Lennox G8Q3-90-4 will not ignite the pilot. The
Lennox G8Q3-90-4 will not ignite the pilot. The problem occurred this morning when I realized the furnace was off and the house cool. I tried to restart the pilot. I can hear gas coming out, but nothing happens in those 60 seconds I am supposed to hold the button down.
    Brigadier General:
  • 4,736 Answers
While holding down the control knob for the pilot, you either have to use the pilot ignitor or match light the pilot. Then old the knob in for 60 seconds, before releasing it. If the pilot remains lit, turn the control knob to ON. If the pilot does not remain lit, the Thermocouple or Thermopile may need to be replaced.
Hope this helps you to solve the problem.
Posted on Mar 23, 2011
Testimonial: "Thank you!"
  • Rich Landrum Mar 23, 2011
    My pleasure, Bvalachi. I'm glad I could help you and thanks for the 4- thumbs up rating.
    Guru:
  • 1,524 Answers
Change the. spark igniter and thermocouple
Intertherm propane furnace will not stay on
You need combustion air to keep pilot and gas burning. You should have louvers or vents on that door. If you don't, you may have the blower door and combustion air doors switched. I have been on a couple services calls where the customer had reversed the doors without realizing it.
Dec 29, 2017 | Intertherm Heating & Cooling
Lennox g26q3
electronic ignition or pilot type? assuming electronic ignition, check the airflow sensor for dirt in the peto tube, or a defective sensor, if you hear the high voltage click but have a failed ignition chec that the pilot is being lit, and that the thermopile/infrared sensor is good. one of those is your problem.
Mar 23, 2014 | Heating & Cooling
Lennox G20 gas valve switches off then on Intermittently?
This could be a dirty flane sencor of the pressure switch check hoses are tight and not spilt , try jumping out the pressure switch see if that makes it work also check air fliter is clean .
Feb 11, 2013 | Heating & Cooling
Lennox furnace model G11Q3-110 v.2 burners light but go out before fan comes on
Troubleshoot an ignition problem on a Lennox gas furnace ...
? 2:44
https://www.youtube.com/watch?v=yXIxgzwMkPs
Nov 17, 2012 - Uploaded by grayfurnaceman
This furnace should light its pilot with a spark then the pilot proves its on ... Troubleshoot an ignition problem on a Lennox gasfurnace .... Pilot and no inducer but is the same model as that great video! ... You probably have dirty burners. ... How do you know spark module is not sending 24 volts to mv and pv ...
Lennox Furnace Model G11Q3-82-2 - RepairClinic.com
Nov 19, 2012 | Heating & Cooling
Pilot light will stay lit Lennox G8D2-82
You may need to replace the Thermocoupler. It screws into the gas regulator and the sensor end is set in the flame of the pilot light. You can get one at any appliance parts store. The Thermocoupler simply feels the heat of the pilot light and sends a very small amount of voltage to the gas switch that opens when your thermostat calls for heat. If the pilot light isnt lit, no voltage from the sensor and no gas can be released by the regulator.
Anyone can replace one. Just find the tip that sits in the the pilot flame when you try to ignite the pilot light. Follow it down to the regulator and unscrew it. There is no gas involved. It is Ultra Low Voltage. No danger.
Be sure to turn off the power to the unit before you begin removal. Take it to the parts store along with your furnace brand and model number. If you see any identifiers on the regulator, note them and take them with. When you replace it be sure to have the sensor end up in the flame of the pilot.
Sep 29, 2009 | Heating & Cooling
Can't find instructions on lennox gf 8 series furnace
Does it have a standing pilot light? On new units, there is an igniter and not a pilot. But if you have a standing pilot, you will move the gas valve to "pilot" and push down the red button while holding a flame under the pilot located by one of the jets. Once it lights continue to hold the button down for a minute or so and then release the button. The pilot should stay lit. Then turn the dial to the on position. That's it.......... If the pilot won't stay lit then the thermocouple is bad and needs to be replaced.
Apr 05, 2009 | Heating & Cooling
Furnace will not heat.
Most of the Lennox G-16s that I have repaired were having problems with the gray Penn-Johnson Piggyback igniton control module.
This is best repaired by replacing the spark module. Sometimes it may be neccesary to replace the gas valve also. Lennox updated to a ROBERTSHAW ignition system. Honeywell can also be used.
Also check that there is no water in the pressure switch or tube.
Hope this helps.
Matt
machtcl1@verizon.net
Jan 13, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
806 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
