Question about Samsung Audio Players & Recorders
Hello. When we turn on our DVD player, it all of a sudden does not work. IT says "welcome" and OPen, but all at once flashes "protection" and shuts itself off. How can we fix this problen? Your help would be greatly appreciated. Thanks Lana
  • Samsung Master
  • 17,130 Answers
This is an error message which indicates that there is a hardware error on the circuit and needs correction and replacement before the feedback will reset the processor.
So you will need to disconnect the drive sections and see if the error message changes. If not there are shorting within the main board and needs a confirmation by elimination and voltage checking.
Posted on Mar 23, 2011
Power Acoustik DVD headrest shows blue screen/red welcome on start, won't play
sd sa dsa das dasd as fasf as
[url=http://www.rezibis.com/]headrest monitor[/url]
[url=http://www.rezibis.com/]headrest dvd player[/url]
Jan 02, 2013 | Car Audio & Video
Dvd door won't open
Someone is going to have to open the unit to see what is happening--either a disc is jammed inside or a mechanism problem.
Sometimes with unit apart you may be able to gently probe and free the jammed area--possible also something that does not belong there got inside--look closely.
Jun 16, 2012 | Daewoo DV6T-81N DVD Player / VCR Combo
Dvd player wont eject
Unplug the DVD player and disconnect all other attachments, press and hold power for 2 minutes to remove all residual voltage in hopes of a microprocessor reset. If this works the DVD should work normally.
Apr 20, 2012 | Zenith XBV443 DVD Player/VCR
Check disc
The DVD player's laser pickup assembly is intermittent and since it is brand new and under warranty take it back for replacement. There should be no issue with your TV set.
Mar 18, 2012 | Televison & Video
Dvd drawer won't open
stick tip of pencil in tiny hole just under the drawer
Dec 30, 2011 | Sony RDR-VX560 DVD Recorder/VCR
Hi I would like a little help to update the firware dvd blu ray bd 8002 Marantz tell me how should I do? thanks you.
Hello
Enter these sites for fudate your Maranz.
www.buyblurayplayers.com/firmware-updates/how-to-update-your-firmware
www.avforums.com/.../765663-marantz-firmware-updates-sr7002.html - United Kingdom
softwaretopic.informer.com/firmware-update-tool/
I'll ge you some hints also
Open the Internet browser and navigate to the Marantz.com website. Select "Products," then choose "DVD Players."
Select the DVD player you are currently using, then select "Manuals and Downloads." This lists all of the available updates for the Marantz DVD player.
Click the software update to download to your computer system
Plug the USB flash drive into a USB port on the computer, then click "Start," "(My) Computer," then double-click the removable device icon. A window loads with all of the files stored on the flash drive.
Click-and-drag the software update into the open window, then close the window, right-click the removable device icon and select "Eject."
Disconnect the flash drive from the computer once the icon disappears.
Plug the USB flash drive into the USB port on the rear of the Marantz DVD player, then power on the device. The software update will upload onto the DVD player. A prompt on the television screen appears once the update has finished.
Mar 20, 2011 | Marantz BD8002 Blu-Ray Player
Dvd player will not eject or play dvd. It just keeps spinning and says "reading." I've tried unplugging for 2 minutes, pushing close/open and stop at the same time(hold for at least 3 seconds)....
Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray. Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.6 Jan 2013
Solved: DVD is LOCKED will not eject. please help. Manual ... - the ...
https://community.sony.com/t5/Home-Theater.../DVD-is...will-not-eject.../td.../55919.
or try this link. Dvd player will not eject or play dvd Google Search
Oct 18, 2017 | RCA DRC8295 DVD Recorder/VCR Combo
No power; no lights will come on. I was watching a recorded DVD and then all of the sudden it turned off and will not come back on.
The reason the DVD went off was because it was exposed to a high current and the power pack got burnt during the process.
To fix this, you have to get the appropriate screw driver, open up the cover of the player,
You will see the power pack, if it is covered, open it up and if it is not just go ahead and test the capacitors with a meter reader.
You will discover some burnt capacitors.
Disconnect the power pack, get another power pack and replace the old one, and the player will be okay once again.
Take care
Jun 14, 2010 | Emerson EWR20V4 DVD Recorder/VCR
HELLO
i had the exact same problem yesterday (4/8) and just playing with the open/close button several times the drawer finally opened completely and closed like it should. i then did the reset sequence and all is back to normal
Apr 03, 2007 | JVC XV-S500 DVD Player
77 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
