FranklinCovey PlanPlus for Windows has encountered a problem and needs to close. We are sorry for the inconvenience. ProductName=FranklinCovey PlanPlus for Windows Version=1.0.3156 OSVersion=Microsoft Windows NT 6.0.6002.0 Service Pack 2 (NonTabletPC) Details=Requested value None was not found. (System.ArgumentException) Stack= at System.Enum.Parse(Type enumType, String value, Boolean ignoreCase) at System.Enum.Parse(Type enumType, String value) at Agilix.Binder.BinderForm.I() at Agilix.Binder.BinderForm.Initialize() at Agilix.Binder.MainApp.A(Boolean A_0, String[] A_1) at Agilix.Binder.MainApp.Run(ArrayList apps, String[] args)
  • 7 more comments
  • Ziv Azmanov Mar 23, 2011
    Please help me resolve this issue with Franklin Covey PlanPlus for Windows PC ver 5.1
    Please see the details below.
    Thanks in advance,
    Ziv.
    Version=1.0.3156
    Details=Requested value Noneꮫ was not found. (System.ArgumentException)
    Thank you for the prompt response. I appreciate your time and efforts to resolve my issue.
    To answer your questions:
    - I'm using Windows Vista SP2
    - The application, FranklinCovey PlanPlus has been working fine on my PC for more than 2 years.
    - This issue started today for the first time.
    Please see the following error message that I received:
    Version=1.0.3156
    Thanks in advance.
    No. I'm afraid of losing all my information that's stored in this application.
    I've tried to repair the installation (using Control Panel -> Program and Features).
    Thanks.
    There is an auto backup utility for this application. However, I don't know where the backup file is stored once the backup is completed.
    Thanks. Do you happen to know where they are normally located on a Vista PC?
    Also, the other problem with re-installing is that I don't have a disk for this program. I purchased it online and downloaded the files directly to my PC. Do you know how I can re-install in this case?
    Thanks again.
  • Ziv Azmanov Mar 24, 2011
    Thanks.
    I re-installed the program last night, and again this morning.
    However I still have the same problem.
    Do you have any other suggestions?
    Thanks,
    Ziv.
    Yes. Actually, I was just able to fix the problem. It turned out that the database was somehow corrupted. I had to remove it and create a new one.
    Nevertheless, thank you much for your suggestions, time, and effort. I greatly appreciate it.
  • Tina Carter Aug 21, 2012
    I just recently converted to Windows 7 and when I try to open Franklin Covey version 5.1 for Windows, I get the following error and it closes:ProductName=FranklinCovey PlanPlus for Windows Version=1.0.3156 OSVersion=Microsoft Windows NT 6.1.7601.0 Service Pack 1 (NonTabletPC) Details=Cannot find font 'Tahomar'. (System.ArgumentException) Stack= at System.Drawing.FontFamily..ctor(String name, FontCollection fontCollection) at System.Drawing.FontFamily..ctor(String name) at Agilix.Binder.Controls.FontHelper.GetSafeFont(String fontName, Single fontSize, FontStyle fontStyle) at AgxBdrCO.X() at Agilix.Binder.BinderForm.AL() at Agilix.Binder.BinderForm.Initialize() at Agilix.Binder.MainApp.A(Boolean A_0, String[] A_1) at Agilix.Binder.MainApp.Run(ArrayList apps, String[] args)
  • 2,632 Answers
Welcome to Fixya. Can you provide the information needed to fix the issue.
- What operating system you are using?
- Is it working before on that computer?
- Any changes that has been made before if happens?
If you have questions please let me know. Thanks for using Fixya
Posted on Mar 23, 2011
  • 7 more comments
  • Rofel Lantican
    Rofel Lantican Mar 23, 2011
    Did you tried to resinstall the program?
  • Rofel Lantican
    Can you make a back up of the files that are stored on the application because we might fix it by reinstalling the application.
  • Rofel Lantican
    Please read below. It seems that the files will be saved on the .pst files.
    Click Here
  • Rofel Lantican
    If the file was saved on the pst it will still remain there.
  • Rofel Lantican
    it really depends on where you save the pst file. you can try to search your computer. Usually you need to reinstall the program if it is not working because some registry files got corrupted. try to search for .pst on your computer
  • Rofel Lantican
    FranklinCovey PlanPlus for Windows Download
    Can you try to use this one. By the way before you uninstall the program make sure that you have the backup ok?
    Thanks
  • Rofel Lantican
    And if you need help on backing up files you can refer to the link of the support below.
    They can help you to located and how to backup the files.
    FranklinCovery Plus Support
    If you have further questions please let me know.
    Thanks
  • Rofel Lantican
    Rofel Lantican Mar 24, 2011
    Hi - are you using the program on the same machine? Same operating system when it is working properly?
  • Rofel Lantican
    No problem. Thanks for using Fixya and have a blessed day.
    Brigadier General:
  • 3,513 Answers
Hi
Please check the bellow link to get a detailed idea related to your issue:-
http://support.microsoft.com/kb/293623
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
  • 1,555 Answers
Here's two ways to turn off that error reporting. First, you can Right-Click on My Computer, go to the Advanced Tab, and choose the "Disable error reporting" option.
Alternatively, you can navigate to the services console in Administrative tools, find the Error Reporting Service, go into properties and disable it.
Restart your pc and then try to run your app.
Yahoo! Messenger has encountered a problem and needs to close. We are sorry for the inconvenience.
Welcome to FixYa! Are you using window blinds or alienguise or some other window enhancement program? Examples are programs that add extra buttons like transparency and keep always on top or change the look of the windows in anyway (not including standard XP themes), if so disable it and yahoo should work.
Do a search on http://www.wackyb.com for window blinds as it's discussed there often :)
This is sometimes a flash issue, make sure you have download and installed flash from Internet explorer (not any other browser)
http://www.adobe.com/shockwave/download/...
Still having problems try Common Issues/Tips & Tricks here:
http://www.wackyb.co.nz/Yahoo!_Messenger...
Hope this helps! Thank you for using FixYa!
Jul 04, 2011 | Yahoo Messenger
WMI has encountered a problem and needs to close. We are sorry for the inconvenience.
This is not unusual, Sometimes the software encounters a order that it cannot follow and looks into its error data and sends this message. It maybe a problem downloading an update from Windows, it could be a virus encounter, it could be malware ( Advertisers hijacking your desktop). If it occurs often, then you need to clean somethings out. See: http://social.answers.microsoft.com/Forums/en-US/xpperformance/thread/bb4e514d-9afc-41ba-b926-366d2da5e65e
Dec 07, 2010 | Microsoft Windows XP Home Edition for PC
Windows Explorer has encountered a problem and needs to close. We are sorry for the inconvenience.
You have a nasty virus. Don't even bother trying to clean the pc, just reinstall Windows directly.
Nov 01, 2010 | Computers & Internet
Computers & Internet Logo
625 people viewed this question
David Payne
David Payne
