Question about Fujitsu Siemens Amilo Pi1505 Laptop Universal AC Adapter 18-20v (AC22VPNNP5WC3)
Fujitsu Amilo 1505 keyboard removal to fit memory upgrade
IB4G2008
  • 3587 Answers
SOURCE: laptop memory
hmmm..ok...try them one at a time, and make certain that the laptop can id each of them. if that works, swap them in the sockets..if that does not work, then one of your sockets is unhappy.
also, use F2 when loading up, and see if memory is present in system setup screen..be careful in there, of course, since it's the nerve center of that whole computer.
Posted on Apr 27, 2008
micromaster
  • 3614 Answers
SOURCE: memory slots
Switch your notebook off.
► Close the LCD screen so that it locks into place.
► Unplug the mains plug of the mains adapter from the mains socket.
► Disconnect all cables connected to the notebook.
► Turn your notebook over and place it on a stable, sturdy, flat surface. If necessary, lay an
anti-slip cloth on this surface to prevent the notebook from being scratched.
► Remove the battery
if you need manual click HERE...
Posted on Jun 20, 2008
  • 30 Answers
SOURCE: Keyboards
Yes, Amilo Keyboards are compatible with each other.
Posted on Jul 14, 2008
Geekman
  • 32281 Answers
SOURCE: Where the procesor is located in Amilo A7640?
The CPU is located under the heatsink/ fan assembly.
Posted on May 09, 2009
  • 5 Answers
SOURCE: how to open the back panel of fujitsu AMILO D 7820
u can use the software herionee to change the password ...if not use the guide which is given to u with the lptp t
Posted on Feb 05, 2010
Fujitsu Amilo Pi 1505 25-03-2010 I have a Fujitsu Amilo Pi 1505 Laptop. The screen goes black when viewed at normal angle, when lowered at 45 degrees it comes on. We opened bottom cover and removed the...
With so many questions that really relate to your dexterity and skills! Who can best answer your questions! Yea that person in the bathroom mirror is the only one that will show the fortitude and trail blaze the way. Then boast of their success!
Mar 25, 2010 | Fujitsu AMILO Pro V1000 Notebook
How to change and upgrade the memory Fujitsu-Siemens Amilo Pro Fujitsu-Siemens Amilo Pro V2010
on the bottom of the laptop is a square plate with 1 or 2 screws, when the laptop is off, remove those screws and you should see your laptop memory, gently expand the two thin metal clips on either side of the memory and it should pop up at an angle, gently remove it and replace with a larger capacty memory module.
Nov 18, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
How do you remove the keyboard from a Fujitsu Siemens AMILO Pi 1505
35aca84.jpgPrise up the keyboard using a blunt knife,there is a metal plate below the keyboard held by clips, the keyboard will pop out giving access to the memory slot below,the keyboard can then be pressed back in place to re-locate the plate on the clips! I used a a knife from a dinner set that has a round blunt tip!
Nov 18, 2009 | Fujitsu Siemens Computers & Internet
Keyboard replacement instructions for fujitsu siemens amilo pro v2010
The keyboard removal process is very similar to many other laptop brands.
1. Remove screws securing the keyboard.
2. Remove keyboard bezel.
3. Unplug keyboard cable from the connector on the motherboard.
A word of caution. Be very careful with the connector on the motherboard when you unlock it If you accidentally break the connector, you’ll have to replace the whole motherboard.
You can even try this site http://mycapsules.com/disassembly/fujitsu-s2110/keyboard
or this site
http://www.amilo-forum.de/topic,1056,-Arbeitsspeicherwechsel-RAM-bei-Amilo-Pro-v2010.html
It is not your model but it will give you an idea.Just keep pressing "next"
Hope it helped.
Aug 03, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Memory uprgrade
You have to remove the keyboard, under the keyboard to the left is a heat shield (silver metal cover), remove it. Your ram is located there. Just take your time and remember where the screws go.
Jan 22, 2009 | Fujitsu Siemens AMILO Pro V2010 Notebook
Replace keyboard for fujitsu siemens amilo pro v3515
Hello Den,
1st remove the Battery ..u will find screw below the battery ..unscrew it and then remove the blastic bar above the keyboard which contain the power ,wireless..etc Keys ..afterthat u can remove the key board and replace the new one...
Best luck
Nov 30, 2008 | Fujitsu Siemens AMILO D-7830 Notebook
Upgrading my fujitsu amilo pro v2010
Hi Brian,
It's not a problem as u think..
Yes your Ram is 256 M.B // but your Vga Card is built in the mother board with 64 M.B ..so it's share the Vga card Memory from ur basic ram (64 - 256 = 190~192 M.B) .
So u just need to increase ur rams by new one or replace this ur current ram by 2g.byte ram .
best luck.
Nov 29, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Keyboard Problem
My advice would be tp return to the purhaser as if you mess about with the keyboard and really damage it then your warranty will be void.
Feb 25, 2007 | Fujitsu Siemens AMILO Pro V7010 Notebook
Fujitsu Siemens Amilo Pi1505 Laptop Universal AC Adapter 18-20v (AC22VPNNP5WC3) Logo
87 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
