Question about Symbol Motorola MC3090 Handheld Computer
I have 4 guns(MC 3090) that lose their static IP address when i remove the battery.I have exported the file as well as exported all profiles and still i lose the Static IP address.What can i do to correct this problem
2 Suggested Answers
SOURCE: wireless configuration problem. It lost parameters I had imposted.
If you are using a MC909X, after entering the static IP address and WEP key etc. via the Wireless Configuration Editor, you can export the profile you created by going to the Manage Profiles area, tapping and holding the profile name until the menu appears, then select export, it will create a registry file in the Application folder of the device that will persist after a cold boot, and the settings will will not be lost.
Posted on Nov 06, 2008
Where do I assign a static IP address on the scangun
Al-
It's best you contact Motorola Solutions.
portal motorolasolutions com
Mark
Motorola Mobility Support
Aug 21, 2014 | Motorola MC9190-G Handheld Mobile Computer
Lost my IP address from zyxel
According to me there are two reason for not connecting to internet through your ISP.
1. Configuration setup might have got deleted
2. Driver files may be corrupted
An important thing to know is We would not lose our IP address.
Static IP address wouldn't be changed while restarting our modem,
Dynamic IP address changes on every restart of our modem. To know the Current IP address the following URL will be useful to you. http://www.ip-details.com/
Jul 25, 2012 | Zyxel P-2602HW Router (P2602HW)
MC 9090 doesnt keep Wlan profile
You can make your profile cold boot persistent by following these steps. Create the profile. Once saved click on your wireless icon and select options. Scroll down to export. Select the export all profiles and press ok to finish creating the .reg file.
Tech Support Barcoding Technical Support
Jun 04, 2012 | Symbol MC9090 Barcode Scanner
Hi, I have D-link AirPlus Xtreme G Wireless Router. The problem is that when i connect my laptop to the wireless connection it says it's connected but then i cant even open a page. I'm with...
The problem could be that the static IP address is not in the range as the IP address as the router.
You should let the wireless router issue an IP address to your computer.
Change the TCP/IP settings in your laptop's wireless card to Obtain an IP address automatically and Obtain DNS server address automatically.
Then reboot your laptop.
May 22, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
I cannot set the static IP for my MC9090. I went into Network Connections and have tried to Specify a valid IP address, Subnet and Gateway. I press ok. Then when I run cmd, I then type ipconfig and it...
Hi Jim,
I remember having the exact same problem when I first used the MC9090. It works on such other devices like the Datalogic Viper, but not the MC9090.
The IP is set within the wireless profile.
On the radio icon in the task bar select Wireless Profiles. This box then holds all your wireless profiles, including the default Motorola "out of box". Hold down the stylus on the screen and select "Add New" follow the prompts. When you get to IP Address from the pull down menu select static and then next this will take you to another screen where you can add your details.
Now you want to make them persist through either a cold boot or when the terminal has been left without a battery for a substantial amount of time.
This can be done 2 ways. When the profile has been set up highlight it by holding down the stylus on it and from the menu select export. This saves the registry key to the Application folder; a folder which persist through a cold boot. When it does cold boot it takes all the registry keys from the Application folder and builds 1 complete key.
The other way is to close the WLAN profile and selection options, from the pull down menu select export and save all profiles.
Hope this helps.
If you need any more help then please do not hesitate to contact us:-
http://www.biastechnology.com/
or TEL 01202 620955
Jan 14, 2010 | Symbol MC9090 Barcode Scanner
I cannot set a static IP on my MC9090 scanner but
Hi Jim,
Hope this helps.
or TEL 01202 620955
Jan 14, 2010 | Symbol Motorola MC9090 Mobile Computer
Configuring MC9090 default settings
Hi
When you set the wireless profile you set the SSID, WEP, IP etc. Which I'm sure you already know. Now you want to make them persist through either a cold boot or when the terminal has been left without a battery for a substantial amount of time.
Hope this helps.
or TEL 01202 620955
Dec 08, 2009 | Symbol MC9090 Barcode Scanner
Alow a scanner into the network
When you setup the wireless profile you set the SSID, WEP, IP etc. Which I'm sure you already know. Quite a few people forget the fact that they sometimes need to set a static IP if they do not have a DHCP server. Also if you set the WEP encryption keys incorrect the MC9090 will give you the green signal bar, but you can not get it onto the network, this has confused quite a few people in the past. Now you want to make them persist through either a cold boot or when the terminal has been left without a battery for a substantial amount of time.
This can be done 2 ways. When the profile has been set up highlight it by holding down the stylus on it and from the menu select export. This saves the registry key to the Application folder; a folder which persist through a cold boot. When it does cold boot it takes all the registry keys from the Application folder and builds 1 complete key and thus details of the wireless profile are imported.
The other way is to close the WLAN profile and selection options, from the pull down menu select export and save all profiles. Has a lightly different registry key setting. The bonus about this is if you pull note the registry key file name you can then browse for the key using active sync and copy it to a host PC. You can then copy this key to any other device and cold boot and hey presto your wireless profile appears. You would of course need to change a static IP and export the profile again to overwrite the existing one. If you didn’t export again you would get duplicate IP’s on the network.
The last thing to check is the regulatory options; if you wireless profile is showing a yellow warning triangle this is usually the problem. From the wireless icon in the task bar, select options and then from the pull down select “Regulatory”. Un-tick 802.11d and select the correct country. Then from the pull down select export and export options, this will make them persist through an old boot.
TIP: Always take a not of terminals MAC address and match the serial numbers or specific ID’s. If you do ever get duplicate IP’s you can trace the offending device using the MAC address and the list you create.
helpdesk@biastechnology.com or TEL 01202 620955
Nov 27, 2009 | Symbol MC9090 Barcode Scanner
When battery goes dead, does not save wireless LAN settings
PS Please stop informing people to phone manufactures tech support. Is that not what we are trying to bypass.
Jun 16, 2009 | Symbol MC9090-G RFID Handheld Barcode...
Wireless configuration problem. It lost parameters I had imposted.
Oct 30, 2008 | Symbol MC9090 Barcode Scanner
Symbol Motorola MC3090 Handheld Computer Logo
197 people viewed this question
Top Symbol Computers & Internet Experts
Michael
Oloyede Monsuru
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
