Question about Ovens
Need a manual sylvania microwave oven 23FJ - Ovens
I just got an old microwave and don't now how to use it. Please is there a way to find a user manual? National Dimension3 Microwave/Convection oven
Try the Panasonic website below. National became Panasonic a number of years ago. I just went there and did a search for demension 3 under microwaves and it definitely has a few results for instruction manuals. You will need your model number (most likely on the back of the oven)
http://www.panasonic.com.au/Support/Customer+support/Downloads+and+documentation
Good luck :)
May 04, 2011 | Ovens
Can we use non stick pan in a microwave?
Non-stick pan I think may be surely made of metal. Its always
advised not to use metal pans, dishes, spoons etc inside the
microwave oven. Metals are mainly avoided due to the effect
of the microwaves on the metals.
These ovens uses the microwave radiations generated from a
magnetron. The microwave radiations are reflected off by the
metal surfaces. So if you use metal pans inside the oven, they
act as a microwave antenna that reflects back the radiations to
the magnetron and can cause damage to your oven. Another problem
with the metals inside the oven are due to arcing effect.
The atoms in the metal are ionized and the air gap near them lead
to a lightning like discharge of energy causing sparks. This can
easily cause a fire inside the oven since the food materials may be
easily ignitable under that temperature.
Alternatively you could check the manuals of your oven to confirm
the type of dishes that can be used to cook inside. If no
user manuals are available check manufacturer website.
Considering the safety, its a "No" to use metal pans inside the oven.
Dec 26, 2010 | Ovens
I am looking for a Manual for a Litton Microwave Oven Model 560
Try this site for your manuals.
www.laundrymanualsonline.com
Hope this helps.
May 19, 2010 | Ovens
MY KITCHEN SUPERBA MICROWAVE/CONVECTION OVEN BEEPING IS ANNOYING
Sorry, I have the same oven and the same complaint. The manual doesn't indicate anything. BTW- the service manual is inside the oven frame, between oven "lining" and the outside sheet metal.
Jan 03, 2010 | KitchenAid 27 in. Built-in...
Jenn-air microwave light bulb
This is an older (Mfgr. May, 1987) microwave oven. Functions perfectly, works an looks good to this day, just no light inside. I searched a couple of websites looking for parts for this unit and appliancepartspros.com provided schematics of the product that I own. From those drawings, it was determined that the microwave oven will have to be slid out of the cabinet above the built-in oven in order to change a $2.37, 40W light bulb. Just a handfull of scrws retaining the oven and exhaust baffles and I'll get it out (onmce the New Year's Eve hangover disappears). The engineer who designed a system like this must have been on an Acid Trip. I haven't looked closely at newer microwave ovens, but I'd have to believe changing a crummy light bulb would have to be made easier than this during the preliminary engineering phase of design.
Dec 31, 2008 | Ovens
Microwave Oven Manual
Why won't you help for free
Aug 08, 2008 | Ovens
Whirlpool RMC305PDQ1 Oven-Microwave Combo Unit
is this model mounted over the oven as one piece unit?or does it hang above the stove?
Feb 20, 2008 | Whirlpool RBS275PD Electric Single Oven
big job belive it or not the oven will need to be pulled to change it please post your email and i will send you the manual
Jan 24, 2008 | Ovens
Ovens Logo
157 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
