Question about Ovens
Pitsos Pop Cooker Stuck on Auto
Unable to use oven as stuck on auto after electricity cut
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Unable to get cooker out of automatic mode
If your oven has timer and it is flashing AUTO then you need to reset it to manual for it to work.
If no timer then it could be a faulty door micro switch, located at the front left side..\Hope this helps, please leave feed back.
Thanks
Posted on Nov 25, 2008
amgm
  • 32 Answers
SOURCE: Electrolux EOB 966 stuck in auto mode
Hi, try to switch it off at the main switch. Wait for 10 seconds, then switch the power back on, reset the clock, and you should be fine.
Cheers
Posted on Feb 12, 2009
SOURCE: clock on cooker flashing
Excellent! Now my clock works, but where can I get an instruction booklet for this oven? Thanks.
Posted on Jun 10, 2009
SOURCE: Kleenmaid Scala Oven. My oven will not turn on.
I had exactly the same problem. I followed the directions to reset the clock. That is the cooking button and finish cooking button. They look like a caserole dish and a casserole dish with a cross through it. Hold them down at the same time and the + and - button to advance the time. Be aware I had to try this a few times before it worked. Hope this helps, Dean
Posted on May 14, 2010
Hi, I've tried to programme my cooker on auto following the instructions, everything works apart from when the time comes to turn the oven off automatically it doesn't work. The buzzer goes...
Are you sure it's the oven still running and not the built in cooling fan...next time look at the fan at the rear of the oven if it's not turning it's off and you will be hearing the cooling fan
Oct 08, 2017 | Ovens
Cooker clock requires resetting
You need to press 2 or more of the timer/clock buttons in seqeunce to cancel the auto setting.
The sequence of buttons varies according to the make of cooker, so just keep pressing the buttons until you hit the correct sequence.
Hope this helps.
Jan 06, 2010 | Ovens
Clock on cooker flashing
Just to let you know that i have solved the problem with my cooker, (clock flashing after electric going off) i held down the cook period button and the end time button, then i was able to reset the clock by pressing the +button.
Apr 28, 2009 | Hotpoint UY46 Style Line Stainless Steel...
Cheers
Feb 12, 2009 | Electrolux EOB6696X Electric Single Oven
How can i mend the grill and oven on my electric cooker?
If the rings work o/k then could be timer if it has one make sure it is set to manual and not auto.
Another thing it could be is a faulty selector switch, which selects the different functions.
Hope this helps.
Plz rate my solution.
Thanks.
Dec 31, 2008 | Ovens
Electric oven and hood not working but grill is?
Make sure the timer is set to manual and not on auto.
Dec 10, 2008 | Zanussi ZBQ665 Electric Single Oven
Thanks
Nov 25, 2008 | Hotpoint Ovens
Auto Timer
hi there switch your oven off at the mains switch for one minute thenswitch back on and set the time this will disable the auto on the timer.
Dec 09, 2007 | Neff U1661 Double circotherm super...
Belling Format cooker
I found the following information useful, although it wasn't a belling cooker the controls appeared to be the same. Go down to the electronic timer section. http://www.prestigeappliances.com.au/owner's-manual.shtml
Oct 29, 2007 | Belling XOU482 Electric Double Oven
Ovens Logo
382 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
