Question about HP ProBook 4710s Notebook
How to start disassemble hp 4710s laptop? My kayboard doesn't work properly. I think that there is dust on some of the contacts inside
Hp 4710s webcam shows the pictures upside down when it is active
Open the Webcam software, click on the Tools Tab, or Settings, and flip your webcam's image right side up.
Nov 17, 2012 | HP ProBook 4710s Notebook
My hp 4710s laptop right click not working
change touchpad in service. cheap repair - use usb mouse - wired or wireless
Oct 25, 2012 | HP ProBook 4710s Notebook
Hi, my HP Compaq Presario has been working great till the 5th of July when it shut down unexpectedly. I instantly turned it on again and shuts down again after booting up. I waited for about an hour, then...
Due to the heavy processing the PC heats up. Excessive heatup beyond usual is alarming and PC shuts down by itself when the processor/ CPU temperature exceeds the safe temperature limit. There are mainly two reasons for heatup.
Heating issue generally occurs due to fan failure, which may damage the system, if not checked and resolved properly. Another most likely cause of overheating is the dust present inside the PC, which clogs the fan and heatsink. As you have mentioned that the fan is not running, most probably the fan has gone dead or it may have stopped working due to clogging with dust and hence it needs cleaning or replacement. To do so, you need to purchase a new fan and disassemble the laptop to replace the fan.
To replace the fan, you have to disassemble the laptop and for that you need to have the laptop repair manual that can be downloaded here.
(I think that you have HP CQ60-419WM Laptop). The repair manual contains all the information as well as graphic illustration about disassembling and replacing the fan. Please refer to Page 4-41 for complete details.
If you are able to work inside such electronics and have some disassembling experience, you may try to do it yourself. However, if you have no experience, it is strongly recommended that you seek professional help from HP authorized repair/ service professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 06, 2011 | Computers & Internet
My toshiba netbook doesn't start
Check to see that the battery is properly in place and installed into the bottom of the laptop. If so, try cleaning the contacts with a dry cloth (never wet, water and electricity don't mix well!). If this doesn't work, unless you're a professional, do not disassemble your laptop. Bring it into a professional to get it checked. (Preferably where you bought the laptop)
Jun 22, 2011 | Toshiba Computers & Internet
How to disassemble an hp probook 4410s?
Welcome to Fixya. If you want to disassembel the HP ProBook 4410s you can use the link below. It shows how to remove the parts of the notebook.
HP ProBook 4410s Parts Replacement Guide
If you have questions please let me know. Thanks for using Fixya.
Apr 07, 2011 | HP ProBook 4710s Notebook
Have probook 4710s and forgot system password is there a software to clear cmos thanks
Dear User,
Please You need to remove the RTC battery which is on system board then start the system to reset the password.
Regards,
Tech_Comp
Feb 24, 2011 | HP ProBook 4710s Notebook
Left shift key and caps lock is not working
hi
there is a kayboared tester software on google just downlod and chack the your kayboard
some time dust stucks you keyboard frist just try to clean with bolower then try
Jul 11, 2010 | HP Pavilion 110-1030NR Notebook
HP ProBook 4710s Notebook Logo
1,147 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
