I have been given asecond hand Ignis 405/2 top loader washing machine, but doný have the manual. I simply cannot understand the washing symbols on the top. Can you help?
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly
With great effort I found a quick start manual here that is not free:
http://www.user-manuals.com/quick-start-IGNIS-AWV4052.html
The link above is the only one I found that did not say
"The manual is available only in language(s): Spanish Portuguese"
It is the only link I found that saod the manual was also available in English.
I hate to make a referral as I am hoping you do not spend $8.99 for a manual in a language other than English.
Thanks for choosing FixYa,
Posted on Mar 23, 2011
Ignis website
how i get a manual for ignis fl910 washing machine?
Jan 23, 2014 | Washing Machines
Where to put washing detergent in Whirlpool AWM8121?
Simply place detergent into wash ball and place inside drum on top of clothes,,,,fabric softener goes in smallest compartment in tray
Jun 20, 2013 | Whirlpool Washing Machines
Soap residue fisher & paykel top loader
Agitator can be removed easy,Take out the fabric dispenser cup,
Reach down inside the agitator & undo the wing nut, left to undo.
Take out agitator & clean & the bottom of the bowl,
For a more better clean fill machine with hot to high water level & leave soak over night,Do heavy duty wash in the morning to remove scrud.
Feb 10, 2013 | Fisher and Paykel Washing Machines
Require an owners manual for L G -H950 top loader
Do you mean the LG WT-H950 top loader? LG' s Australia site had the manual for the washer on their support site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-H950.jsp . Click on the Support tab and the link to the PDF of the manual is on the right hand side of the page.
I hope this helps. If you have a different washing machine, please add a comment with the full model number.
Feb 28, 2012 | LG Washing Machines
Avanti W797 Combo Washer and Dryer............Does not fill with enough water to wash clothes. It will runn the cycles with some water, but clothes do not all even get wet????? How can I correct the...
I have this problem too. Called the repair man out to the house & he just told me it was set at the factory & there was nothing he could do. I discovered if I held the water level knob between the settings given, water would run to the level I wanted as long as I held it in place, but I don't know if this does any damage to the machine. So I don't know if you want to try that or if it can even be done on your model???
Feb 21, 2012 | Avanti W797 12 lbs. Top Loader Fully...
Ge prodigy top loader wash machine. washes fine, spins, but water won't drain. have checked for blockage in hose and found none. water will trickle through hose then stop. what do I do? Don't...
Water will not drain from machine
1. Kinked or clogged drain hose---clean hose
2. Pump does not run----readjust & tighten pump, drive mechanism
3. Suds lock---remove suds add cold water
4. Faulty transfer value---replace
5. Defective timer---replace
6. Loose belt----adjust belt
Sep 22, 2011 | Washing Machines
I require a user's manual for a Whirlpool washing machine that is approximately 10 years old. I don't know the model but the serial no. is 34 9945 011318
with out model number you will not be able to get the manual, the model number is usually on lid/door rim ,inside the lid for top loaders and inside door for front loaders
IF ya find the model number go here and download the manual http://www.whirlpool.com/owners-center/owners-center-homepage.content.html
Aug 03, 2011 | Whirlpool Washing Machines
How to remove water pump ge front loader washing machine
Pretty simple operation...here's an overview of the component locations:
Remove the 3 screws at the bottom of the front panel. Lift panel out at the bottom and it should fall down. Discharge pump is on the right-hand side. Simply disconnect the hoses from: 1) the tub and from 2) the outbound discharge hose. Then remove all screws holding the pump in place. The electrical is a quick-connect adapter.
Save yourself a mess by draining the assembly first -- just follow the instructions for draining/cleaning the filter in the Use & Care manual
Jul 27, 2011 | General Electric WCVH6800J Front Load...
Maytag neptune top loader model fav6800aww has an error code od
rlbishop720,
See this post Left Hand Lid Lock Troubleshooting . I discuss Left Hand Lid Lock troubleshooting for error codes OD,OP FL, FO all related to Left Hand Lid Lock issues. I also provide a link to purchase a replacement Left Hand Lid Lock if you don’t want to deal with a DIY fix.
Let me know if I can help…..Rich
Mar 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Is it possible to download the user manual for the ignis washing machine model FL 1207
Sure, you can retrieve the manual form the main Ignis support website. You will need to enter your model number in the provided space. You can also, retrieve you manual at this link below as well.
Click Here
Jul 09, 2009 | Washing Machines
Washing Machines Logo
465 people viewed this question
Top Washing Machines Experts
