Question about Indesit W 123 Front Load Washer
My washing machine is just clicking past the programs ive count the flashing faults lights and there are 7 of them what dose this mean is wrong
  • Indesit Master
  • 17,130 Answers
It is possible that the contacts are not working or contacting and so the timer program controller is faulty.
Since the program moves but the cycle is not initiated you must confirm with a circuit test- the voltages on the motor at the time of the cycle.
Posted on Mar 23, 2011
What do I need to get error code as machine is not working
If your machine has a digital display and there is a associated fault with the machine then an error code will automatically be shown in the program window but if there is no known fault then no code will be shown. Some machines use a varying array of flashing lights or beeps to display a fault and with these machines you would need to count the bleeps or note which lights flashed and in what sequence. These fault codes only show when there is a fault with the machine
Mar 28, 2017 | Washing Machines
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Knob keeps on rotating but it doesn't follow the program.it keeps on moving and jumping into another number.
So the timer Knob keeps on rotating click click ........forever.Do you have a red light flashing a number of times then light stops for 3 secs or so then flashes the same number of flashes again before it stops again for 3secs=a fault code.count the number of flashes very carefully.Usually,the pump is jammed or blocked but can be whole load of other things depending on the number of flashes!
Dec 29, 2010 | Indesit Washing Machines
Start light flashing wont start cycle, what does it mean
count the number of flashes- this indicates fault ie will flash 4 times stop, flash 4 times stop. To clear fault, hold start button for 3 secs. Try running another fast cycle- if fault reoccurs count flashes: Number of flashes:1=NTC fault, 2=Flood switch activated, 3=Heating fault, 4=drain fault, 6=water inlet fault, 7=flow meter fault, 8=water level fault
Aug 06, 2009 | Whirlpool Dishwashers
Hariston margarita a1324 advantage
hiya
dont remember giving assitance before but i'll try and help you if i can. when the machine starts to click around count how many times the doorlock/on off light flashes as this indicates a fault code. it will usually go something like, flash pause flash pause etc until it flashes quickly then it restarts the fault sequence.
if you could let me know how many times then i'll be able to diagnose the fault quicker.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 13, 2008 | Ariston Technologies Ariston AWD12 Front...
INDESIT WI101
hiya
these machines will do this if the timer dial has been moved during a cycle, they have a memory chip on the main circuit board.
they also do this if the machine has a fault with the exception that they dont stop, the doorlock light flashes and the timer just keeps clicking.
try setting the timer to a dot on the settings then switching the power on, the doorlock light will flash a few times, turn off again select program then switch back on, machine should now be reset and work ok, if not then count the flashes of the doorlock light as this indicates a fault code.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 04, 2008 | Indesit W 123 Front Load Washer
Beko 1512s problem
hiya
sounds like there is a fault on the machine, when the timer starts clicking the doorlock light will flash a number of times, you will need to count these flashes as this will give an indication of the fault.
hope this helps
please dont forget to rate this answer. thanks kj
Jul 25, 2008 | Indesit W 123 Front Load Washer
Washing machine problem
Possible sticking door lock or a faulty PCB located in the back of machine, however watch the red light and count the flash pulses, if there is a compnent fault the self diagnostics should emit a fault code, the light will pulse and then pause, you need to count the pulses between the gaps.
Jan 04, 2008 | Washing Machines
Indesit
hi there first of all check your filter located at the front of the machine for blockages as this is a comon fault, failing that next time the dial clicks round count the amount of times the red light flashes before it does a pause then starts again, and let me know how many flashes it does as this corasponds to a fault code
murdozzz
Dec 09, 2007 | Zanussi WJD1667W Front Load Washer / Dryer
Indesit W 123 Front Load Washer Logo
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
