We have a TCL LCD TV No. L26E62AZ. All channels have been installed and are listed on the main menu. However, recently we have encountered a problem with Channel 9, 99 and 90. We are receiving picture but no sound. All other channels are working successfully. Can you suggest a solution to this problem?
  • 19,396 Answers
Hi.
The problem used to happen with certain receivers that are confused by digital broadcasted signal.
Try the following:
1) Reset the receiver box to factory settings and do a rescan. If receiver is built in with TV, simply do a rescan.
2) Call the provider and ask if they are aware of the problem. They usually are, since the problem depends on TV provider signal not working with certain receivers.
3) Check if a firmware update for the receiver box (or TV if directly connected) is available.
4) If there is no better solution, see if there are duplicate of the same 9 channels in different positions.
In this example with Go Australia the "9" channels where duplicated in positions 350-352.
Alternatively delete manually the nr.9, set the channels as skip, and re-program manually the channels in different positions. Procedure depends on the receiver used.
Regards.
Ginko.
Posted on Mar 23, 2011
2 Suggested Answers
  • 11800 Answers
SOURCE: We have a TCL LCD
You didn't said what were those channels and of what type (analog or digital), where you live or what cable company you use. Without any information i can only say that the problem is not with your tv - otherwise it would have affected all the channels, not just a few.
Most likely something in the settings of those channels has been changed : they switched to a different coding system (NTSC instead of PAL), they might have been transformed from a free channel to a paid one, or they might have changed their security code and the cable company hasn't upgraded theirs yet.
You will need to contact your company and ask them what changed and then, if possible , made the appropriate modification on your side.
Posted on Feb 12, 2011
Find the channel to run DISH
Channel 3 is normal for that. Always have it on channel 3 on the TV set. Then you can work with it. Check your stuff and see is there a switch to set for channel 3 or 4, if none present, put it on 3, then start from the menu to set it up with remote.
Oct 07, 2014 | TCL 39" LED LCD 1080p HDTV - TVs & Home...
My tcl L26E62AZ tv specification
Refer its user manual for details. Electro help
Sep 14, 2014 | Televison & Video
Unlock TCL-21276 child lock without a remote please help
Okay Welkins, try to power of the tv and power it on by keep on pressing POWER-BUTTON and MENU-BUTTON at the same time,... and see if the tv start into de menu mode....if it does...just keep on using volume "up and "down" button combined with channel "up" and "down" buttons to select an reach the UNLOCK-MODE...most of the time the MENU button will be the enter button after each sellection....hoping to inform you correctly I remain,Yours Friendly.
Mar 06, 2014 | TCL L32HDM11 32 Class Widescreen LCD HDTV...
TCL LCD TV L24D10F Channel locked; need password
how to upgrade my tcl lcd tv l24d10f? can u give me a firmware?
Oct 24, 2011 | Televison & Video
Only channel 9 no picture but got sound in LCD TCL BRAND
Make sure in the menu that you are using cable instead of antenna - then do a channel scan if you are using a coax and not thru a cable box. Have you tried any other inputs to ensure they are working properly? Please reply if you need additional assistance.
Thanks,
Michael
Feb 25, 2011 | Panasonic TCL42D2 42 in HDTVReady LCD TV
I bought a TOSHIBA 32KV500B tv. At the Initial Installation mistakenly I selected "yes" for 'do you want to search analogue channels?' guestion. And then I lost all my automatically selected...
I had this problem and searched the internet for hours looking for an answer and was given the initial same reply as this and it does not work. To solve this problem all you simply need to do is press source button on the controller followed by pressing the DTV/USB option. All your digital channels will come back to you and you will find the menu setup options you are looking for!!!
Feb 12, 2011 | Toshiba Televison & Video
I have a TCL L42M61AZ LCD TV. I find that the "Channel 9" programs in Adelaide, Australia, namely GEM, GO and Channel 9 DTV will not show a visual picture, only play audio. All other programs are...
A firmware update from TCL will fix the problem. Call them and they will send out the firmware and a serial cable (required for update) for free.
I did the update yesterday and it fixed the problem (sound but no picture).
You will need a PC or laptop with a serial port (RS-232).
Jan 26, 2011 | Televison & Video
Toshiba tv 32kv500b, when tryin to install channels came up no signal, checked aerial cable but cannot get back to the installation menu which came up in the beginning, when press menu button a smaller set...
I suspect you are seeing the Main Menu for the source that you are currently using. Press the Source button (TV/AV on the TV itself) and make sure you are on TV source. The menu will have a set of icons if it is set for analog and a vertical list in digital. Select Setup (use the up/down arrows for digital and the left/right for analog - it's the first one in the list) and click OK. Then select Installation (third one in the list) and then press OK. Next select Automatic channel scan (first one again) and press OK. You will see a warning prompt, highlight Yes and click OK to scan for digital channels. When it is done, it will ask if you want to scan for analog channels.
The manual is available here: http://www.toshiba-om.net/LCD/PDF/English/Country_Specific/KV500-32-English-Specific.pdf (direct link to the pdf)
I hope this helps.
Dec 16, 2010 | Toshiba Televison & Video
Televison & Video Logo
178 people viewed this question
Top Televison & Video Experts
