Question about Asko Dishwashers
My 10 yr old 1895b leaks during the drying cycle
  • 55 Answers
The most common issue on these units is the door seal. The seal around the door will break down over time not sealing real well. You would need to order and replace the door seal to fix this issue on this unit.
Appliance & Refrigerator Repair
Posted on Mar 23, 2011
Whirlpool washer model wfw9050xw00 This unit is 1 yr old and is stopping at various times during all of the cycles. Also the unit is buzzing a bit when it is using the pump for drainage. Some times we...
Only 1 yr old so I assume its a simple fault like partial blockage at pump. Remove filter bottom right of machine check and clean if needed . remember to use an old towel fist as this will contain around half pint of water assuming its drained 1stly , Always unplug machine from Electrics before any repairs, Good luck.
Jan 08, 2018 | Whirlpool duet Washing Machines
96 Suzuki Sidekick JX (86K mi.) has 5 yr old
Another problem. Cupping would be from alignment. Dry rot is dry rot. All tires will do it.
Mar 15, 2010 | Suzuki Sidekick Cars & Trucks
Silvia leaking water
Hi
The solenoid valve needs back flushing the correct way with a espresso machine detergent like Cafiza, or Joe Glo. Place a 1/2 teaspoon in a blind basket. (don't come with Silvia). Place blind basket in portafilter and brew like making espresso, but run pump for no more than 5 to 10 seconds or until the pump starts to change tone (slow down). Stop the pump when either of these things happen or Silvia can be damaged. Repeat the pump 5 to 10 times leaving a 1 minute wait between cycles, or the suds comming out the 3 way valve turns pure white, with no coffee stains in the foam. Remove the portafilter and rinse then reinsert and repeat the cycles to rinse the internals. This should take care of the problem. If not you may have to replace the 3 way.
Nov 12, 2009 | Rancilio Silvia Espresso Machine
Spin cycle stopped on 10 yr old Amana washer
its the brushes on your motor or your pump is blocked or defective
Jun 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Craftman 205 mpg 2 cycle gas blower 40:1 raito will not start.
Similar experience with the same blower. I cleaned the carb checked for spark but I still can't get it to start
Nov 13, 2008 | Craftsman 4 Cycle Blower/Vac
2-yr old unit is leaking
I had this problem with similiar model, the extended warranty company was out several times, replaced gaskets and many other parts. Still had the problem. The last tech replaced the upper washing arm that hangs below the upper rack, He said there was a defect where water shoots out between the mfg welded seam and shoots water at the door in the right spot to make it leak. He replaced it and haven't had the problem for about 8 months.
Nov 26, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
Dishwashers Logo
83 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
