Question about Bosch Dishwashers
I think I need to check the water pump/motor on my Bosch SHU43C dishwasher. It seems the water enters at the start of the wash cycle but then there is silence through the remainder of the cycles. Water will not spray. The drain appears to work ok to drain most of the water out. I have the washer out and upside down. Any hints on removing the base to get access to the pump? Should AI be looking at the control panel also for a fault? (the cycles seem to count down ok)
  • jeff128 Aug 03, 2008
    How do I access the pump/motor and the control board?
  • 2,071 Answers
Click below;
Latest Bosch Dishwasher Use and Care Manual May 4th, 2008 by Samurai Appliance Repair Man For Models: SHE44C / SHE46C / SHE47C / SHE56C / SHU43C / SHX46A / SHX46L / SHX43E / SHV46C / SHE43F / SHE43M / SHX43M / SHE45M / SHV45M / SHX45M / SHE55M
In case you lost yours, you can borrow my copy. Just be sure to return it when you’re done. Domo!
If’n you need parts for your dishwasher, come git you some! And if you’re having a problem with it, come start a new topic in the Samurai Appliance Repair Forums and that bad boy.
hope this may help;
Regards;
VOTIT
Posted on Aug 03, 2008
  • LORETO LACARON
    LORETO LACARON Aug 12, 2008
    did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further
  • LORETO LACARON
    LORETO LACARON Aug 21, 2008
    latest updates of the thread problem...
    Genius:
  • 1,847 Answers
Seem issue with the water pump
  • Legin Varghese
    Legin Varghese Aug 03, 2008
    Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
    Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
  • 13,433 Answers
Read this page, it may be helpful to you
http://www.repairclinic.com/0088_9_1.asp
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Bosch Dishwasher model SHU66C06 doesn't enter wash cycle
this sounds like flow sensor failure,it it fails machine will either not fill up or fill and drain without washing its a cheap part to replace and is fitted downstream of inlet valve behind l/h/s side panel either attached to inle hose or heat exchanger.
Mar 03, 2017 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch Integra SHU 9955US/12 - when we start wash cycle, the detergent dispenses and the tub fills with water, but the wash cycle never starts (never spins spray bars). Seems like timer is counting down,...
Sounds like your motor is burned out. The drain motor and wash motor are seperate on your machine. You can check for power going to the motor, but to do this you might have to pull the dishwasher out. While the cycle is running check for 120 VAC going into the motor. If you are getting power and nothing is happening, you will need to replace the motor, otherwise you will need to replace the motor control board located at the base of the machine.
Jan 31, 2011 | Bosch SHU9955UC Built-in Dishwasher
The water does not circulate throughout the washer. Is the pump bad? The full cycle will run without cleaning.
Before we jump to conclusions, you can try to clear element that discharges the water. The wholes in these units can become clog do to the detergent as well as food. Most Bosch units allow you to unscrew these pretty easily. Blow through them, or use a plastic tooth pick to clear any obstructions or both. Before you reattach, turn on dishwasher and listen to hear how much water is shooting out at the discharge points. Most Bosch have two discharge points one for the top and of course one for the bottom. Reattach units and Run dishwasher.
Should this fail it could very well be the circulating pump.
Oct 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My Bosch SHU43C will sometimes make a loud noise
It may be more cost affective to just replace this unit. the circulation motors that are used in these dishwashers are not reliable. the wash impellers seems to have issues dealing with staying attached to the drive stud and shaft. this will cause the impeller ti shift inside the housing, causing noise and jams.
A new circulating impeller kit will cost about 100 dollars and, labor for this type of repair is 80 dollars an hour.
Jun 21, 2009 | Bosch Dishwashers
Bosch SHU43C installed in 2003
My Bosch SHU43C had the same exact problem. I found the below solution on this site. Perhaps you already seen it.
My SHU43C is just over 3 years old. I had a similar problem recently. First, there were a few floods. Then, the Bosch only drained non-stop. Even when I used the Cancel Drain buttons the drain pump would run without stopping. When I tried to run one of the cleaning cycles, no water entered the machine. Corrective: I removed the base plate, and saw that the red plastic floatation device was in the up position. Using a flashlight and a wooden spoon, I lightly toggled the red float stem down. I pushed regular clean cycle and kept toggling with the red float stem until the rinse water started to enter the machine (turning the red stem seems to also actuate a step in the program). Now the dishwasher runs normally. Voila!
Aug 07, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43C
Jun 22, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHU43
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door. Mine is a BOSCH 5316.
The draining problem may mean a clogged drain hose -- you have to check it all the way back to either the main drain or the garbage disposal (if you have one). This may be what forced off the impeller wheel.
Nov 15, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
466 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
