the DEL key. While holding DEL, reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  5. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
Voyage Solutions:
For the TI-89 Family, TI-92 Family, and Voyage™ 200:
  2. Adjust the contrast by pressing and releasing the Diamond Key key followed by pressing and releasing the [+] key; repeat as necessary. To adjust or lighten the display, use the [-] key.
  3. Users of the TI-89 Titanium or Voyage 200 should see the following case before performing the following reset procedure to prevent the loss of valuable Apps.
    On the TI-92 family or Voyage 200, hold the [2nd] key and the [hand] key, then press and release the [on] key. On the TI-89 family, press and hold the [2nd] key, left arrow, and right arrow; then press and release the [on] key. This should reinitialize the operating system, in which you should see a progress bar filling on the screen.
  4. Remove one of the AAA or AA batteries. Press and hold the [APPS] key, and while holding the [APPS] key, replace the battery and turn the unit on. TI-89, 92 Plus, or Voyage 200 users should see "Press I to install code...", and should press the [9] key. The calculator should then say, "Waiting to receive...". TI-89 Titanium users should see "Waiting to receive..." or "Waiting to received OS...". You will need to restore the calculator's operating system.
Jan 28, 2009 | Texas Instruments Voyage 200 Calculator
User manual
This page contains 2 manuals for FX115 calculators, and while the standard seems to be MS, each manual includes several models. This should address what you need.
http://www.retrevo.com/s/Casio-fx-115MS-Calculators-review-manual/id/467ci265/t/1-2/
If you need more help, please post back, otherwise thank you for using and rating FixYa!
Jun 04, 2008 | Casio Office Equipment & Supplies
Sharp EL-1801V Calculator
Change the switch to Rate Set, then input the mm.dd.yyyy then the clock/time button then hrs (military time).minutes then clock/time button.
Apr 02, 2008 | Sharp EL-2630P Calculator
HP 32sII Calculator Logo
199 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
