Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
I,ve lost instructions for Bissell Smart mix - Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
  • 48 Answers
SOURCE: connecting a BISSELL AUTO MIX PISTON TO A AUTO MIX KNOB
Take of the housing ,turn it over and you will see the under side of the auto mix dial , Then turn the auto mix dial to rinse only;
On the top of the piston you will see a small slot , this fits into
the out side spiral on the auto mix knob with the dial set to rinse only the top part of the spiail sould point to the courner
Tilt the piston slightly,then hook it on the point of the auto mix knob , when you turn the auto mix dial to heavy traffic the piston should slide down the outer spiral of the auto mix-dial ,
Put the housing back on with the auto mix dial set to heavy traffic, but make sure no tubes are trapped or this will stop the flow of water,
i hope you can under stand what i have wrote ,Goodluck
Posted on Nov 29, 2007
SOURCE: Smart Mix selector
I figured it out,since you nor Bissell was of no help. It turns out to be quite easy.
Posted on Jul 22, 2008
heatman101
  • 43501 Answers
SOURCE: replacing smart mix plunger bissell proheat
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 04, 2010
BissellCSR
  • 276 Answers
SOURCE: lost instruction book for my bissell pro heat turbo deep clean
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Posted on Sep 09, 2010
heatman101
  • 43501 Answers
SOURCE: FILLING INSTRUCTIONS. I HAVE A BISSELL PROHEAT
heatman101
Posted on Sep 23, 2010
Basic how to use instructions.
1. Step on the handle releae pedal and lay the handle back.
2. Remove the tank and take it to thesink.
3. Remove the top cover cover and fill the plastic bladder with water only.
4. Replace the tank.
5. Your 'Smart Mix' (shampoo) bottle is on the operator's right in front of the machine. Remove it and fill it with Bissell shampoo.
6. Shampoo is automatically mixed with the water as you dispense it depending on how your 'Smart Mix' Knob is adjusted.
You can download your complete maual here:
http://www.bissell.com/searchresults.aspx?searchtext=1698&mode=userguides
May 20, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Replacing smart mix plunger bissell proheat model 7901 procedure for proper installation
heatman101
May 17, 2010 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell proheat 1698 reassembly, smart mix piston, new pump?
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101
erqtr
Mar 01, 2009 | Bissell 1699 ProHeat Clear View Upright...
Smart Mix selector
Jul 20, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bex Bissell Pro Heat 7920-E
Remove the cap for the flow indicator, then there 6 screws to remove to take off the top, before removing the top, turn the smart mix valve to about the half way point so the piston won't fall off. When you are ready to re-install the top cover, just before pushing it all of the way down, turn the smart mix valve to the water only setting, then push it into place, re-install the screws and the flow indicator parts.
May 27, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Problems--No solution spray
Is the smart mix valve turning and stopping where is is supposed to, if it turns all of the way around, then it is broken inside the top cover. Try replacing the smart mix bottle insert and cap asm part #2101795 . Make sure that the rubber gasket is on the valeve asm. at thebottom of the smart mix bottle. If not, it has to be on the valve.
May 19, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Removing the top of the 7901-1 Bissell Proheat
Unscrew the cap for the flow indicator, remove the 6 screws, the top will come off. When you put the top back on, make sure the piston is hooked on the smart mix knob(underneath the top cover) set the smart mix valve in the wtaer only setting, then put the top back on. Turn the smart mix valve to make sure it is turning like it should, then re-install the 6 screws and the flow indicator parts. (don't over tighten the screws)
May 16, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
MY BISSELL DOES NOT WORK
When you put the top back on, did the piston line up and go into the hole? The piston mounts on the smart mix knob from the bottom, just before the top is on, put the smart mix knob in the water only setting, then push the top down. You could also have pinched a line if any of them aren't in the right place.
Mar 17, 2008 | Vacuums
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
526 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
