Question about Hotpoint NWSR483EBWW Electric Dryer
Timer spins does not catch to innitiate timing timing mechanism broke...
  • 122 Answers
Check the knob to see if it is split or cracked.. If not then you need a new timer.
Posted on Mar 23, 2011
How do I replace the timer knob on Speed queen AWM351W-3062 ?
The problem may be mechanical failure of the timer rather than the knob, especially if you have to push or pull to start washing.
Aug 20, 2016 | Speed Queen Washing Machines
Why can't I hear the timer ticking?
The timer, if it's the mechanical type that you have to push in the knob to select cycles, then pull out to start, is *not* repairable. From what you are describing, it sounds like the internal mechanism had broken and the timer needs to be replaced. There is a specific, small procedure for removing the dial and replacing it on the new timer--if you are unsure on how to do this, get a qualified tech to do it--otherwise you run the real risk of breaking the mechanism in the new timer. I hope I helped you!
Aug 10, 2015 | GE Washing Machines
How can I fix the lid of the washer comes down to close and it pushes down on a mechanism that allows the washer to drain and spin, that mechanism how can I fix it ? broke
If it is a top loader you will need to raise the top lid. There should be two spring catches in the front joint about 3 inches in from each side. The springs need to be pushed in to release the catch. with a screwdriver or perhaps table knife or with another thin blade tool. Once the lid is raised you should have access to the problem device. It's possible it has become bent or misaligned. or wire connection apart or badly corroded. Electrical connections need to be cleaned to bright metal. Otherwise, replace the broken device and or switch.
May 07, 2015 | Kenmore Washing Machines
How to trouble shoot maytag timer nob
There is still water in the machine , the pressure sensor my not be operating there is a loose contact in the motor spin winding or the timer no supply voltage is going to the motor check the votlage at the motor at spin cycle
Sep 20, 2012 | Maytag SAV3710AWW Washer
Bobbin won't spin to allow needle to catch thread
sometimes when you break a needle it can cause the machine to
jump time, the machine would have to be taken to a sewing machine
shop to be checked by the technican
Aug 17, 2012 | Singer Inspiration 4210 Mechanical Sewing...
Ge washing machine timer plastic clips broke
go to the manufactures website and request this clip from them or go to a scrap yard and look for the same machine to take the part out of it to replace yours eric
Dec 27, 2017 | GE Washing Machines
Spin cycle is not emptying completely the basin. clothes are relatively wet.
Put it in spin (empty) with the lid open and push the lid switch. If you see that it agitates while it is going into spin, that means that the "catch" inside the transmission is broke. The "catch" is supposed to lock the mechanism to the spin basket while in spin. The only thing you can do is replace the transmission or buy a new machine.
May 20, 2011 | Maytag PAV2300 Top Load Washer
My whirlpool model/LSR8233JQ1 will not agitate or spin ut does everything else. already bypassed lid switch years ago because it broke,its still connected.
1. you possibly have a malfuncitoning timer
the timer is the control to the motor and the pump on a washer and each click represents function to the components on the washer such as the spin cycle ( the motor engages to spin the drum to extract the water to the pump at a given time on the timer.
Your machine need a service tech to determine this issue.
I hope this helps.
Jun 14, 2010 | Washing Machines
Whirlpool Gas Dryer Timer problem
OK, this timer is designed to spin in both directions and, if you have to advance this timer in any way to complete a cycle, you will need to replace this timer asap.
In most cases, the mechanism will fail, causing this non advancement stage(stalled timer mech).
replacing the timer will fix this issue.
Jun 01, 2009 | Whirlpool GEW9250 Electric Dryer
Timer knob
HI. the timer mechanism has failed. these timer control modules will run about 134.00. simply replacing this timer will fix your issue.
May 28, 2009 | GE Washing Machines
Hotpoint NWSR483EBWW Electric Dryer Logo
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
